Amazing Boot problem !!
I have a problem with a driver 2 startup..
Sometimes it boots properly and sometimes : "After booting the monitor dos'nt display the desktop.. instead it looses display..'
When i repair my installation using the 2000 fast repair.. it repairs some driver that loads @ d startup and i am able to boot into 2000.
this problem occured with WindowsXp also but since there was no option to fast repair the boot ..XP always started the entire setup again... repeated setups also do not solve the problem....so i tried to test using windows 2000 professional...
I have come to know that somhow .... a boot fie gets corrupted .. (!!!) so that i have to fix it at every boot....
now tell me how this will fix up.. 1. my graphics driver is not corrupt since after fixing install it works fine........2. RAM is not faulty....ihave tested it...3. I have a P3 800Mhz 256MB RAM 82810E board..
  • 2 more comments
  • sutsav Jan 18, 2009
    its not a loose connection as well guys.... common u can solve it.. ur d pro guys!!
  • sutsav Jan 21, 2009
    i do not have a separate graphics card ..
    its onboard VGA ..
  • Wiard Giezen
    Wiard Giezen May 11, 2010
    do you have a sepparate graphics card in your system or do you have it onboard?
    do you have a brand a serial nr. for both mainboard and graphics card, or maybe just computer brand and model...
  • Dick
    Dick May 11, 2010
    "common u can solve it.. ur d pro guys!!"
    There are many, many drivers in a computer system. Without detailed information about your system and which drivers you have no one can solve this problem.
  • 131 Answers
Stick another card , agp pci or whatever you can get easiest in a slot . if it works....hmm bad onboard video. if not could be mb , motherboard , over heating or cpu. are fans spinning full speed ? reboot then go into bios, usually del key. and check motherboard temp. after failure.
Posted on Mar 05, 2009
Boot manager is missing HP pavilion dv6 notebook windows 7
This sounds like a common issue. The boot manager file "NTLDR" Can become corrupt or go missing due to a few situations.
1) Shut down improperly
2) Virus
3) Bad hard disk
4) Windows being windows.
Too fix this simply use a windows 7 cd and boot from it.
Choose the Repair option and let it do its thing. If i recall there's also a repair startup option you can use aswell.
Windows repair usually fixes the problem but if that doesnt work you can also put the hard disk into another computer and copy over replacement boot loader files.
  • ntldr, the main boot loader itself
  • NTDETECT.COM, required for booting an NT-based OS, detects basic hardware information needed for successful boot
    Try that. The windows repair usually works but if you have to use the alternative and it doesnt work it could be your MBR. Windows repair also fixes this but theres an old command you can run from the dos shell of the cdrom "mbrfix or fixmbr" That will take care of it.
    Good Luck :)
    Jun 08, 2014 | HP Pavilion dv9000z Notebook
    My computer fails to boot several times and when it does finally get to the desktop, it freezes and then goes off into power saver mode. how do I fix that?
    Try running the Check Disk Utility.
    To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
    Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
    If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
    In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
    In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
    May 04, 2012 | Dell OptiPlex 360 Desktop Computer
    Today while a user was trying to get online using IE, the machine froze and the monitor went blank. The monitor had red lines appear about 1/2 inch apart and froze. The machien qwould not soft boot. I did...
    Your startup got corrupted. If you have an emergency boot floppy, you should be able to get to DOS. This may not work unless Floppy is in your Boot order. If your lucky, you have a cd/dvd in the boot order. Try to put your original XP or Vista disks in and see if you can boot. You can then see files.
    Nov 10, 2009 | E-Machines T5048 (7136) PC Desktop
    NTLDR MSSING, how can i solve this?
    NTLDR is short for NT loader – a program loaded from the hard drive boot sector that displays the Microsoft Windows NT startup menu and helps Microsoft Windows NT load. So when it goes missing for some reason, your windows cannot load.
    Cause:
    1. Computer is booting from a non-bootable source.
    2. Computer hard disk drive is not properly setup in BIOS.
    3. Corrupt NTLDR and/or NTDETECT.COM file.
    4. Misconfiguration with the boot.ini file.
    5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
    6. New hard disk drive being added.
    7. Corrupt boot sector / master boot record.
    8. Seriously corrupted version of Windows 2000 or Windows XP.
    9. Loose or Faulty IDE/EIDE hard disk drive cable.
    if there is attached drive ,remove the drive first before restarting the system if not then if you had access to another computer, copy the NTLDR and NTDETECT.COM which is available from the recovery CD which comes with computer. If you do not have the recovery CD, its available on microsoft site or is available from another computer using the same Operating System (Windows XP ). The location may be C:\i386\ntldr C:\i386\ntdetect.com use a bootable disc to restart the computer (the Win XP bootable CD or Win 98 bootable CD worked). After entering MS DOS mode, copy these 2 files to the C drive in the proper location. After restart, then pressing F10 on start up (used for system recovery ), then start the repair of Windows via system recovery This will reinstalled all Windows drivers and system files, while preserving all data on your computer.
    Sep 16, 2009 | Computers & Internet
    Black screen on startup. The monitor is okay, but remains off when I boot up my acer m1610. I can hear one bop (means okay) and run, but without video. Sometimes it runs with with video, sometimes not......
    Does the monitor give picture and stay on when connected to another pc? Also, does the monitor function properly in safe mode? If so, your video adapter may be set to display a resolution beyond the capabilities of your monitor. try this:
    1. Download the latest drivers for your videocard but do not install it yet.
    2. Boot into safe mode and uninstall any video card/driver software installed on your pc
    3. Go to device manager, expand video adapters, right click on all video adapters and uninstall (uninstall driver too if prompted)
    4. Reboot normally. If you followed the above steps correctly, the pc will automatically re-detect your video card and install a generic driver for it.
    5. Now install the video drivers you downloaded in step 1.
    6. That should do it. Let me know if this works or not.
    Aug 08, 2009 | Computers & Internet
    Boot problem - with XP and 2000
    whn you ran with xp did you have AC power plugged in
    Jan 18, 2009 | Toshiba Satellite A105-S4004 Notebook
    Benq 19" monitor not working every time when computer started
    Check your connections and make sure they are tight, and there are no bent pins. If everything seems ok, you might want to try plugging this monitor into a different computer or plug a different
    monitor into yours to determine whether it's the monitor, the video card, or maybe the driver (doubtful on this as you state it seems to be bad somethimes on boot).
    May 26, 2008 | BenQ Computers & Internet
    Freezing or shutoff on boot, setup or minutes into operation
    Try this:
    Boot the system with your Windows XP installation disk. When the boot options window appears select R for recovery console. Once you have logged into the DOS session type: fixmbr and hit the enter or return key and select "y" for yes you want to do this. Type: fixboot and hit the return key again, hit "y" for yes.
    May 17, 2008 | HP Pavilion ze2000 Notebook
    Sometimes it boots sometimes it wont
    Hello Mike:
    Sometimes is the trouble here..but lets go through a few things to check...perhaps maybe one of mine someone else didn't think of...
    1) remove the battery and unplug from the wall. Hold power button on...plug into power...let boot.
    2) Perhpas it is software related...your MBR could be corrupt...boot to DOS (you can create a dos diskette from boot.com) or simply hit F8 to boot in DOS mode. at the C prompt type FDISK/mbr. This will not harm your data...it will rebuild your Masterboot record. There a few nasty viruses that hide in the MBR (Master Boot Record) running this ustility will wipe it out.
    3) On the otherhand you could have a more serious problem...motherboard or CPU. TRoubleshooting this items in a laptop is a bit trickier than a desktop...you could purchase one of those troubleshooters for about 20 bucks...you plug intoLPT1 and USB...power laptop and read the lights.
    Hope I have been soem help...
    Good Luck my Friend
    Seek PC Repair
    Feb 10, 2008 | Sony VAIO GRX580 Notebook
    Unable to load
    How to get to a MS-DOS prompt.
    Reason: If Windows or the computer is not operating properly, it may be necessary to get to a MS-DOS prompt to diagnose and to perform additional troubleshooting on the computer.
    Solution: MS-DOS users
    Windows 3.x users
    Windows 95, 98 and ME users
    Windows NT, 2000 and XP users
    Windows Vista users
    Other PC Operating System users
    MS-DOS users If you are running MS-DOS with no other operating systems, the computer should be booting into a MS-DOS prompt automatically unless you have a shell or other program loading automatically. If the computer is not getting you to a MS-DOS prompt, reboot the computer and as the computer is booting, press the F5 key when you see the message "Starting MS-DOS" or the MS-DOS version. This will load the default standard MS-DOS. If you successfully get to a MS-DOS prompt and would like to prevent the computer from loading the program that is preventing you from getting to a MS-DOS prompt, or if you would like to fix possible error messages you may be receiving when booting the computer, edit the autoexec.bat and/or the config.sys files.
    Windows 95, 98, and ME users If you are able to get into Windows 95, 98 or ME, you can get to a MS-DOS prompt by following the below steps.
    1. Click Start
    2. Click Run
    3. Type "command" and press enter.
    This will open a MS-DOS shell. However, if you are attempting to troubleshoot an issue with the computer and are using Microsoft Windows 95 or Windows 98we suggest you restart the computer into MS-DOS. To do this follow the below steps.
    1. Click Start
    2. Click Shutdown
    3. Choose the option to restart the computer into a MS-DOS prompt.
    If you are unable to get into Windows 95 or Windows 98 to get into a MS-DOS prompt, follow the below instructions (Windows ME does not have this option).
    1. Reboot the computer
    2. As the computer is booting, press the F8 key when you hear a beep or when you see "Starting Windows 95" or "Starting Windows 98". Windows 98 users sometimes may find it easier to press and hold the left CTRL key as the computer is booting.
    3. If done properly the user should get to a screen similar to the below screen.
    Microsoft Windows 95 Startup Menu
    ============================= 1. Normal
    2. Logged (\BOOTLOG.TXT)
    3. Safe mode
    4. Step-by-step confirmation
    5. Command prompt only
    6. Safe mode command prompt only
    Enter a choice: 1
    F5=Safe Mode Shift+F5=Command prompt Shift+F8= Step-by-step confirmation [N]
    4. Select the option for Safe mode command prompt only.
    Windows NT, 2000, XP, and Vista users If you're running Windows NT, 2000, or Windows XP and need to get to MS-DOS prompt follow the below steps.
    1. Click Start
    2. Click Run or click in the "Start Search" field if you're running Vista
    3. Type "cmd" or "command" and press enter.
    Additional information about the difference between "cmd" and "command" can be found on document CH000395. If you're attempting to get into a MS-DOS prompt to troubleshoot the computer boot the computer into safe mode. Additional information about how to get into safe mode can be found on document CHSAFE. Windows 2000, XP, and Vista users who are unable to boot the computer into Normal Windows mode or Safe mode can also enter the recovery console to manage their computer from a prompt. Additional information about how to do this can be found on document CH000627. Finally, if you are experiencing issues getting into Windows NT, 2000, or XP, it may be necessary to run troubleshooting steps from a MS-DOS prompt. It is recommended that the Network Administrator get into the MS-DOS prompt by using either a standard MS-DOS boot diskette (note: will not be able to access data using a standard MS-DOS bootable diskette) or the ERD diskettes created after the installation of Windows NT, or boot from the Windows XP CD.
    Index
    Category:
    MS-DOS Q&A
    Companies:
    Microsoft
    Related Pages:
    MS-DOS
    Safe Mode
    Resolved
    Were you able to locate the answer to your questions?
    Dec 06, 2007 | Microsoft Windows XP Home Edition
    Computers & Internet Logo
    121 people viewed this question
    David Payne
    David Payne
