Question about NetGear RangeMax N150 Wireless Router WNR1000
The saved settings on my laptop for the network do not match the requirements of the network,what do i need to do ?
  • 7,627 Answers
First, delete the SSID and saved settings in Network and Sharing Center. I don't know your OS?. Then reboot the machine, Your wireless will show your not connected but wireless networks are available. Select your SSID, enter your "password", connect. dependind on your OS, a popup will ask to auto connect and save settings.
Posted on Dec 31, 2012
azz949
  • 55 Answers
SOURCE: trouble connecting on my netgear router model wgr614v7
Posted a solution on your other thread:-
http://www.fixya.com/support/t1594223-netgear_wgr614v7_network_security_key
Posted on Jan 25, 2009
Benzschwagel
  • 33 Answers
SOURCE: error message that says the setting on this computer for the
well, there are several possibilities for this. I would first check to see if DHCP is enabled on the router, also check the connection on the computer to see if it is automatically getting it's settings from the router (this is what it should be doing with DHCP on). It sounds like the IP address and/or subnet mask are configured incorrectly, possibly even the default gateway or DNS settings. On your average home network you should see 192.168.X.X for the IP address of the computer and 255.255.255.0 for the subnet mask. The Default Gateway is also usually 192.168.X.1
Hopefully this helps, post a comment if you need any more help.
Posted on Apr 01, 2009
anandg27
  • 1272 Answers
SOURCE: 'The settings saved on this computer for the
Well, follow the steps below for a better way to configure your connection:
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router with the Username as admin and password as password (unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
Now perform the steps below on the wireles vista computer:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a password setup on the router enter the security key.
7. This should setup the wireless network.
I hope the steps above will help resolve the issue. If you need any further help please email us back so that we can continue to work on a solution.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Sep 13, 2009
  • 825 Answers
SOURCE: settings saved on other computer for the network
This error message usually occurs in windows vista & win7 if the settings saved on the computer doesnt matches with the settings in the router...
You can get rid of this message by deleting the list of preferred networks from your computer...
To delete the preferred networks, follow the method given below...
Open control panel > open Network & Internet(double click) > open Network & Sharing center(double click)
On the far hand side left you will have an option called "Manage wireless networks" If you click that, you will see the list of preferred networks that are already saved in your computer... Now select your network, make a right click and select "Remove network" Select "ok" for all the warnings...
Thats it..! you are done..! Now search for the list of available wireless networks in range, you must be able to see your network name without any error mesages... Select your network and click connect, it will ask for the network key(if you have setup one)... Enter the key and get connected...! You must be able to go online now..!
Posted on Dec 20, 2010
Geekman
  • 32281 Answers
SOURCE: When I try to connect to my netgear wireless
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Nov 28, 2011
Can't connect with the internet. Message is "settings saved do not match the requirements of the network."
okay what you do is go to start documents and copy this to the address bar "Control Panel\Network and Internet\Network and Sharing Center" after you do that click on manage wireless networks on the side now click on your internet profile and hit delete after its deleted search and find you internet and set it up again
Apr 05, 2011 | IBM Lenovo ThinkPad T400 7417 Notebook
Our laptop won't connect to our network set up on our desktop home computer. The desktop is running Windows XP Home Edition V2002, and the laptop is running Windows Vista Home Premium V2006. When we try to...
In your laptop Open Control Panel > Network internet > Network and Sharing Center > Set up new connection or network > match with setting in your PC > Finish. Try to reconnect.
Feb 02, 2011 | Acer Computers & Internet
The settings saved on this computer for the network do not match,
You need to remove the wireless network from your preferred networks list and reconnect to it.
1. Right click on the wireless icon (picture of a computer) on your system tray.
2. Click on Network and Sharing Center.
3. On the upper left hand side of the page , click on Manage Wireless Networks
4. Right click on you network name and click Remove/delete
5. Now reconnect to your network.
Jun 09, 2010 | Belkin Wireless-N Wireless Router with...
My laptop keeps saying "the settings saved on this computer for the network do not match the requirements for the network" I can't connect to my home wireless connection
Most likely, you have the network key wrong. Double check it and make sure you don't have CAPS lock on when typing it.
One other possibility is that the modes of the router and the notebook are incompatible, i.e. router is set for 802.11n only and notebook can only do 802.11b/g. Check the settings for this on both and make sure they are compatible. If you need more info, let me know the makes and models along with OS for the laptop.
Jul 26, 2009 | Toshiba Satellite A305-S6863 Laptop
Unable to connect my wifi laptop to my existing wireless b/band
Your wife's laptop is setup to connect to another wireless network. It must be set up now for the wireless network that you are trying to connect to. This means that your wife's laptop is trying to connect to the wireless network somewhere else. You need to let the laptop look for available wireless networks. It should be able to see your wireless network. It will then require you to enter the password that you have set in your Zyxel. If you don't know the password, call Zyxel.
Feb 23, 2009 | Zyxel Prestige P-330W Wireless Router...
Laptop doesn't work with wireless router
in the OS issue try to remove the ip address of your computer network...let the router find the ip address suitable for the network ip...
in the router issue...try to reset and reconfigure the router.it will be reset in the factory settings..all will be renewed....
there are 2 option to fix your problem..if not solve try to send message again..tnx
Dec 31, 2008 | Linksys Wireless-N WRT150N Router
I cant get the laptop to connect to a wireless router. message comes up saying settings saved on this computer for the network does not match the requirements of the network. but it does not tell me how to...
Try checking if the laptop's wireless button is switched to on. It helps a lot! On my laptop, you have to switch a button to turn the wireless on. If i don't it's impossible to get a connect.
hope this helps :)
Dec 13, 2008 | Medion Computers & Internet
Wireless security settings on laptop do not match network settings
You will need to change the existing connection to match the "new" settings. I have had this issue with visita as well. If you open the wireless connections, go to advanced settings click on the "saved" SSIDs you can either delete the exisiting one, and start over (easy) or you can modify the settings to match the "new" upgraded system. Visita and XP store these for future use, problem is if one changes it "Doesn't match" so just delete the existing one and recreate it.
If they changed the password for the system or the type of encryption WEP to WPA etc this will correct the issue.
You may want to turn off the IPv6 which can also cause issues with Wifi in some locations.
Sep 05, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can not connect to internet on wireless acer laptop 5315. it says the settings saved on this computer for network do not match the requirements for the network
Your security key has perhaps changed.
You will need to check this key entered into your laptop against what is entered into the router.
Aug 30, 2008 | Acer Computers & Internet
NetGear RangeMax N150 Wireless Router WNR1000 Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
