Question about RTO Schiller America At-2 Plus Combo Ecg/spirometry Unit Tabletop Model Calibra
Ecg delta 3 plus user instructions - RTO Schiller America At-2 Plus Combo Ecg/spirometry Unit Tabletop Model Calibra
With manythanks,can someone mail the user manual or handbook for schiller ecg/ekg at 3 ?
Manual for AT-2 (I presume that it's similar to AT-3) says that language may only be changed with SWUP program (whatever that means). To change date: ALT - 9 - 2 - 2 - D - D - M - M - Y - Y
To change time: ALT - 9 - 1 - 1 - H - H - M - M - S - S
To reset clock to start counting: ALT - 9 - 9 - 9 - 2 - 1 - 0
NOTE: This is settings for SCHILLER AT-2, I'm not sure that'll work with AT-3.
I hope this was helpful.
Dec 18, 2014 | Schiller Medical
User manual ecg-101g
Check the bellow link for the user manual of ECG 101G
User manual
Ajin
Mar 28, 2012 | Medical
Edan 3 Channel Ecg Unit Se3 user manual
Check the following link for the user manual for Edan SE 300 series Ecg
Ajin
http://www.pocketnurse.com/pdf/01-43-9000.pdf
Feb 08, 2012 | Life Science Edan 3 Channel Ecg Unit Se3
My Cardioline Delta 1 Plus EKG Machine is reading message " himem error" what does that mean?
First of all, the Cardioline Delta 1 if defective would require shipment to Italy for repair, parts and technical information is at a premium this sid eof the atlantic on that particular model. In this case you might be able to resolve your problem by clearing your directory. Acording to Cardioline technical support, that *may* refer to a directory full situation. If you have a copy of your operators manual, refer to it regarding clearing your patient directory and deletion of all the patient data files. Note that doing so will permanently destroy any saved patient data, so print out anything that is important first. I cannot personally vouch for the accuracy of this information, as we have not sold a Delta 1 in many years, and ill admit to being rusty. In fact the tech support engineer was also unfamiliar with your error message, so this amounts to a *very slightly* educated guess. I hope it helps.
Nov 03, 2011 | Schiller Welch Allyn Cardiovit At 2...
Do you have a poster for correct lead placement for AT-2 plus ECG? thanks!
hi,
If you need to know how to place the leads then whach the following video. All 12 channel ecg machines have the same lead placement
Jun 23, 2011 | Schiller Welch Allyn Cardiovit At 2...
I have Schiller AT-2 Plus, i need instruction
press Alt then 9 - 1 - 1 for the time.
press Alt then 9 - 2 - 2 for the date
May 09, 2010 | Schiller Welch Allyn Cardiovit At 2...
I have Schiller AT-2 Plus, i need instruction manual,or guide me how to chnage date and time,hospital name.
i want to configure my Schiller at-2 plus ecg machine from dutch to english and 3channel to 6channel
Mar 17, 2010 | Schiller Welch Allyn Cardiovit At 2...
Where can i download the user manual for this ECG?
I would just go to a store that sells them and buy a new one go home photo copy the instruction manual and then take it back and get your money back! Good luck.
Nov 20, 2009 | Ge Medical Systems Ge Marquette Mac 1200...
The schiller at 2 plus ecg machine not printing ecg
Does it work in auto mode ? are you putting paper correctly means , there is a black mark on paper which is sensed by paper sensor .If you put paper up side down then paper sensor won't be able to sense any paper & gives you error for rifilling paper .If this doesn't help you then You need to replace battrey . Thanks
Jul 15, 2009 | Schiller Welch Allyn Cardiovit At 2...
RTO Schiller America At-2 Plus Combo Ecg/spirometry Unit Tabletop Model Calibra Logo
79 people viewed this question
Top RTO Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you a RTO Medical Expert? Answer questions, earn points and help others
