Question about NetGear RangeMax N150 Wireless Router WNR1000
The settings saved on my computer do not match the requirements of the network.,how do i set up?
  • 7,627 Answers
Delete Saved settings, reboot, select SSID, connect.
Posted on Dec 31, 2012
azz949
  • 55 Answers
SOURCE: trouble connecting on my netgear router model wgr614v7
Posted a solution on your other thread:-
http://www.fixya.com/support/t1594223-netgear_wgr614v7_network_security_key
Posted on Jan 25, 2009
Benzschwagel
  • 33 Answers
SOURCE: error message that says the setting on this computer for the
well, there are several possibilities for this. I would first check to see if DHCP is enabled on the router, also check the connection on the computer to see if it is automatically getting it's settings from the router (this is what it should be doing with DHCP on). It sounds like the IP address and/or subnet mask are configured incorrectly, possibly even the default gateway or DNS settings. On your average home network you should see 192.168.X.X for the IP address of the computer and 255.255.255.0 for the subnet mask. The Default Gateway is also usually 192.168.X.1
Hopefully this helps, post a comment if you need any more help.
Posted on Apr 01, 2009
anandg27
  • 1272 Answers
SOURCE: 'The settings saved on this computer for the
Well, follow the steps below for a better way to configure your connection:
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router with the Username as admin and password as password (unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
Now perform the steps below on the wireles vista computer:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a password setup on the router enter the security key.
7. This should setup the wireless network.
I hope the steps above will help resolve the issue. If you need any further help please email us back so that we can continue to work on a solution.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Sep 13, 2009
SOURCE: I followed your advice regarding Netgear not
how to install netgear switch
Posted on Dec 08, 2009
  • 825 Answers
SOURCE: settings saved on other computer for the network
This error message usually occurs in windows vista & win7 if the settings saved on the computer doesnt matches with the settings in the router...
You can get rid of this message by deleting the list of preferred networks from your computer...
To delete the preferred networks, follow the method given below...
Open control panel > open Network & Internet(double click) > open Network & Sharing center(double click)
On the far hand side left you will have an option called "Manage wireless networks" If you click that, you will see the list of preferred networks that are already saved in your computer... Now select your network, make a right click and select "Remove network" Select "ok" for all the warnings...
Thats it..! you are done..! Now search for the list of available wireless networks in range, you must be able to see your network name without any error mesages... Select your network and click connect, it will ask for the network key(if you have setup one)... Enter the key and get connected...! You must be able to go online now..!
Posted on Dec 20, 2010
Settings saved on this computer for the network do not match requirements of the network
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Jan 03, 2012 | D-Link DIR-615 Wireless Router
Can't connect with the internet. Message is "settings saved do not match the requirements of the network."
okay what you do is go to start documents and copy this to the address bar "Control Panel\Network and Internet\Network and Sharing Center" after you do that click on manage wireless networks on the side now click on your internet profile and hit delete after its deleted search and find you internet and set it up again
Apr 05, 2011 | IBM Lenovo ThinkPad T400 7417 Notebook
Our laptop won't connect to our network set up on our desktop home computer. The desktop is running Windows XP Home Edition V2002, and the laptop is running Windows Vista Home Premium V2006. When we try to...
In your laptop Open Control Panel > Network internet > Network and Sharing Center > Set up new connection or network > match with setting in your PC > Finish. Try to reconnect.
Feb 02, 2011 | Acer Computers & Internet
I have set up my USR9111 but message says" The
The reason you get this error is the name used for this current network was previously saved with settings when used before. All you have to do is,delete this network from the preferred network list from your compute and re-connect your computer to the network and you will not receive this error message again.
Hope this helped. For further assistance please feel free to contact us.
Jan 21, 2011 | U.S. Robotics (USR8054) Router
Settings saved on other computer for the network do not match the requirements of the network now
Dec 14, 2010 | NetGear WNR2000 Wireless Router
My question is ''thes settings saved on this computer for the network do not match the requirements of the network'' how to connect the wireless internet on my computer now? PLEASE see
See there are some old settings saved on your computer for the same wireless network name.
I believe the operating system on your computer is windows VISTA / 7 .
Now you will need to remove the network from the preferred network list. then add the new network on your computer and you will be able to connect to the network. Make sure that you have all the wireless settings of your network. If you are not sure about the wireless settings of your network then you will need to check the wireless settings of the network.
Apr 08, 2010 | WiFlyer - Portable, shareable WiFi base...
After we turn the computer on it is telling us that the "the settings saved on this computer for the network do not match the requirements of the network"
This may work for you. This is for Vista
Under network & sharing center ...... go to manage wireless network ...... Configure the wireless settings manually .....try to connect to network ......
Hope this helps.
Nov 08, 2009 | Belkin (F5D7230-4) Router (587009)
Can not connect to the internet via router
use the network set up wizard, new connection.
Oct 01, 2009 | Computers & Internet
NetGear RangeMax N150 Wireless Router WNR1000 Logo
49 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
