Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
I have a samsung hlp 4663w dlp just stopped responding to either the remote or direct attempts to turn the picture on...the tuner/amp is working fine as we still have audio, just no video...there is power to the set and i can see light from the bulp vents on the back lower right side...any ideas? thanks...bob
  • 42 Answers
Bob I have seen the DMD on the light engine cause this
The DMD board is available through your local parts distributor
You said you had sound so the analog board is working
The digital board may also be suspect
It is a lot more expensive than the DMD
I would replace the lamp if it is over two years old just on principle
Good luck
Posted on Feb 10, 2009
I had pin holes on my projection tv, with the hlp of jimmys .com video I was able to change out the dlp chip, tv looks great except picture is1in to high on the screen. Samsung HL67A750A1FXZA . HELP
A Convergence of the screen problem made by a special tool made on marketing technical decision in a little memorychip or (maybe there is a special servicemode for picture geometrical adjustments , ask for it your dealer or it has autoconvergent then there could be are also a few bad capacitors to replace. most change to find in the vertical group.
Samsung HL67A750A1FXZA Service Manual Page 19
Sep 03, 2016 | Samsung Televison & Video
We have a samsung DLP tv model number HLP 4663W tv. The picture went so we replaced the bulb. Still no picture and the tv makes a noise that sounds like a fan and the tv cycles on and off by itself. ...
Yes, almost certainly a bad color wheel, see attached photo.
If you remove the lamp and look in the direction it faces you should be able to see the wheel, look for it to be missing pieces or shattered.
You Tube has detailed video instructions for replacement in most of the Samsung sets; I have replaced dozens of the wheels.
Before you rate my solution let me know if you have any questions by commenting here.
Jul 08, 2011 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLP 4663w dlp-hdtv replaced lamp and ballast, still not working. lamp/standbytemp and timer all flashing. i get no clicking on ballast, upon power up all i hear is low fan or vibration sound which...
If the capacitor on the ballast was puffed up or blown up you have to replace the lamp, ballast & SMPS at the same time. But if the ballast is not trying to fire the lamp it sounds like the color wheel is not coming up to speed. If this is the case, the set will not turn on.
Sep 22, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
I have a hlp 4663w that will not turn on checked the bulb it good. three lights blink that it .what is the prob
First. Lamps can look ok in the center and still be bad. Install a new lamp since I do not know when you replaced the lamp or if at all. Turn on the set and at the same time look through the Lamp Door vent slots to see if the lamp Illuminates. If so your lamp is ok and the Color Wheel is bad.
Apr 06, 2010 | Samsung SP46L3HX 46" HDTV-Ready DLP TV
Samsung hlp 4663w does not receive off air signal from roof antenna through antenna ports 1 or 2. Get cable signal just fine through same ports. Same antenna works fine on other tvs. Whats the problem and...
If you're in the US, you will no longer get antenna signals because the US has recently switched to digital. The TV you have does not have a digital tuner and you'll need to purchase a digital converter box that converts a band of analog signal to digital.
Feb 03, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP 4663W DLP TV 3 lights blinking
Color wheel is the biggest failure part in Samsung DLP...
A little technical to replace...............T.
Jan 22, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Hi, I have a Samsung HLP 4663W TV and cannot get it to power on. We bought it used about 4 months ago, but has been fine.  Did not notice any problem when we shut it off, after a couple of hours would not...
Get a high pressure can of air and blow out circut boards with quickshort bursts (after removing lower back pannel! It may also be your flyback voltage regulater (about 60.00 for part!
Dec 11, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Issues with replacing Ballast
I have some proble dlp tv I put new lamp;put the problem didnt whant away
May 05, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung hlp 4663w
Samsung color wheel fix
http://www.jaGet a new cable if everything else works that is your problem
Dec 16, 2007 | Samsung HLN5065W 50" Rear Projection...
Sumsung HLP 4663W
Might be a bad ballast, has the picture been dark?
Jun 21, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
113 people viewed this question
Jerry Greenberg
Jerry Greenberg
