Toner fly in Bizhub 500
In Konica Minolta Bizhub 500.After 80000 copies toner flies over the transfer unit. when paper comes through it the dark image comes on the edge of the paper.
  • Anonymous Jan 25, 2009
    * at that time count is 102,466.
    * no error codes.
    * no scraches on the drum.
    Yes I try to clean transfer unit several time but problem is not soveled.
    In this connection I like to say that developer & drum life is 250.000.
  • sam gerban
    sam gerban May 11, 2010
    what is the meter count ?
    any error codes ?
    any scraches on the drum?
    try cleaning transfer unit & cantact .
  • 1,326 Answers
The problem may be comming from the drum unit, there is a small over sray tray right under the developer mag roller. It is mostly filled up with waste toner or dropped toner from the mag roller. You have to take out the drum unit and then the opc drum and vaccum out the tray and that should take care of the problem for now... The problem will come back..... Have you ever had the developer and or the drum & blade replaced. Minolta are a duel component copier. When the developer is worn out it will start to trow toner and fill up the small tray under the dev. mag roller..... Good Luck
Posted on Jan 19, 2009
I have bizhub c450 , printing time devoloper comin on edge of paper , my imaging units are nes
Removed all imaging unit then below you will see PCL in every imaging unit you must clean it with soft cloth completely. When PCL is covered with dust,toner,dev etc.. the developer from your imaging unit become to fall causing developer on edge of paper(dirty copies).
Dec 26, 2014 | Konica Minolta bizhub C450P Laser Printer
Konica Minolta Bizhub c754e Blue Lines after installing new machine
The blue toner cartridge or drum are damaged. First, try a different toner cartridge. This will probably eliminate the lines.
Apr 08, 2014 | Konica Minolta Office Equipment & Supplies
Trouble c-2551 call service
Cyan Image Unit (Blue) Pull out cyan image unit not the cyan toner, Shake the image unit along the axis of the unit we want developer and toner spread evenly along the entire image unit. Then re-install. Reset code by closing and opening image unit door, not toner door. Worse case replace the image unit you do get bad ones.
Additional questions:
1.Is this a new unit?
2. Is it OEM or third party?
3. Is it new?
4. Did you chip it?
Sep 12, 2013 | Genuine Konica Minolta Konica Minolta...
How can i settle the problem of magenta developer finishing so fast. Magenter developer for Konica Minolta Bizhub C550 is getting finished so fast.
If the message Change Imaging Unit Magenta displayed refer to imaging unit with contents a developer.The Imaging unit life is 80.000 copies.
The imaging units located after front door when is located the waste toner box.
If the message M toner end/change the M toner displayed refer to toner cartridge
The toner cartridge life 15.000 copies 5% saturation.In full color mode the color saturation is 80% and the color toner life is 6.000-8.000 copies.
I think your problems is a toner not the developer.
Apr 11, 2013 | Konica Minolta Bizhub C550
There is an error code c-2558 showing on my machine konica minolta bizhub c452 please do let me know the proper remedy for it ASAP
Abnormally high toner density detected Black TRC sensor-
1. Correct the TRC Connection on the underside of the imaging unit if faulty
2. Reinstall black image unit
3. Change image unit
4. Change PWB-M
5. Change PWB-MFP
you can try # 2 then run 20-30 sky shops (copies with lid up to make black copies) put a white piece of paper over lead edge section of copy glass so you are only making 1/2 black copies if you don't the copy may jam in the fuser due to excess toner. after running copies turn machine off for 10 secs to reset and power backon. if problem continues I would change the image unit.
Aug 21, 2011 | Konica Minolta bizhub C250 All-In-One...
I have a Konica Minolta bizhub C450. Can the image unit be reset?
It may, but this mean that next time you put toner on the machine, you will expect less copy quality and printing for each toner bottle.
Dec 23, 2010 | Konica Minolta bizhub C450P Laser Printer
Cof32, blank copy on printing and copying bizhub c350
C0F32 is e developer problem,Imaging Unit ATDC (automatic toner density control) failure.
Try to add some toner and adjust the developer.
Enter service mode and adjust with F8
Apr 22, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta dirty copies
remove the filter and housing from the i/u and vac out the spilt developer, do the same on the underside, if background/halo is still there increase the seconary transfer value by 2 for plain paper
Jun 11, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
223 people viewed this question
jasbo
jasbo
