Microsoft Xbox 360 Console
Problem for Microsoft Xbox 360 Console
Error E 74
By galvin on Jun 24, 2007
ive had my xbox 360 for about a year and a half now and it has worked great until just a couple of weeks ago...when i turn my xbox on now all it shows is the bottom right ring light flashing red and E 74 appears on the screen. I looked it up and was told that it was a problem with the a/v cable, but i tried other a/v cables that belong to my friend and it still doesnt work. i figured that maybe that it was the a/v component inside the xbox i.e. the chip. i no longer have a warranty on my xbox so microsoft will not help. does anyone have any advice for me? is there a way i could acquire another chip and replace it? thanks for any help
Comments:
Dec 19, 2007
- I have fixed the problem
Jan 11, 2008
- I bought a new 360 and threw away my other one
Clarification Request
Posted by justinjhon on Jan 10, 2010
Try this link... http://bb04bdyba069tkcalgqign2f34.hop.clickbank.net/?tid=SOLVE
Sorry was forgot to place the link...Click here to solve the all xbox problems
I want to let you know everyone, if you are facing xbox problems and want to solve soon the xbox360 problems like 2red lights problem, 3red rings problem,E74 error,audio but no video, audio but no picture, 3flashing red ring problem, red ring of death problem, rrod, ring of death problem, Disc read error, One red light problem, freeing problem, then you should have to Click Here.
Posted by biFixYa on Aug 23, 2009
Enjoy the solution below
Posted by biFixYa on Aug 22, 2009
I have the solution....................................................................................................................................... Try this linke -> http://wisestart.chri5123.hop.clickbank.net/ ..............................................................................................................................................................................................................
Same Problem
May 17, 2009
-   no cash e 74
-   Guest
May 17, 2009
-   my xbox says e 74 i don't know how to fix it
-   shahrouz12
May 17, 2009
-   Same problem. 3 year warranty on new ones but looks like Microsoft support is bad (lost order, repeated send backs, etc) I might just fix myself modding the cooling and reapply thermopaste which worked for me on three rings. -   Guest
May 14, 2009
-   i am not willing to pay anymore money. m$ = cheap bastards friken setting up xboxes to blow up 1 day after the warrenty,BUILD SOMN THING THAT DOESENT BREAK -   Guest
May 02, 2009
-   Same as this guy with the E 74 error.
-   Guest
Best Solution
posted on Aug 26, 2008
Helpful)
R Dubs
Rank: Apprentice
Rating: 94%, 24 votes
call the tech support 1-800-4my-xbox. when you get to max just press 0 until you get connected to a person. then lie and tell them you got 3 rings of death not 1. once you do that they will give you the box to send it in the mail. they don't check the just swap yours out with one that was fixed....
-R Dubs
Was this helpful?
Yes
No
9 people thought this was helpful
Solution #2
posted on May 08, 2008
Helpful)
bousty
Rank: Apprentice
Rating: 90%, 26 votes
the towel trick is def only temp. i called xbox and they want 100$ to fix it. I am going to either threaten to call bbb ( better business burough) of actually file a report if they won't do anything about their faulty hardware. I think that everyone else should do the same.
Was this helpful?
Yes
No
15 people thought this was helpful
Solution #3
posted on Dec 27, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i got the same error, and what idid was i removed the hard drive, blew on it, and let it sit for a minute or 2. after this it worked fine
Solution #4
posted on Nov 14, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
take it to game station they swped mine without reciept
Solution #5
posted on Oct 31, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
1. do the damn towel trick.
this is a temp fix
2. go sell it to gamestop w/o HDD
3. GO back the next day and buy a new 360
 i had to do this cuz my xbox was stolen
Solution #6
posted on Sep 18, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Worked for me. Wrapped in towel for 5 minutes. Took it off and let it cool down. Error E74 gone (for now).
Solution #7
posted on Jun 25, 2007
Helpful)
ambrose313
Rank: Master
Rating: 76%, 237 votes
Okay, you can pay xbox about $150 and they will fix it. your xbox is overheating and it is happening to all of them. If you don't want to try that, I have heard of a solution some people, even a friend of mine has wrapped a towel around it and just left it on. It will counteract itself and reboot itself to normal and you will be able to play with it. when and if you fix it, unplug it when not in use and don't play marathon times with it.
Thanks
connie
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #8
posted on Mar 11, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i had error 74 .The only way you will fix it is by doing the x clamp fix ,then over heat the system by unpluging the fans until you get two red lights. My 360 has been work ever since.
Solution #9
posted on Jul 08, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
E74 is chip failure
Solution #10
posted on Nov 17, 2008
Helpful)
stinger626
Rank: Apprentice
Rating: 87%, 17 votes
okay the error e 74 is a problem with the heat sync not av cables or accessories. In order to fix it you need to take apart the xbox 360 and remove the flat silver heat sync, then take some thermal past and put it on the chip that connects to the heat sync then place the heat sync back on and boot up the system while applying pressure on the heat sync. the xbox should be working and all thats left is to put it back together. I did this to mine and its been working for over 6 months now.
Was this helpful?
Yes
No
12 people thought this was helpful
Solution #11
posted on Jul 13, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
just send it in
Solution #12
posted on Oct 20, 2007
Helpful)
awesome95
Rank: Apprentice
Rating: 86%, 12 votes
just for a reminder, the towel basically overheats the system, so there is a chance of your xbox 360 getting fried and becoming a boat anchor.
Was this helpful?
Yes
No
6 people thought this was helpful
Solution #13
posted on Jan 13, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
alright i am probaly not telling anyone anything new but just incase microsoft are a bunch of morons give them a call if u still have your warinty oh and DONT TRY THE TOWEL TRICK!!!! it can fry the xbox oh adn unless you are very familiar with electronics dont take it apart because xbox wont do a damn thing if u break the seal
Solution #14
posted on Oct 24, 2007
Helpful)
Tskull
Rank: Apprentice
Rating: 86%, 19 votes
I wrapped my 360 with a towel and left it for about 30 minutes. I let it cool down for 15 minutes then used a fan under the 360 for about 25 minutes and it worked fine. so no worries :)
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #15
posted on Jan 12, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i heard the towel thing is bad for the xbox.i tried everything swithcing the hdmi cables to av cables unplug and repluging everything but nothing worked.I got error e74 from having my xbox setting on 1080i for my LCD Tv. but when i brought it to a friends house plugged it in and i got error e74 from having my xbox at 1080i which his tv couldnt handle.so i had to go back to my house switch the settings to a lower setting capable for non hdtv's brought it back to his house and it worked.the second time i got the error e74 i didnt know how i got it so i called techsupport and they told me that error e74 is from either 3 things.1.the av or hdmi cables are not working correctly,the plug inside the xbox360 that the av or hdmi cables plug into is malfunctioning then ur xbox needs repairing(the worst of the three).and 3. The problem i had when error e74 was the HDD drive is malfunctioning,all you got to do is take out ur hard drive,turn it on and it should work.if it does turn it off put back in the Hard drive and if it works,ur good to go.but if it doesnt you need a new HDD and youll lose all ur game data.
Solution #16
posted on Aug 04, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
microsoft robbed everybody who brought a 360 because mine went in 6 months. I think everyone should get together a complain or even send your complains to a news station so they can warn everyone about the 360.
Solution #17
posted on Oct 23, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The first thing I did with the xbox I bought brand new was to take the entire thing apart and 'fix' the problems that microsoft so generously built into the systems.  If you are technically inclined, there is the 'xclamp' mod, and the '12v stock fan' mod.  These two together go a long way toward eliminating the issues caused by the massive heat generated inside the 360.  Of course, doing these things voids the microsoft warranty.  I would not suggest this action for the typical user.  I have 16 years of electronics hardware experience to work from.  So am comfortable with fixing the systems myself if anything goes wrong.
But yeah, microsoft really screwed up with the initial design of the 360.  Its really pitiful they released it with these obvious overheating problems.
Solution #18
posted on Oct 29, 2007
Somewhat Helpful)
hxnjg
Rank: Apprentice
Rating: 82%, 14 votes
Try fooling around with it till you get the 3 red lights. Then wrap it in a towel for half an hour than let it cool for 10 minuets. Or leave it off for several hours.
Was this helpful?
Yes
No
Solution #19
posted on Jun 27, 2007
Somewhat Helpful)
Daniel9
Rank: Guru
Rating: 87%, 316 votes
Try this solution it works for the 3 red light it might work in this case too. Just don't do it if you still have your warranty.
http://www.fixya.com/support/t142158-3_f...
Was this helpful?
Yes
No
Solution #20
posted on Jan 10, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
if anyone bought their xbox from gamestation like i did, they said to me you get an additional 2 years warranty. so if you have tired everything including towel trick, for e74 message, phone up xbox line if they say, your warranty is over just tell them you got it from game station, should be ok, then carry out everything else, get it repaired free, if you live in UK,UPS, (or some other business like that) comes to colllect it( not sure about USA). Usually takes about 2 weeks if not more, definetly not more than 5 weeks, altough not quite sure.
Solution #21
posted on Oct 15, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i have the same problem....towel wrap only works for so long.
i have found a petition and signed it..hopefully every1 does http://www.petitiononline.com/mod_perl/signed.cgi?360recal&251
Solution #22
posted on Jan 18, 2008
Somewhat Helpful)
batch27B
Rank: Apprentice
Rating: 82%, 17 votes
1. Turn off the console, disconnect all the cables, and then reconnect all the cables. Turn the console back on. 2. Turn off the console, and then disconnect any accessories that are connected. For example disconnect any Xbox 360 controllers, Xbox 360 Memory Units, and the Xbox 360 Hard Drive. With the accessories disconnected, restart the console to see whether the problem continues to occur. This can help determine whether the console or an accessory is experiencing the problem. - it is not the AV cables or even the port where we connect it, it is one of the hardware failure and if not able to solved this by following the troubleshooting steps provided then we just hoped that your console will have the extended warranty to send this console for repair. But most likely, most of us who'd experience this inconvinience, will have no option but to send the system to micrisoft
Was this helpful?
Yes
No
Solution #23
posted on Jul 23, 2007
Somewhat Helpful)
xetas
Rank: Wiz
Rating: 89%, 116 votes
The Warranty period for the 360 was extended to 3 years after your initial date of purchase. Call up Microsoft and send it back to them for just the cost of shipping.
Was this helpful?
Yes
No
Solution #24
posted on Jun 05, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
try firmly tapping the top of the xbox this worked once for me!
Solution #25
posted on Jul 15, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
my solution is to buy a playstation 3 xbox is a pile of pish
Solution #26
posted on Jun 26, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Bullshit i have the e74 error the only way to fix this is to replace the thermal paste on GPU and the spray the entire motherboard with shit to stop it from overheating and going brown. this is the only way i found to cure thsi problem and is a permanent fix to this problem. if this does not work for you then you have one more option which is to sit down ND FART ON THE MOTHERBOARD UNTIL IT OVERHEATS, THIS WILL MELT THE COLD SOLDER JOINTS BACK TOGETHER BUT WILL NOT FIX IT PERMANENTLY AS WHEN YOU PLAY THEY WILL HEAT UP AND MOVE APART.
THANKS
Solution #27
posted on Nov 26, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
obviosly the problem is heat inside the box if you warranty is up and you want a good cheap fix drill holes in the cover to leat the heat escape box. These things are like ovens and the heat has no where to go so it just gets hotter.
Solution #28
posted on Mar 24, 2009
Very Helpful)
coheikkila
Rank: Apprentice
Rating: 100%, 9 votes
My son x-box had the same problem. The heat grease condutor between the heat sink and the graphics chip had broken down to where it was not transfering the chip heat to the heat sink and causing it to overheat, warp the board and break the connection of the chip. We pressed down to resecure the graphic chip (as seen on you tube), striped the old layer of heat grease, cleaned the surface and applied some new grease I purchased from FRY's (local electronic store). The test last night went well and it was working today. I think we have fixed the issue.
Was this helpful?
Yes
No
Solution #29
posted on Nov 05, 2009
Helpful)
faglartron
Rank: Apprentice
Rating: 93%, 21 votes
In my opinion the best way to fix error 74 and all other errors associated with microsoft products is to go to your local Home Depot, purchase yourself a nice garden axe. Proceed to use the axe to open the plastic casing. Carefully cut open the metal case with Thermite taking care not to destroy the motherboard. Once the case is removed, place the xbox on a flat suface about knee hight. Proceed to defacate on the silicon components, wrap the whole thing in duct tape and give it a shake. Once you plug it back in, you find that while despite the smell, your xbox should function much more efficiently than before. Even if that means not working at all. Please tell your friends about this simple fix that microsoft has tried so hard to hide from us all. Thank you.
Was this helpful?
Yes
No
Solution #30
posted on Feb 18, 2009
Helpful)
xanon
Rank: Apprentice
Rating: 93%, 7 votes
I had the same problem. And the soloution was for me was as some others have said. The heatsink on the processor needs removed, cleaned of the old thermal paste, and reapply new thermal paste. There our a ton of videos on YouTube on opening your xbox, and also on the issue of what to do when you get it open. I found it wouldn't work untill I started the xbox without the heatsink on, so it would give me two red lights. That was the only way to "reset it" in a way. It had only been a week so far, but so far so good and no problems as of yet. I would not recommend the towell thing. That's like fixing a roof with bubble gum and duct tape.
Was this helpful?
Yes
No
Solution #31
posted on Feb 07, 2009
Helpful)
Adam611
Rank: Apprentice
Rating: 92%, 6 votes
Yeah this worked for me :)
Watch it to get ur xbox fixed in minutes
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #32
posted on Mar 25, 2009
Helpful)
lollilolli1
Rank: Apprentice
Rating: 88%, 13 votes
buy a playstation 3
Was this helpful?
Yes
No
7 people thought this was helpful
Solution #33
posted on Aug 28, 2009
Helpful)
all-guru
Rank: Wiz
Rating: 84%, 367 votes
The first way to fix this error is actually really quite simple, it may just be your AV cable. The first thing that you can try is to unplug the AV cable and blow out any dust that may be built up in the connections. Then try hooking it back up and turning it on.
If you are still facing the error than try getting a new AV cable, or you can borrow one from a friend so that you don't buy a new cable if this is not the solution either. Once you have the new AV cable, plug it in, fire up your Xbox 360 and if the error is still occurring then you will have to move on to the next method of fixing the E74 Error.
If the AV cable didn't work then you are going to have to move on to a little bit of a more complex method to fix the error. It can still be fixed but the methods can't be explained in a single article.
You can find Xbox 360 repair guides on the Internet that have very detailed instructions on how to fix the E74 error as well as other errors like freezing, the no video problem and the red ring of death. These guides usually come with very detailed step-by-step instructions. The better guides will also include pictures and videos of the process so you can be sure that you will understand each step of the repair.
Follow the below link to see video -
http://www.youtube.com/watch?v=3pQozsc0fiY
Good Luck!!
Thanks
Was this helpful?
Yes
No
Solution #34
posted on Jul 24, 2009
Helpful)
jonathon577
Rank: Apprentice
Rating: 88%, 2 votes
try to take the xbox 360 apart and figuer out a way to stop the fans.then leave the xbox 360 on.keep a constana eye on it and make sure to feel it to check when its hot.than turn it off,unblock the fans then turn it on and wala one fixed 360
Was this helpful?
Yes
No
Solution #35
Helpful)
08fix01
Rank: Apprentice
Rating: 88%, 10 votes
Try this trick!
Was this helpful?
Yes
No
Solution #36
posted on Jan 03, 2009
Helpful)
littletwerpy
Rank: Master
Rating: 80%, 9 votes
use this guy. he will tell eerything you need to fix the xbox. mine had the three rings and it works like a charm now http://www.youtube.com/watch?v=Bo2dl2vlwis
Was this helpful?
Yes
No
Solution #37
posted on Apr 04, 2009
Helpful)
JMEX
Rank: Apprentice
Rating: 83%, 3 votes
hey galvin
This issue is pretty easy to spot, since it is related to a heat issue on the motherboard of an 360. What i suggest is pretty much going to spoil the warrenty, so what u do is open the the xbox to reveal the board with the fancy silver heatsink, once the 360 is off. Remove the big silver heatsink and turn it on, so u should get more red lights. Then turn off the xbox again and put back the heatsink mentioned earlier back on and turn the 360 on. Voila, no more redlights. If this doesnt help, better to buy a another xbox 360 or even better a ps3 since ps3 dont have any issues besides the tv cable menu selection red screen issue.
Was this helpful?
Yes
No
Solution #38
posted on Feb 17, 2009
Helpful)
ldrury10
Rank: Master
Rating: 84%, 8 votes
try and get a new chip for the 360 and connect it to the 360
Was this helpful?
Yes
No
Solution #39
posted on Nov 09, 2008
Helpful)
StanXboxMan
Rank: Apprentice
Rating: 83%, 6 votes
The towel trick worked like a charm, but only for like 3 days at a time. Finally I just took the hard drive off the top and I gave it a couple of firm hits on the top with the bottom of my fist and it has been working for about 5 weeks now.
Was this helpful?
Yes
No
Solution #40
posted on Feb 22, 2009
Somewhat Helpful)
lololololol
Rank: Apprentice
Rating: 81%, 4 votes
first open it then once u see the bndages inside or if u dont have bandages then u should make 4 stacks of pennies 2 in each group then wrap it in the black parts were the badages were used to be or those black square spots on the x-clamp side then put it back together and then towl trick it then it works then it works for me it is now working for me about 1 month now=D
Was this helpful?
Yes
No
Solution #41
posted on Jan 07, 2009
Somewhat Helpful)
jgfjgfjgfjfj
Rank: Apprentice
Rating: 81%, 9 votes
2sed4344e34er4wr4134r`eq2 Flap yo weena on yo xbox and **** on it
Was this helpful?
Yes
No
Solution #42
posted on Jan 11, 2008
Somewhat Helpful)
C13295
Rank: Master  Microsoft Expert
Rating: 80%, 99 votes
Watch this video and it will teach you how to do the towel trick the other guy is talking about. You won't believe this at first, but it works.
Here is the link. http://youtube.com/watch?v=hjjinHmEoss&feature=related
Was this helpful?
Yes
No
Solution #43
posted on Sep 03, 2009
Somewhat Helpful)
arale
Rank: Master
Rating: 79%, 46 votes
Try this link . . . www.microsoft.com/Xbox360Console
To find your best solution.
Was this helpful?
Yes
No
Solution #44
posted on Aug 23, 2009
Somewhat Helpful)
biFixYa
Rank: Apprentice
Enjoy
Was this helpful?
Yes
No
Solution #45
posted on Jun 07, 2009
Somewhat Helpful)
cjmeno98
Rank: Master
Rating: 79%, 19 votes
No you can' t acquire another chip.It was made by Microsoft specifically for the Xbox 360.So Micro soft won't sale the chip they need it for future consoles.So buy a new one or send it for repairs.
Was this helpful?
Yes
No
Solution #46
posted on Apr 23, 2009
Somewhat Helpful)
youchy0
Rank: Apprentice
Rating: 75%, 2 votes
I found this site that solved my problem completlly:
http://www.xbox360-3redlightsfix.com/Xbox2/error-e74.html
Was this helpful?
Yes
No
Solution #47
posted on Mar 21, 2009
Somewhat Helpful)
matthewanker
Rank: Apprentice
Dude this is the deal microsoft will give you
If you have extended warranty on ur xbox they will fix it for nothing but if u dont have it well then if u decide to buy it will cost you like 140 bucks
Or
You can buy a new 360
I just got this like a day ago so yea it sucks I dont see why microsoft when producing the product they just make it so it does not have this problem
Was this helpful?
Yes
No
Solution #48
posted on Dec 26, 2008
Somewhat Helpful)
LFC Sauce
Rank: Apprentice
Rating: 77%, 5 votes
this happened to me on christmas day. i got a new xbox today basically if u have a reciept u say it broke before ur warranty had run out, they HAVE to believe you, and they will test it and they shud give u a new one.
I would make sure the place is quite busy because they will take u to one side and sort it out, plus they will not be thinking about it and they will give u and leave, i got 3 free months and i got to keep my hard drive.
I do NOT recommend one of these "fix it yourself" things because if they find you have messed with it no matter how long ur warranty is it will become void so u will have to buy a brand new xbox if it breaks!
Was this helpful?
Yes
No
Solution #49
Somewhat Helpful)
bogars
Rank: Apprentice
Rating: 75%, 3 votes
i had the same problem,i fixed by putting a shim on the anna chip the chip is situated in the left back side just being the chip with the heat sink on the left , i put the shim on the chip just thick an af to apply pressure whith the air duct on an putting back dvd player on , the idea is to put pressure on the chip it help if a solder is bad underneat , good luck you can see how to do it on you tube my console is working great since that fix
Was this helpful?
Yes
No
Solution #50
posted on Aug 30, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
alright quit witht the goddamn towel trick it breaks the consale even more water and electricty doesnt work just send it in or fix it your self
Solution #51
posted on Jun 21, 2009
Not Rated)
A4HTEC
Rank: Apprentice
Rating: 0%, 0 votes
IF YOU HAVE AN OLDER XBOX OR ANY XBOX THAT WON'T STAY FIXED EVEN AFTERE THE X-CLAMP FIX OR E74 THAT KEEPS COMING BACK AFTER A FEW DAYS. YOU CAN TRY THIS MOD THAT I DO FOR ALL MY CUSTOMERS AND IT SEEMS TO WORK. I HAVEN'T HAD ANYONE CALL BACK FOR MONTHS NOW AFTER THIS MOD.
BASICALLY, WHAT WE'RE TRYING TO DO IS MOUNT THE DVD ROM ON TOP OF THE CASE, DRILL SOME HOLES DIRECT NEAR THE POWER AND SATA PORT AND RUN THE CABLES ON TOP OF THE CASE. THE TRICK IS TO MAKE IT EASIER DRILLING THE HOLES BY REMOVING THE METAL PLATE ON THE TOP HALF OF THE CASE.
THIS IS NOT A FULL TUTORIAL SO YOU'RE OBVIOUSLY GONNA HAVE TO FIND OUT HOW TO SOLDER THE ADDED 80MM FAN TO A 12V SOURCE I DO IT FROM THE BOTTOM OF THE MAIN POWER PLUG. AND SCREW OR EVEN TAPE IT DIRECTLY ON TOP OF THE GPU HEATSINK PUSHING AIR DOWN TOWARD IT.
THIS IS WHAT THIS MOD IS ABOUT IT MAKES ROOM FOR THIS FAN BY MOVING THE DVD OUTSIDE OF THE CASE AND THIS FAN KEEPS THE GPU FROM OVERHEATING AND CAUSING THE e74 OR 3 RED LIGHTS
FOR THE EJECT BUTTON YOU CAN JUST POSITION IT IN THE SAME SPOT AND ZIP TIE IT TO THE BOTTOM PIECE OF THE CASE IT WILL STILL WORK THE SAME.
also becareful when your are screwing the top of the case with the long screws cuz without the metal plate you have to know when to stop screwing it in cuz it will cause the top piece to bend out of shape and you won't be able to align the eject button or even snap the 2 pieces of the case back together. I usually just use 3 of the 6 long screws and do one on each back corner and one on the front middle then use the 3 extra screws to bolt down the dvd rom into the holes that are already there on the top piece of the case you will have to drill a hole for the last screw. This will keep the dvd rom securely in place and would recommend you buying a longer sata cable cuz the original one is not long enough. Also pull the sata cable all outside and tuck it under the rom. Better for the air flow and won't get caught up in the fan.
THIS MOD IS TeSTeD AND IT WORKS GREAT CUZ MY HALO EDITION 360 HAD THE E74 AND EVERYTIME I REVIVE IT, IT WOULD COME BACK IN LIKE A DAY, THEN I THOUGHT OF THIS MOD AND SO FAR ITS BEEN 3 MONTHS AND ITS STILL RUNNING LIKE A CHAMP QUIET TOO ALMOST SILENT CUZ TEMP SENSORS DON'T JUICE UP THE VOLTAGE ON THE 2 BACK FANS CUZ OF THE HEAT. AND I ADDED SOME DIFFERENT COLOUR LEDS INSIDE AND IT ACTUALLY LOOKS PRETTY GOOD
HERE IS A LINK IF YOU WANT TO SEE SOME PICTURES
http://360mods.net/index.php?name=Forums&file=viewtopic&t=17296
Was this helpful?
Yes
No
Solution #52
posted on May 25, 2009
Not Rated)
beancaller
Rank: Apprentice
Rating: 0%, 0 votes
Just open the stupid thing up and get the 3 red light repair kit but only use one set of the screws and one set of washers and fix the xclamp over the GPU. Ive done it many times and allll my xboxs work fine now.
Was this helpful?
Yes
No
Solution #53
posted on Sep 16, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
All these posts and some many confused folks.
E 74 is not covered by the warranty that Microsoft extended to 3 years. They want $100 to fix E74. Why pay that when you can fix it for 12 cents?
Seriously, if you have the E 74 error and know how to take a part a computer (same as 360 basically)
Follow the page listed above to a "T" and your problem will be solved.
http://fastercomp.co.uk/error_e74_fix.html
not sure how long this lasts, but it works
Solution #54
posted on Aug 28, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
All you should do when talking to xbox support, is say that you have the 3 RROD. If you tell them this you will get your xbox repaired for free, seeing as it has a 3 year waranty on the RROD. Also when it is getting repaired they have no evidence of the console not actually having the RROD because sometimes it can come and go.
Solution #55
posted on Aug 08, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
E74 is a graphics error. Usually is due to some small chips (scaller chips I think is how you spell it) in the rear of the motherboard. Xbox tells you its the A/V cable, which is possible thta it causes this error, but is about as likely as a PS3 messing up. You have about a 20% chance of the x-clamp eliminating this problem cause it could be the GPU, but like mentioned before, its usually the smaller chipset. USUALLY, the xclamp mod only fixes the RROD fault anyway.
Solution #56
posted on Aug 02, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
clean the Heat Sink and GPU and replace the thermal gel. Then remove silver fan turn on xbox and turn off. if it doesnt turn off then unplug and plug back in. Then put fan back on apply little bit of pressure and turn on hold down fan untill xbox is working again.
Solution #57
posted on Jul 21, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
okay, E74 is a GPU problem, and i do believe that it has something to do with a chip failure or something.
I have heard that it falls out of a socket or something, so yeah.
Either look it up or send it in.
Solution #58
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
error e74 is the scaler chips!
Solution #59
posted on Jul 12, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
e74 is the av cable i think...
Solution #60
posted on Jul 02, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
E74 is an AV cable error!
Solution #61
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Don't do the towel trick.
Microsoft are now refurbing the Xnox 360 that you send in so it will only lead to more damage if you have to send it in.
Solution #62
posted on May 03, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
if your warrenty is expired or your to cheap to send it in to xbox u can dissasemble your xbox remove to heat sink clean the gpu with alchol and reapply new thermal gel such as silver 5 reput on the heat sink and it should fix it permantly u may have to over heat it after u do this, but then it should be good to go. did it to mine
Solution #63
posted on Mar 16, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
if youve had it for only a year n a half u should still have the warranty from Microsoft even if u didnt purchase a warranty
Solution #64
posted on Jan 17, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
here y are u all sayin e74 is heat?? its a problem with the av cables or the av chip.. NOT HEAT i hav a coolin fan on my xbox nd i still got the e74 error
Solution #65
posted on Jan 01, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
all you have to do is let it sit for a day or two unplugged and then plug it back in adn try. if it still says E 74, then turn it off and on and keep doing this like 15-20 times. i did it like 17 or 18 times and it works. Note, there is a risk permanatly damaging your motherboard doing this.
Popular Solutions for Microsoft Xbox 360 Console
Questions and Unsolved Problems for Microsoft Xbox 360 Console
Do you recommend Microsoft Xbox 360 Console?
Answer
Answer
what is wrong with the xbox 360 when the red light comes on, and it want come on.
Answer
I cant play bfbc 2 in xbox 360.WHY?i already puted mi email and pasword and it says that i... (More)
Answer
hi my xbox wont read any of my game's but yet my games work on other peoples and then it starts to... (More)
Answer
locks up and has three red flashing lights where the controler lights are.
Answer
why don,t my hdtv setting hightlight so i can set it my xbox won,t work on hdmi cable
160 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Apr 26, 2009
I've had my xbox 360 for almost 1 year and a half. Ive never had a problem with it before but recently I turned on my xbox and it had one red light on the bottom right hand corner.When I look at my screen it says "system error. Contact xbox customer support." In many different languages. It also says in big letters E74. So I went to xbox.com to see how to fix this problem. I did everything at least 3 times, it still won't work... What should I do to fix this problem?
Comment by Guest, posted on Apr 16, 2009
four months old and quit working now showing E74 error cant get any help or find out where to get the damn thing fixed at $459.00 thats pretty steep to play a gammer. want it fixed or money back !
Comment by mrob1conobe, posted on Apr 16, 2009
i have the same problem but my xbox360 is the elite version and only 14mths old and was told that it would cost between £74 to £98 i have been told that it is one of the most comman problems with the console
Comment by Guest, posted on Apr 05, 2009
something as galvin
Comment by Guest, posted on Mar 31, 2009
Well my XBOX 360 crapped out on me yesterday night after playing for about 2 hours, so I'm thinking that its a progressive problem that will manifest itself with aa e74 eventually.
Tonight I'll try and fix it myself rather than send it to M$ because I broke my warranty modding my system to play burned games.
Comment by vivianwhaley, posted on Mar 30, 2009
Ive been having the same problem the ring of death (the red ring) will not go away
Comment by Guest, posted on Mar 29, 2009
I have the same problem. Microsoft keep producing piece of **** machines.
error 74 syetem error
Comment by sgtcazz, posted on Mar 27, 2009
Happened to me twice in the past 2 months. Luckily, I have an extended warranty. Seems all the repair company did was clean it and reset something (VGA or something like that). Does it happen to you only when you play a certain game? I was told that this Error Code was a hardware failure but it ONLY happens when my kids are playing HALO3. Maybe a worn/corrupt disk is causing it. My kids play that game constantly.
Comment by killthestupi, posted on Mar 26, 2009
I have the same problem, my bro gave me his old xbox (1.5 - 2.0 years old, he got an elite) and 2 weeks later I got it on that one....microsoft said it is probably a hardware issue...I tried the stuff they said to no avail, and it appears that this is not covered under the 3 year warranty but is very common...I might have to switch to ps3
Comment by astauf, posted on Mar 25, 2009
ugh E74. Torn between the towel trick and buying an old 360 if it breaks, spending the $110 for a fix, or going with a new PS3. At least then Id have a bluray
Comment by Guest, posted on Mar 25, 2009
One day with my mates turned on the 360 to find E 74 no idea what to do I tried the towel trick. Did not work. Turned 360 off for an hour. Not working. I was trying as much as I could but in the end I gave up. Can you help solve the problem?
Comment by Guest, posted on Mar 23, 2009
Well basically you know when your gonna get the E 74 error cause when I was playing my screen turned to a rainbow color i turned it off for awhile turned it back and wam! there was the E 74 error
Comment by colesspace, posted on Mar 22, 2009
my xbox 360 worked fine for 2 years. one day i turned it on and it had 3 red lights and said error 74 and i dont no what to do.
Comment by betterhealth, posted on Mar 17, 2009
E 74 error and 1 red light only happens when av cord plugged in
Comment by axis_service, posted on Mar 15, 2009
i have same problem with xbox one red light and e74 on tv what can i do
Comment by fahimhhu, posted on Mar 15, 2009
One morning i was playing my xbox and then i went to the mall and i bought Endwars. When i came home i pop it in and i got the red light. Any adivce ?!
Comment by tara17, posted on Mar 12, 2009
turn on my xbox360 and error e74 pops up
Comment by Guest, posted on Mar 11, 2009
error 74 what do i do
Comment by navycpo7, posted on Mar 08, 2009
need to know if there is a simple FREE fix for this,
Comment by Guest, posted on Mar 05, 2009
exact same scenerio
Comment by Guest, posted on Mar 04, 2009
Same problem as yours. I still had mine in warrenty so i sent to microsoft............ so yea hope you can fix it.
Comment by Guest, posted on Mar 03, 2009
Microsoft provides a warranty for the 3 red rings of death...but not for the e74 error...there is something wrong with that
I Have that too
I have the E74 Error
Comment by DreadOrestes, posted on Mar 02, 2009
Well, i bought the solution. Followed every step and my Xbox worked for 50 seconds and de E-74 returned. Now, if I repeat the steps nothing happens, E74 is still there. Only thing left to test is the one involving the thermal gun... frankly, i'm starting to believe is not worth the time.
Comment by Guest, posted on Mar 01, 2009
same problrem here
Comment by Guest, posted on Feb 27, 2009
the samething
My xbox 360 has been working for just over a year now. but a few weeks ago i turned on my console and there was a red light flashing at the bottom right...
Comment by Guest, posted on Feb 24, 2009
I opened the 360 and put coins on the ANA chip and did the towl trick and it still dosent work
Comment by Guest, posted on Feb 22, 2009
Its stupid my screen had lines randomly going through the middle of it we thought the tv was screwed up. Well we figured out it was the xbox I dont know if i should do the towel trick,but my warrinty hasnt expired so should turn it in or keep doing the towel trick. Any advice?
Comment by PorkFish, posted on Feb 19, 2009
I have the E74 msg two of my xbox elites ($1000 purchase price and 300 to repair). If i buy a new one, it will just happen again. Hmmm... you guys keep shopping with shady microsoft, I think i'll give my money to someone else(SONY).
Comment by ntpatlanta, posted on Feb 19, 2009
I have one red light flashing and an error message saying e73
Please advise
Comment by donnaduckie, posted on Feb 18, 2009
I have an xbox 360 elite and it has the same probleme as yours.On the bottom right hand corner of the circle of light it flashes red-1 time and has error 74 on it.Help
Comment by Guest, posted on Feb 17, 2009
hey i have the same porblem and was wondering do you know it was the chip inside cause i dont really want to buy a new one and want to get a new 360.
Comment by nymetfan247, posted on Feb 16, 2009
i have the same problem.  i have no idea how to fix it.
Comment by pssnell, posted on Feb 10, 2009
Yes got the E 74 system error too. Cause, same as the rrod overheating due to the poor design of the console.
Comment by Guest, posted on Feb 10, 2009
I have the same problem when i turn my xbox on it comes up 1 red ring and error 74 on the screen. I know what is wrong with it and where in the xbox it is, the only trouble im having is getting the heat sync off thats over it if i knew how to do that i could repar it.
Comment by cl_sanderson, posted on Feb 09, 2009
I purchased my Xbox 360 sometime 9/2007. By July 2008 I had already received the "ring of death" and Microsoft replaced my Xbox. I now have the error of E74 but my warranty ran out in 9/08. Please tell me how this is... I received a BRAND NEW console from Microsoft what... 7 months ago, and now it's going to cost at least $100.00 to fix it? Are you kidding me. Then I was told that they extended the warranty an additional 90 days past the original date, because of the replacement. Obviously Microsoft doesn't stand behind their own merchandise. Especially because what I read is that this E74 error is becoming almost as common as the "ring of death". I'd rather buy a Wii or PS3 which from what I hear are much better anyway! This is really poor business.
Comment by Guest, posted on Feb 08, 2009
i have the exact same problem man and my warranty just expired please tell me if you find a solution thanks
Comment by auzzyh11, posted on Feb 07, 2009
my xbox has red ring botom right and says e74
Comment by Guest, posted on Feb 07, 2009
e 74
Comment by Guest, posted on Feb 04, 2009
i have the same problem with my xbox 360 elite e-74. could use any ideas thanks blinhart
I have the same problem and i dont think thats away to fix it
Comment by Guest, posted on Feb 03, 2009
error E74 appears on my 360 Xbox.
I have the same exat problom,when i try it on my friends tv it works,when i play it on my tv all it brings up that red light flashing on the right hand corner i think the problom is the wire just out off curiausity
Comment by Nana Army, posted on Feb 03, 2009
I also have E 74 with one red light flashing on the console tv. I tried another av wire from another xbox 360 and still receiving this message. My grandson had this machine for a year and a half. His sister unplugged his game because of bad grades and when I replug the wires, I received the E 74 message. Could the problem start because it was unplugged for 2 weeks?
Comment by Guest, posted on Feb 01, 2009
i went to the webiste xbox.com/support and my warranty ran out and i have to pay 94 dollars. but I think its messed how everyone cant have a lifetime warranty. I dont know what to do either except to pay for the repairs.
Comment by Guest, posted on Jan 27, 2009
I also have this problem. The Xbox flashes one red light and the E74 message appears on the screen.
Comment by Greedkid, posted on Jan 23, 2009
hey i have the same problem as the the other guy. i have the bottom right of the ring is flashing red with E74 on the screen. my warranty is up and would cost 94 dollars to fix from microsoft. does anyone know of any things of how i could fix it?
i dont want the towel trick or anything that will screw me up down the road
thanks
Comment by Guest, posted on Jan 13, 2009
e-74 is my problem warranty just ran out and this really stinks
Comment by Guest, posted on Jan 11, 2009
same problem
Comment by Guest, posted on Jan 10, 2009
hit the hd, geez caveman stuff
Comment by chloe_babb, posted on Jan 08, 2009
i have 1red in rightside at bottom and e74on screen
Comment by Guest, posted on Jan 06, 2009
E74 Error
Comment by ccollinz, posted on Jan 04, 2009
e 74 error
Comment by Guest, posted on Dec 31, 2008
i have the same probblem it suks. but i am taking it back.
Comment by Guest, posted on Dec 30, 2008
send it in and pay 100 bucks all i can tell ya or try the neet tricks over youtube
Comment by bogars, posted on Dec 24, 2008
i have error 74 problem it happens only when i use the dvd drive if i use a game with the memory card it works ok if i use the dvd drive it happens again after a few minutes is it possible that the dvd drive is defect may i change the drive or just the optical system thank you
Comment by kevin95, posted on Dec 24, 2008
yesturday i   i was playing my xbox 350 and i was playin for about 7 hours   then i turned it off the next morning like around 12 sumthing i  tured my 360 on its said system eroor contact microsoft  customer support i  did  contact them but i found out my warenty expired 1 month ago   microsdt said i need 100.oo bucks to get it fixed . pleaee if there any sloutions to my probalem let me know and i will be very great full
Comment by Guest, posted on Dec 22, 2008
E74
Comment by Guest, posted on Dec 18, 2008
same problem only xbox wants 110 bucks to fix it
Comment by HANSENbros, posted on Dec 17, 2008
i have the sam eproblem with the one flashing red light i took out my av cables abd it worked fine there was no light but as soon as i plugged it back in the light came back and the message popped up. I also noticed that a few days ago before this problem started my games were gettin all fuzzy and blurry halo 3 and forza motorsport 2 were the worst. any solutions??
Comment by Guest, posted on Dec 17, 2008
i have the same problem with the av cables i took my cables out and it worked fine there was no flashing light but as soon as i put my cables back in it came back up again and i also have no warrenty left on mine ne solutions?
Comment by Guest, posted on Dec 15, 2008
please help i need my game
Comment by yanceymi, posted on Dec 14, 2008
Have E 74 error code,but Microsoft will not repair and the system is only 1 yeaqr old. They said that I have to have three flashing lights instead of one. Help
Comment by Michela69694, posted on Dec 14, 2008
i have the same problem i dont know what to do
Comment by Guest, posted on Dec 13, 2008
well when i turn it on my xbox 360  is fine but can only hear it i cant see the picture do you have any solutions?? i bought a brand new a/v chord but i still does the same i even tried it on a different t.v. any solutions?
my 360 worked for about a year and a half as well and the e 74 thing happend as well what the heck do i do!!!!
Comment by bummdout, posted on Dec 10, 2008
one red blinking light ,error code E74
Comment by dante1579, posted on Dec 09, 2008
my xbox 360 has one red light and the screen says E74 i dunno why maybe because my room is to hot i dont play to much i wasnt even playing when that happened and its been 5 days since that ocurred.thank so much
Comment by Guest, posted on Dec 05, 2008
what a pain.....16 months old.....not one scratch
Comment by Guest, posted on Dec 04, 2008
dont worry send it microsoft but be preperd to wait a good we wile or you can find out how to fix it your self but itl take a wile evil microsofd
Comment by Michelleb12, posted on Dec 03, 2008
I found that the towel method did work but was temporary...I got a good recommendation from this guy how to fix it permanently..
http://howtofixyourxbox.blogspot.com
Comment by kalum77, posted on Dec 01, 2008
i have the same problem error 74 code on the screen with lower right quadrant red.xbox 360 is also 18 months old.
Comment by Guest, posted on Dec 01, 2008
i need to fix e74 now and fast
Comment by IVIunKey, posted on Nov 28, 2008
I have the e74 trick, but sometimes my xbox will start up, but the graphics are messed up, it looks sort of like matrix lines every where. Does the towel trick work on this error?
Comment by Guest, posted on Nov 27, 2008
e74...........1redlight........no guaranted help help help!!!!!
Comment by Guest, posted on Nov 26, 2008
i was playing the xbox last night and then i come home from work and i go to play it that when the problem started 1 red light comes on and says e 74 at the bottom of the screen
im startin to think xbox360 is for niggers
Comment by Guest, posted on Nov 22, 2008
I have the same problem! but unlike most people, mine didn't happen when i was playing, i just turned it on and it showed one red ring, i thought it was the red rings of death, but when i looked at it closer i saw it was only one red ring, I don't want to spend $100 on sending it back to microsoft and get it fixed, WHAT DO I DO?
Comment by Guest, posted on Nov 18, 2008
Man, i have the same problem and i've heard to unplug everything, I MEAN EVERYTHING, and leave it for about an hour. I 've tried it, did'nt work for me but it might work for you
Comment by blinhart, posted on Nov 18, 2008
bottom right red light flashing
Comment by killer50, posted on Nov 17, 2008
I got two rows of white lines covering top half of the screen for 2 days. On third day there was on red rind and an error message in several languages. On the bottom it read E 74. I was no longer able to see anything but the black screen with the error code.
Comment by Mustang302Co, posted on Nov 08, 2008
My Elite just started doing the same thing.
Comment by Guest, posted on Nov 08, 2008
yup same one.....Im gonna tell them incompetent bastards that its the rrod.
Comment by jonathonlamb, posted on Nov 07, 2008
Comment by Guest, posted on Oct 26, 2008
the same as the other gur. CHUCK NORRIS HELPPPPP
Comment by Guest, posted on Oct 25, 2008
I just got it on my 6 monts old Elite version
Comment by Guest, posted on Oct 24, 2008
ok, i have th wesame problem. i read all this solutions people posted and none of it worked. if you have the xbox laying down stand it up. Unplug everything thats connected to it then plug it back in even your live cable. then tap i a few times and turn it on. works like new.
its retarted. all i want is to play. and i dont wanna take my console apart. and i dont wanna wait three weeks for microsoft to fix it.
Comment by bobcat103, posted on Oct 20, 2008
Same story here.
My thing is, where does Microsoft get off charging me $100 to fix my system?
They tell me they're throwing in a month of Live, extending my warranty and promising me a new system if they can't fix my old one.
Why not just fix the one I have and stand behind the XBox 360 product?
Basically, is XBox holding me responsible for my system overheating? Is that how they figure they have the right to charge me?
Comment by Guest, posted on Oct 19, 2008
Xbox 360 Console 1 red light bottom right quadrant flashing - Error code E 74
Comment by Guest, posted on Oct 17, 2008
LAME. Just happened.
dude this just happened to me it sucks
Comment by Guest, posted on Oct 16, 2008
I just turned it off and back on and it works again.
That's usually all it takes to correct the problem.
Comment by D3waal3nator, posted on Oct 16, 2008
I have the same issue
Comment by benhead, posted on Oct 15, 2008
e74 help
e74??????????? help me
Comment by Guest, posted on Oct 12, 2008
i have got one red light, error E 74.
Comment by kupal11, posted on Oct 12, 2008
i have my xbox one red light and error 74
Comment by chrisangel, posted on Sep 30, 2008
my xbox360 only haves 8 months with me and that same error happened.
I really dont know why.
Comment by Guest, posted on Sep 29, 2008
did ne1s xbox sound like it was overheating b4 it happened
Comment by Guest, posted on Sep 27, 2008
is there no way to fix it? ,should i just buy a new 1
Comment by Guest, posted on Sep 25, 2008
same
Comment by Guest, posted on Sep 19, 2008
I have the same problem can anyone help
Comment by Guest, posted on Sep 14, 2008
one red light
Comment by joan50, posted on Sep 14, 2008
yes i have E74 error code tryed all still E74.
need HELP..........
Comment by Guest, posted on Sep 10, 2008
yea i got this while i was too and my warranty is over so i need help!!!
Comment by Guest, posted on Sep 07, 2008
Well I did, then I visted here:
I've been messin with the 360 for the last 6hours, trying allsorts, replacing the thermal compund, seriously breaking bits of plastic... anyways found this site - followed the instructions and seriously I need to buy the author a pint.
Would suggest you don't try the hairdryer for the suggested 2mins though...got worried at around 45seconds after which I turned on the console and problem solved, but fans went into overdrive...so left it to settle (5 mins or so) and to be pleasent surprise it worked. Fingers crossed it stays like this!
Comment by spenwack88, posted on Aug 27, 2008
xbox customer support wont help so help!!!!!!!!
Comment by Guest, posted on Aug 13, 2008
E-74 error and 1 red lights
Comment by Adam611, posted on Aug 10, 2008
i have the same problem :( and my warranty has expired - i just dont no what to do....
Comment by KungFounded, posted on Aug 01, 2008
ok so i got an xbox 360 elit and it got the error 74 1 right hand side red light and it happened in 6 months i am really pissed because know i can't play for the summer and i had the idea of not playing when school starts. So now i am gonna play at the week ends. Why can't Microsoft fix it faster or make it so it doesn't break like the ps3. plz any one got any way of fixing this problem with out opening it cuse Microsoft wont take it back tell me.
Comment by donatz45, posted on Jul 29, 2008
360 1 red light bottom right e74
Comment by Guest, posted on Jul 28, 2008
e74
Comment by Guest, posted on Jul 26, 2008
errror E74 but mine is under warrenty and microsoft will fix it.
Comment by Guest, posted on Jul 23, 2008
the exact problem is now happening to my consule!!!! This sucks!!
Comment by Guest, posted on Jul 20, 2008
Comment by smaximo, posted on Jul 19, 2008
e 74 problem,
I tried removing harddrive turning it back on does not work
towel trick
Comment by Guest, posted on Jul 11, 2008
My xbox has one flashing red light on the bottom right saying error 74. how do i fix it my warranty has gone?
Comment by busgeek79, posted on Jun 30, 2008
I have a solution that worked for me.. Unplug the av cord on the xbox and power up the unit.. When I did this the ring did not turn red.. Let the unit run and it will shut itself down after no use.. Plug the av cord in and power up and hope fully it will work for you..
Comment by Guest, posted on Jun 24, 2008
still can't figure out a way to fix it.
Comment by Guest, posted on Jun 07, 2008
i have taken the plastic of but i still need to take of the scrus from the mettal box
Comment by Guest, posted on Jun 04, 2008
This should help, but you have to open up your 360 to fix it permanentaly.
Comment by Guest, posted on May 23, 2008
Yea I got my 360 in spring of 2006 and every time I start it up it doesn't show any picture on the screen its hooked up to. But if when i turn it off and boot it up a second time it always works. Every once in a while ill get the E 74 error message but i ignor it because its been two years and nothing eles has happened. But i noticed that Microsoft exteneded warranties and that they are using a new motherboard in the 360 so i might turn send them mine for a new one. The only problem is that I have a launch edition Premmium and it has the matt silver hardrive and I am afraid that if they send me a new one the top will be flat gray and not match my hard drive. Does anyone know if they will match the top for a launch edition?
Comment by jals, posted on May 11, 2008
I called microsoft and i have to pay 65 pounds to get it fixed and if they can't fix it you will get a new xbox. It's stupid and microsoft are a big let down. i can't believe a billion pound organisation can't give its loyal customers a decent console that will last. its cheap and it has way to many problems. if the gameplay wasn't so good i would get a ps3.
Comment by roughguy, posted on May 03, 2008
My xbox gave me The E74 erro with one red light
Comment by mca0824, posted on Apr 30, 2008
bottom right red light flashing, e74 on the screan. This sucks. I will find a repair fot this. If you have one with this or other red ring lights dont throw it away, send it to me. Or I will buy it from you if you have paypal. Email me, I would feel better trying to fix one if I had more with the same problem. I am sure I will mess up the first few times so sell me yours and buy a new one. Good luck and may the red ring stay away from us all.
Comment by Guest, posted on Apr 25, 2008
same problem when i turn it on the bottom right hand corner ring is flashing if anyone can help it will be apreciated
i got the prob and now gta 4 about to be out
Comment by p-squared, posted on Apr 23, 2008
i have the same problem it sucks
Comment by fishslap12, posted on Apr 21, 2008
i had my 360 for a year now and now it won't work at all it turns on for 5 secs then it turns red
Comment by Guest, posted on Apr 21, 2008
My problem is just the same. And i dont know what to do
Comment by WetJumper, posted on Mar 24, 2008
I have the e74 message and 1 red light. The 3 red lights is covered by warranty but the microsoft charges $100 for a repair of the 1 red light. My question is about whether or not there is a way to trigger a 3 red light erro?. Maybe if I over heat it or simething to get the warranty. Also do you think it is feasibe to buy a new console from a retailer and then switching the consoles out and returning the faulty one?
Comment by Guest, posted on Mar 23, 2008
e74
Comment by Guest, posted on Mar 20, 2008
brilliant
Comment by Guest, posted on Mar 12, 2008
thank you
Comment by minime115, posted on Jan 24, 2008
My 360 crashed and died a couple weeks ago and what happened is that the 4th quadrant turns red and flashes while the screen says E 74. Whhee, I want it to be fixed but I dont want to send it to Microsoft.
Comment by MXGREG417, posted on Jan 10, 2008
HEY MINE DID THE SAME THING HOW DID YOU FIX THE PROBLEM? THANKS MXGREG417@YAHOO.COM
Comment by Guest, posted on Jan 10, 2008
You posted that you fixed the problem with the error 74. HOW? I am in Afghanistan and the only break I get is playing my xbox. So if you can tell us how you fixed it!
Thanks
Comment by Guest, posted on Jan 07, 2008
error 74
Comment by pemberton22, posted on Jan 03, 2008
how do you fix it
Comment by Guest, posted on Dec 31, 2007
got COD4 for xmas, put it in, played first level, then screen did a green blur like a bad nightvision
rebooted console and got E74
i don't know how it could be a heating problem because my box was on for only a half hour and i have a cooling fan in the back
i've had my xbox on for 8 hours straight with no problems
Comment by Guest, posted on Dec 30, 2007
Same problem nothing fixes it Microsoft wants 150 or more to fix and im not doin the towel thing.
Comment by guchie, posted on Dec 27, 2007
same thing here guys it really pissed me off
Comment by Guest, posted on Dec 26, 2007
i just got i today, i was having some problems with the graphics on COD4 , i went to restart the the console and ther it was. i checked the power supply and i have left it to cool down cause it was quite hot. i will try the a/v cables and described. that might be the problem. fingers crossed
Comment by skibum8, posted on Dec 26, 2007
Galvin, how did you fix it? Like yours, my Xbox 360 is a year and a half old. I had recently started seeing blue vertical lines on the entire screen and now all I see when I start the machine is a a E74 system error with the bottom-right circle flashing.
Comment by fbhsportsmom, posted on Dec 25, 2007
Got E 74 error after trying new game chair and new game Call of Duty 4 for about 15 minutes. Also had downloaded heroic maps a couple of weeks ago. Have tried unplugging all cables, removing hard drive, letting it cool down and nothing works. Please help.
Comment by FixMy360, posted on Dec 25, 2007
I Popped in a brand new copy of Mass Effect i got for christmas, and in under 10 minutes of gameplay...There it was, a Red light on the lower right corner and The E-74 Error. I called the Microsoft customer service, only to be connected to a half-wit who can't speak a lick of english. I found out that my warranty expired 2 days ago and that I would have to pay for the repairs, all because my console has one red light instead of the classic 3.
Gamers, can you feel my Frustration? I guess i will try the Towel thing :'(
Comment by Guest, posted on Dec 16, 2007
got the e74 message on the 13'th after i dl'd heroic
Comment by Guest, posted on Dec 14, 2007
erorr 74 same as galvins
Comment by Guest, posted on Dec 12, 2007
this problem came after i got the heroic map pack, never before. is it the download and if it is, will there be a update? at first i deleted the maps and it worked normal but, then when i got the maps again it just started all over.
Comment by Guest, posted on Nov 26, 2007
E 74
Describe your Video Game Consoles problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
