Question about Refrigerators
Got bits floating in the water of my non plumbed daewoo fridge freezer
Non plumbed model frs u21pci has floaters in the water tried running several tanks of water through it still no good
  • Geoff Towler
    Geoff Towler Jan 02, 2013
    as I said its a non plumbed model and when I put the glass underv to fill with water its got bits floating in it what more can I say
  • 183 Answers
SOURCE: need help
With this model it suffers with the evaporator freezing up, try to defrost overnight with the doors open, restart the following day and it should start to work ok within 24hrs. Regards Advisor
Posted on Sep 01, 2007
SOURCE: Daewoo refrigerator water filter red light still on after replacing the filter
Press and hold "ICE MAKER LOCK" button, and while holding it shortly press "LOCK" button, and the light will change to green LED.
Ivan
Posted on Nov 12, 2007
SOURCE: Daewoo FRS-2031IAL instruction manual
Hold down the [ice make lock] and then the [lock] button simultaneously for 3 seconds. It took me a couple of attempts but I got there in the end (the manual mentions holding them down at the same time).
Posted on Apr 21, 2009
SOURCE: Daewoo FRS U20 DAi side by side f/f fridge
MIne has the same problem, the insulation is breaking down and cannot be repaired.
Posted on Jan 14, 2011
baraquielnar
  • 247 Answers
SOURCE: My Daewoo FRS-2021IAL fridge/freezer control
try to re insert the ribbon connector on your PCB board possible loose connection then reset your unit to unplug your unit for a few minutes the n plug on after then observe the operation.
Posted on Mar 06, 2011
Testimonial: "Thankyou. I tried that with all the connectors, with no joy. Tonight the control panel light kept coming on for no reason. ??"
Ice maker problem daewoo frs-2031 IAL
I wouldn't buy a Daewoo fridge with Donald Trump's money!
Jun 27, 2016 | Daewoo Freezers
Mw Daewoo fridge freezer FRS-20321BE is leaking water copiously from the refrigerator I cannot see any source for this but puddles form and flow internally under the veg box. Help!
All depends on how much water is collecting. A lot of water indicated a leak from the ice maker. A small amount and it's probably a clogged condensate drain. Here's a YouTube video on a different brand showing a clogged drain, your may be similar (or not), but it might give you an idea as to where to look. Refrigerator dripping water inside FIX
Mar 07, 2016 | Daewoo Refrigerators
We have a FRS-U20FA
The water dispenser tube has a low wattage element to prevent the water from freezing in the tube. its normal. Check to see if the evaporator fan is running. Open the freezer door and when the fridge is running, press the switch on the side wall. The freezer light should go out and then you should hear the fan running at the back of the freezer compartment. Common symptoms of a failed fan is ice growing down the back of the freezer compartment , poor refrigeration in the food compartment and partial or poor freezing of food in the freezer. If the fridge is less than 2 years old, it will be under warranty. (Contact Castel Electronics in Melbourne 13
00733962) If its over, they can give you the name and number of a local agent. There are a lot of bits and pieces to remove to get to the fan on an ice and water model, also the rear panel inside the freezer should be removed to make sure ice hasn't blocked the air ducts. If you are not confident in doing it, get one of their agents to sort it out. Cost of fan motor, call and labour should be around $200 to $220
Dec 26, 2013 | Daewoo Refrigerators
Daewoo frs-u20dai service manual
my Daewoo side by side fridge freezer FRS-U2ODAI keeps leeking water from underneath and it says on screen DEODORIZER and FUZZY can u help
Apr 03, 2012 | Refrigerators
Hello, I have a daevoo fridge/freezer \model FRS-2031 IAL I need to plumb it into the water supply for the ice and cool water but do not have the user manual. Can you assist please
You can download the detailed user manual from the following link.( http://www.nodevice.com/user_manual/daewoo/refrigerator_or_air_conditioner/frs-2031ial.html ).Enter the verification code shown into the box and click download.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 17, 2011 | Refrigerators
Just bought DAEWOO FRS-U20DC,cannot get ice maker
how do i suse my model 230 gps
Aug 27, 2009 | Freezers
Need help
Jul 14, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
