I have a Samsung TV (UE40D500) and a Pannasonic Home Cinema SC-Btt190. I cannot get surround sound to play though the TV or satellite box??
I have a Samsung TV (UE40D500) and a Panasonic Home Cinema SC-Btt190. I cannot get surround sound to play though the TV or satellite box?? I have full surround sound when playing DVD but not when TV or Sky. I bought an optical lead but there is no port on the TV to take this. I did have PC speakers connected to the TV using a speaker jack plug. I have also bought a AUX (red and white) to speaker jack cable but when I plug this in I loose all sound.. Can anyone help??
Rifaa
  • 99 Answers
SOURCE: samsung home cinama
Most likley your scart cable is the culprit, check whether the scart cable is the AV I/O type. And also better check the audio settings of the DVD player. Hope u hook up the speakers correctly. Cheers, Rifaa
Posted on Sep 04, 2007
SOURCE: cant get my viera linked panasonic to play through surround sound
I had the same problem, so i contacted panasonic, I am including the email they sent me.
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Posted on Dec 17, 2008
SOURCE: Gurus, I just bought Samsung Home Theater System which i connected to my Hitachi TV with HDMI cable. I have a Optical Cable going from HT to my TV Optical port. I have another connection from my cable
On the remote control for the Samsung Home Theater System look at the bottom left to a button that says "MODE", those moods change the sound each speaker gives off. if that doesn't work, you might need new wiring because there are other wires that are more durable than the ones that come with it, much better too.
Posted on Jun 03, 2009
  • 21 Answers
SOURCE: No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Posted on Sep 14, 2009
  • 21 Answers
SOURCE: Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
How to connect a ps3 to a panasonic sc-btt190 home theater
My suggestion would be to use the ps3 to connect to TV using hdmi & then use an optical audio output (toslink) from TV to the btt190... You would think they would have one or two hdmi connections there but no they have none.... This is how I connected appletv to the btt190.... Works fine you just have to set tv input to appletv and btt190 input to >>ext in >> digital in....
Good luck. Btw have you connected to network? Did you have any troubles - mine will not connect via cat5 cable...
May 19, 2013 | Panasonic Sc-Btt190 Home Theater System...
Why do USB video's play through LG Plasma but not through Panasonic SC-BTT190 home theatre system?
Its really a software type problem i have a sony hometheatre that wont play certain videos. When tvs/home theatres are made they get whatever software that is put in witch most videos require the basic stuff sometimes its outdated or just not compatable.
Jan 02, 2013 | Panasonic Sc Btt190 3d Blu Ray Home...
My panasonic sc-btt190 3d blu-ray will not play usb video
Could be software isnt compatable on one but is the other most times its just outdated.
Jan 02, 2013 | Panasonic SC-BTT190
How to hook up my cable box and tv to panasonic sc-btt190
You could have a bad Hdmi outlet . Try hooking up component c what happens
Dec 19, 2012 | Panasonic Sc-Btt190 Home Theater System...
I cant get my samsung home cinema system to play through my t.v
I bought the optical audio cable ($15 WalMart) and use the Digital In on the DVD player to play the sound through the surround system and turned the TV speakers off. Works great! The optial audio has square ends and looks transparent with just one round shaped cable that goes from the TV to the back of the DVD player.
Jan 01, 2009 | Samsung HT-X40 System
Dec 10, 2008 | Panasonic SC-HT75 System
We have recently just bought a samsung htx250r home cinema. we have a 50 inch samsung plasma, the dvd player sound works using the hdmi cable but the surround sound does not work when we are watching...
Salutations ddog,
Really this is a question of sources. The reason your able to hear surround sound when connected to your DVD player is that is what is providing your audio and video source. When your watching television it would depend on how your getting your broadcasts. If you are either receiving an over-the-air broadcast or cable directly to your set, your television becomes the source. As your television is providing the signal, you would need it to loop back to your receiver to provide that surround sound.
Now for the good news, if you have a cable or satellite box these should have outputs to connect to your receiver to provide the audio source.
Also keep in mind not all broadcasts provide a version of surround sound. Most newer home theater systems will replicate surround sound artificially.
I hope this helps.
Jon
Go Ahead. Use Us.
Jul 05, 2008 | JBL SCS200.7 Home Cinema Package System
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
108 people viewed this question
 Grubhead
Grubhead
