Question about Haier Dryers
How to hook up dryer vent - Haier Dryers
  • 433 Answers
One end goes to the dry exhuast one end goes to the outside, unless you have something new, whats it look like coming out the dryer?
Posted on Dec 31, 2012
Start up procedure
Check your vent duct, it may got clog inside there. Take off your vent duck from the rear of the dryer. Turn on the dryer again, if it is hot, your vent duct is the issue. Else, you need service man to take care of it.
Oct 07, 2013 | LG Dryers
Will not restart when dryer is hot
Have you checked your vent for blockage? If you have an expandable vent hooked up in back (plastic or foil) make sure it is not squished or collapsed. Also check inside the back of the dryer where the vents hooks up for lint build-up and the vent cap outside for blockage or stuck flap. Douglas
Jul 10, 2010 | Amana ALG331RAW Gas Dryer
I have a whirlpool tumble dryer awz3518, that has a flahing filter light on it, but the filter is clean and the dryer is still wont work
run the dryer with out the vent hose hooked up.if the dryer work's than you have a problem with the vent system.check your vent hose from the dryer to the outside vent.
Dec 22, 2009 | Whirlpool LER4634J Electric Dryer
My roper dryer will not dry all the clothes in one cycle.
try runing your dryer with out the vent hose.if your dryer wooks well than you have a problem from were the vent hose hooks up to your dryer and the outside vent.
Nov 17, 2009 | Roper REX4634KQ Electric Dryer
It takes 3hours to dry a load of clothes even thought it is getting hot.
before you move the dryer,look behind the dryer and see if the vent hose is pinched off.if it is not pinched off than try runing the dryer with out the vent hose hooked up.if the dryer drys well than you have a blockage somewere between were hooks up to your dryer and outside vent.
Nov 09, 2009 | Whirlpool LER4634J Electric Dryer
Dries very slow lint is clean have to run and run to dry
make sure the outlet tubes are also clean, also rinse off the lint screen with hot water, softener will clog it and not allow propper air flow, the water wil bead up on the screen if this is true, just keep rinsing till water flows freely
Whirlpool Dryer- Model #YLEQ5000PW0, does not get hot enough to dry clothes and makes a ckicking noice when the drum rotates. What do you think the problem is?
if you have any heat than your element is good,the reason it take's so long to dry the clothe's is due to a blockage,first you nead to look behind the dryer with out moving it to see if the vent hose is pinched off,next try running the dryer with out the vent hose hooked up,if it dry's well than you have a blockage some were between were the vent hose hook's up to the dryer and vent outside.you nead to check the roller's for the clicking noice.
Nov 05, 2009 | Whirlpool LER4634J Electric Dryer
How to hookup side exhaust vent on a Kenmore dryer?
Go to a hardware store and ask for a dryer hook-up kit. You can run the vent to an outside source through a wall or if needed you can exit the exhaust through a roof although I would not do this unless it was the last resort. Instructions for the dryer hook-up are included with the materials.
It consist of connecting a vent hose usually 4 inches to the dryer outlet and running the hose usually a flex hose to another outlet that vents the dryer air outside. The outside connection should have a door that closes when the dryer is not in use to keep rodents and pest out.
Jun 14, 2009 | Kenmore 700 6973 Dryer
Kenmoore dryer
hook it back up. you need to vent it out side.
Dec 16, 2007 | Kenmore 62602 Electric Dryer
Dryers Logo
60 people viewed this question
Top Haier Dryers Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Haier Dryer Expert? Answer questions, earn points and help others
