Question about HP Laserjet 2420dn Laser Printer Duplex / J7949e 47k
How download hp2420dn printer driver directly on usb to use it to other computer which attached to 2420dn
    New Friend:
    Problem Solver:
  • 13 Answers
Go to the following link. http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=412132&lang=en&cc=us&prodTypeId=18972&prodSeriesId=416419&taskId=135
Click which operating system you need the driver for. Scroll down and download the driver for either PCL5 or PCL6. If its basic printing either of those will do. Save the .exe file to your USB drive. Connect USB drive to other computer. Run the file. Select a location on the PC ex. C:\Documents and Settings\"Username"\My Documents. Click unzip. This will extract driver files. To add these printer drivers go to Start > Printers & Faxes or Devices and Printers if its Windows 7. Click add printer select local printer attached to this computer. In the drop down menu select USB001. If you have different devices using USB you might have to repeat the add printer step until you find the right USB name. Once on right USB port click next and this is where you will click Have Disk in bottom right hand corner then click Browse. Go to the directory where you unzipped the printer drivers. Click on any of the .inf files. This action should bring a dialog where you can select a printer or it will just install. Click if you want to share or not share then hit next then if you want to print a test page (I would) click that. Click Next then Finish and your printer should be working properly.
-Ben
Posted on Dec 31, 2012
3 Suggested Answers
niquose
  • 198 Answers
SOURCE: HP2420dn printer spools SLOOOOOWLY
try to change spool settings
Control Panel-Printer Properties-Advanced Tab
Select Spool Print Documents-Start printing after last page is spooled.
Posted on Aug 11, 2009
I want to download the software for HP Laserjet 2420dn
Go to hp.com
click on support and drivers and look for the download drivers, software and firmware option.
Next enter your product number and click on go.
Select your operating system and you should be able to download the drivers.
Al
Aug 16, 2010 | HP LaserJet 2420dn Printer
I WANT TO BE ABLE TO PRINT FROM MY COMPUTER TO MY PRINTER
  1. Either set a static IP for the printer or attach your computer directly using USB.
  2. Setup the printer on your computer using the driver for the printer. If the printer has Postscript capabilities the PS driver is better than the PCL driver.
  3. If the printer is USB setup like any other printer, if the printer is IP then specify a local port in the Wizard and type the IP.
  4. Choose the driver and install
  5. Afterwards go under properties and select the printer components such as duplexer, extra trays, etc.
May 03, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Aug 11, 2009 | HP LaserJet 2420 Printer
I need hplaserjet 2420dn driver
http://www.printcountry.com/drivers/HP_DRIVERS.asp
http://www.soft32.com/download_176629.html
Dec 17, 2008 | HP LaserJet 2420dn Printer
49.4c02 service error coming in hp laser jet 2420dn printer
This is a firmware error, you can try turning the printer on and off a few times, reseating any memory and the formatter board. If these steps don't work Go to http: www.hp.com/
support/lj2410, www.hp.com/
support/lj2420, or
www.hp.com/support/lj2430.
Click Download Drivers and
Software
. Check for the
latest firmware image version
at the bottom of the page. If
this firmware image is newer
than the one installed on the
printer and the printer can
receive a firmware update,
download the newer firmware
upgrade. Not all printer
models can receive firmware
upgrades.
If still no joy replace the formatter (this is the normal coarse of action)
Aug 13, 2008 | HP LaserJet 2420dn Printer
HP Laserjet 2420dn Laser Printer Duplex / J7949e 47k Logo
61 people viewed this question
Ben Johnson
