Question about Ad Tech Multi-Temp Hybrid Cordless Glue Gun
Hi - just bought a Ad Tech Hybrid Cordless glue gun and Ad Tech glue sticks but the sticks are too large to fit - is there a way to resize the sticks?
    Champion:
    New Friend:
  • 217 Answers
Ad tech makes a few different size guns. you need to make sure that you are using MINI GLUE STICKS. they should be 0.28 inch in diameter. there is no good way to resize the larger sticks, just buy the mini ones instead
Posted on Feb 26, 2013
How do you get a stuck wooden stick out of a hot glue gun?
Switch the glue gun on and allow it to heat until the glue softens and then try and pull out the stick.
Feb 08, 2018 | Crafts & Hobbies
Bought a glue gun to re cover my lamp. Unfortunatley there was no Instructions
Pretty basic to use. Insert glue stick from the rear, push it as far as it will go without forcing it, if there is room put another one behind it. turn on gun and wait til it gets hot. stand it on something that will not get damaged from the glue, a piece of cardboard for example, you should see glue start to drip through the tip. now press trigger (gently at first until glue is really hot) and glue will flow, the longer the gun is on the glue will be easier to get flowing. release trigger and glue will stop, (although a little will still come out) When there is room always place a glue stick behind one already in to help the continuous flow of glue. That's pretty much it really.
Jan 17, 2014 | Master Appliance Crafts & Hobbies
HOW IS THE INSIDE WIRES WIRED?
This is a cordless glue gun... which wires are you referring to?
Sep 13, 2012 | FPC Corporation FPC Pro700 Cordless...
I have a new Surebonder rechargeable glue gun. I was gluing a large pc. and rushed to get another stick and it would not feed by pulling the trigger, There was one glue stick (partial) still in gun, but...
it sound like the charge ran down, recharable glue guns are not typically recomended for large project becuase heating elements run down batteries very quickly. to get the stick out of your gun, you will need to fully charge it and then after that turn it on and when its warm pull the trigger and the glue should once again come out, For large project I would recommend you purchase a wired (plug in the wall) type glue gun. Thanks for you question
Mar 22, 2011 | Crafts & Hobbies
Arrow TR 550 heats up fine but glue stick won't feed by the trigger. If I push the stick with my hand glue does come out, but the trigger seems to "slip" on the glue stick. Any ideas?
The trigger probably really is slipping on the glue stick. If you've changed the type or size of glue recently, try changing back to what you were using, or just something else. Maybe the glue stick is too small, or too slippery for the gun. If not that, then it's a mechanical problem. There are some screws on the side of the gun. With it unplugged and cool, take them out and open the case. It might be stuck together with some internal connections as well as the screws, but jamming a flathead screwdriver in them can usually wedge them apart. With the gun open, move the trigger and look for the parts that move with it in the area where the glue stick goes. If you can find something to attach to these parts to make them just a tiny bit longer, do that. The parts that grip the glue have probably worn down or just don't fit, and the fact that you can tell the trigger is slipping means that it's probably very close to grabbing, but not quite close enough. Any little extension to the grabbing parts should do, but be careful not to block the path of the glue.
Feb 28, 2011 | Heavy Duty Arrow Pro Glue Gun Tr550
How do i insert glue stick in to my emhardt electric glue gun
Insert the glue stick into the back of the gun. After doing this plug in the gun and allow it to heat up. When the gun reaches the correct heat level you will be able to pull the trigger of the gun which will pull the stick into the gun. This will only happen if the gun is hot enough.
Aug 16, 2010 | 3M Polygun AE II Hot Melt Glue Gun
Dewalt Glue Gun Warming Problem
Are you in the UK? The fuse in the plug might need replacing. I had the same problem with glue guns. It's not worth buying an expansive one. The cheap ones might take a bit longer to heat up but the last just as long if not longer. I can never tell when the element will go.
Aug 27, 2008 | Dewalt 18V Cordless Adhesive Dispenser...
Glue Gun Troubleshooting
1. Insert your wax stick into a standard sized glue gun. The fit may be tight. The more wax you use, the smoother the fit. 2. Use a second wax stick in the gun to help advance the first, if needed. 3. Heat the gun up to temperature. 4. Do a few test pulls on the gun to get a feel for the quantity of wax you would like to use with your seal. (Two good pulls of the trigger will produce a full seal for the larger sealing coins.) 5. Wait for 10-15 seconds, then press your seal firmly into the wax before it hardens. 6. Lift the seal slowly off the wax. If it comes away and the wax is still quite soft, wait a little longer before pressing the seal down.
Aug 27, 2008 | 3M 5/8 x 8 - Low-Melt Adhesive Clear
Ad Tech Multi-Temp Hybrid Cordless Glue Gun Logo
222 people viewed this question
Top Ad Tech Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Ad Tech Craft and Hobby Expert? Answer questions, earn points and help others
