Question about Electrolux Ovens
How to remove eletric grill - Electrolux Ovens
Change light in whirlpool gold accubake system upper microwave oven
If you need to replace the bulb for the interior cabinet, you'll need to remove the two screws that holds the upper grille in place with a Philips screwdriver.
Access to these screws are from on top of the microwave.
Once you remove the grille, you should see a white plastic cover with a release tab; pop the open and you'll have access to the bulb compartment:
Watch the following youtube video- the instruction phase of removing the grille and access to the bulb compartment starts at 2:40
http://youtu.be/RQM302PShKw
Mar 04, 2015 | Whirlpool Ovens
Oven won't heat
"heating and broil elements check ok?"...by using ohmmeter I assume? next step: unplug oven or remove power source; remove back cover of oven and ohm the thermocouple (unplugged) while heating/cooling it. Resistance readings should change quite a bit. If this checks out, your control board inside the panel is fried.A new one will cost $200-$300. If oven is more than 10 years old, I doubt if you'll find one.
Mar 05, 2014 | Whirlpool RBS305PD Electric Single Oven
My Neff eletric oven works on top and bottom heat, but does not heat up on the fan setting fan. It heats slightly and the fans works but it does not reach temperature.
You need to replace the oven element
This is located at the rear of the oven compartment behind a removeable cover, it is usually circular in shape
Jan 26, 2011 | Neff B1421 Electric Single Oven
On my whirlpool oven FCEM6 the display says STOP and I can not get anything to work.
hi i have a whirlpool oven type fcem6 model akz151/1x i turned the oven on and it triped the eletric and the oven would not work so i got a new element and now just the grill works but not the oven help plz
Dec 28, 2010 | Ovens
My grill element on my zanussi oven, ZBF 260, has stopped working. How do I remove the faulty part so I can replace it?
after isolating electric. remove oven from housing ( 2 or 4 screws) remove back of appliance to access retaining nuts .( disconnect wires noting terminal position). grill is fixed to roof of oven with screws remove these and take out grill. refit in reverse order remember to reconnect wires .
Aug 24, 2010 | Zanussi Ovens
Can I change the grill element myself? I assumed it just plugged in at the rear and have removed the two screws holding element to top of oven. Now I wonder if the steel plate at the back is itself bolted...
The grill element is not usually a 'plug-in' device.
You will have to remove the back of the oven/grill and disconnect it from the back before you can withdraw it from the front.
Remember to switch off the power before removing the back.
Jan 12, 2010 | Bosch HBN 131560B / 131520 hot-air...
HELLO MY FAN OVEN STOPPED WORKING ALTHOUGH THE ALL OVER FUNTIONS ARE OK. WHEN I TURN THE FAN OVEN ON I CAN HEAR THE SOUND OF THE FAN BUT THERE IS NO HEAT EVEN AFTER A LONG PERIOD OF TIME.
If it is an eletrically heated fan oven, thei it sounds like the oven element has failed.
This is usually located at rrear of oven behind a removeable cover.
Hope this helps you.
Dec 06, 2009 | Ovens
New World TGO 70 grill not working because door was closed
THIS IS PROBABLY BEST LEFT TO A QUALIFIED ENGINEER. To reset the grill thermal cut out. This is located under the metal panel at the top of the unit and it is necessary to ether partially or fully remove the whole oven from its housing to get at it. 1. Disconnect electric supply. 2 remove the 2 housing retaining screws. These are located either side of the at the top of the grill cavity. 3.Pull the whole oven /grill unit out and support it underneath to stop it falling forward. 4. Remove metal cover covering top of oven. 5. the safety cut out is a small component that has 2 wires connected to it by spade terminals, in the middle of which is a small red button. push this button gently with the end of a pencil or screwdriver until it clicks. This should now be reset and allow the gas supply to the grill to resume. Finally reassemble making sure that the integrity of the gas and electrical supplies are, in no way compromised and test.
Aug 20, 2009 | Ovens
Grill door removal
you have to remove the glass front to access the screws to secure the grill
Feb 21, 2008 | Electrolux EOD5310 Electric Double Oven
Hotpoint eg76x grill
If the grill is working in some positions on the switch but not in others it sounds like the switch under the knob may be the problem. Does the same switch control the fan? If yes I would say you will have to replace that switch and that the contacts more than likely are worn inside the switch. Switches are usually not hard to replace and usually have lugs or a push/pull connector. Make sure you TURN OFF the POWER before you start trying to remove it. Hope this helps.
Regards
Bryan
Feb 17, 2008 | Ovens
Ovens Logo
13 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
