Question about Dryers
Bosch dryer stop working after 5 minutes, Drying light blinking, Wrinkle Block light blinking, 4 beeps in a row repeated every couple of seconds
SOURCE: bosch maxx wtl 6300 dryer when
Hi Guys...
At least I can shed some light on how to open the bottom part.
When you are looking into the dryer with the door open, take a look at the bottom hinge of the door. There is what looks like to be button popped out slightly..
Place your thumb on it and press. This should open the bottom part of the dryer.  Then clear out the gap between where the lint filter connects to the other units below it (when the door is closed...)
Hope this makes sense... there seems to be a sensor there..  I just cleaned mine so praying that the beeps stop.. Its been driving us mad for the last 8 months!
Posted on Oct 25, 2008
  • 1214 Answers
SOURCE: Fridgidaire dryer beeping and flashing lights
Download the troubleshooting instruction sheet here ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134509400efs.pdf
Follow the instructions and reply back what you determine and I will help further.
Posted on Jan 28, 2009
  • 3074 Answers
SOURCE: I have a Bosch series 500 dryer that has stopped
sounds as though the belt maybe off, you will have to disassemble the dryer and investigate. hope this helps tim
Posted on Aug 28, 2010
SOURCE: asko t702c stops working after about 5 minutes
If you continue to try to run the dryer after the automatic shut off kicks-in it will shut the cycle down with no flashing lights after the dryer reaches a critical and dangerous temperature. If the dryer is skipping immediately to this step without any flashing lights then call an Asko certified repairman as something may be wrong with the machine. If you have not tried cleaning the condensor, please do this as well. Remove the bottom housing of the dyer, move the two red handle to the right, and pull out the condensor unit. Wash it under warm/hot water using a bathtub or shower and you will see lint and dust come out by the heapful. Replace the condensor unit, wait about 30-45 minutes, and then try restarting your dry cycle.
Kevin C., Asko USA.
Posted on Jan 06, 2011
  • 39 Answers
SOURCE: The dryer has stopped working.
We have the same dryer and found it was the micro switch on the panel that was the problem. Have you read and tried this solution.
Not sure if this will address the problem but it maybe worth a try. We also had problems with our dryer starting but the lint indicator was not on. We found the problem was with the start/stop button; it was not making contact with the mini-switch. Used some hot glue under the lever that makes contact with the mini-switch. Put it back together and works great again. Saved about $260 on new control panel. Removing the control panel was pretty easy for a DIYer.
Unplug the dryer.
Remove the four screws that hold the panel in place. They will be hidden under caps on the housing, Pull off the panel. Be careful because the wires will prevent you from pulling it entirely off but you can pull it from the right corner up and flip it on its back side to expose the back of the panel.
The white wire guard will have to be removed. The wire ties holding the wires to the guard will have to be removed by cutting the ties. Replacement wires ties can be purchased at any home improvement store. Remove the control panel by pushing the plastic clips in that hold it to the housing. There should be 6 and two plastic clips on the right center of the panel. If done right it will easily pull off. If force is needed one or more of the clips have not been disengaged. Do not force it because it is made of plastic and will break.
Once the control panel is removed from its housing, the start/stop button can be identified-last one either on the right or left (can
Posted on Feb 07, 2011
Bosch dryer beeps
Two Beeps on my Bosch WTE84100au Condensing Dryer means a thermal overload but also means one of the thermal sensors is faulty .... as if it is always on.
Open the door, pull out the lint catcher and clean around the silver probe (it's like a shiny 1/8" nail sticking into the cavity below the lint catcher). If it still doesn't work (and still 2 beeps), just flick it lightly a couple of times. If it still doesn't work, flick again from the other direction.
Mar 24, 2014 | Dryers
My dryer Bosch maxx 7 doesn't work
That is a bad motor. It is overheating and the overload is shutting it down. Check to see if there is lint buildup on the motor. If not, you will need a new motor.
Nov 04, 2012 | Dryers
I have a Bosch V20-Ul dryer that is 2 years old. Suddenly stopped creating heat. The dryer drum turns but no matter which cyle I select, it spins for about 1 min, then stops, beeps and the wrinkle block...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 09, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Cycle Signal keeps beeping loud-soft every 15 seconds while dryin
Hi Celine, I just experienced the same exact problem. I came here looking for a solution. I got mine to stop by holding down the cycle signal button for 3 seconds, releasing it for three seconds, and repeating until both lights (loud and soft) went off. Hope it helps.
peter
Apr 21, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore dryer beeps constantly
End of Cycle Signal
The End of Cycle Signal produces an audible sound when the
drying cycle is finished. Promptly removing clothes at the end of
the cycle reduces wrinkling.
@ H_GH
@ LOW
@ OFF
END of CYCLE S_GNAL
Press END of CYCLE SIGNAL to adjust the sound level or turn off
the signal.
NOTE: When WRINKLE GUARD _ is selected and the End of
Cycle Signal is on, a tone sounds every 5 minutes until the
clothes are removed, or WRINKLE GUARD _ ends.
Sep 15, 2009 | Dryers
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
Error code DR
Pull the tech sheet out of the dryer ( behind the lower front access panal ). The lights flashing are trying to tell you a fault code.
A copy:
MODEL DIFFERENCES: • Better models have a digital readout display
• Good models do not have a digital readout display
READING ERROR CODES 1. Position cycle selector knob to the 3 O’clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O’clock position.
On better model dryers, the error code will appear in the digital display. On good models, the five indicator lights of
Drying, Cool Down, Wrinkle Rid, and Clean Lint Filter Spin will flash the number of times for the first digit of the code
and the START indicator light will flash the number of times for the second digit. Take separate counts of each indicator
light, then repeat to confirm in order to be accurate in identifying the proper error code. The code is obtained by counting
the number of times the lights flash. Example E24: The five indicator lights would flash twice indicating the 2 and the
START indicator light will flash four times indicating the 4. The five indicator lights and the START indicator light start
flashing at the same time. The control will pause for 2 seconds, then repeat the code.
Note: A letter appearing in the code stands for a number higher than nine.
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code E4A: the first digit would be 4 and the second digit would be 10. If this code would appear on a dryer in
the Good model line, the five indicator lights would blink four times and the START indicator light would blink ten times.
Troubleshoot problem by using chart below.
To move on to the next code, press the OPTIONS button. To clear code, press the Select button.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
jeff.
__________________
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Jan 10, 2008 | Frigidaire AEQ7000ES Dryer
Problem when drying gets to 1 minute mark
This is happening when you selected the wrinkle prevent option or you set it to wrinkle release cycle.what it does is it is tumbling with no heat to release the wrinkle in the clothing. This is normal.It could also be normal part of drying in "regular" cycle
May 29, 2007 | Maytag Neptune MDE6700A Electric Dryer
Dryers Logo
Top Dryers Experts
