Question about Electrolux Ovens
Electrolux ew30ds65gs5 how to remove the bottom door to clean
Remove lower drawer to clean under oven
SOURCE: Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
Posted on Dec 25, 2007
aborcass
  • 2651 Answers
SOURCE: Lower oven door
no adjustment at all you would need to replace oven door hinges,
Posted on Mar 03, 2008
SOURCE: Electrolux Icon Oven won't self clean - "Remove Racks" displayed
I was getting the remove rack error until I finally figured out what it wanted me to remove. When you say you removed the rack supports, do you mean just the sliding parts or the whole side metal rack support? At first I thought they were bolted in, but I read somewhere that they come out, too. Upon further investigation, I found the rack supports just slide into the side walls at 4 points. I had to use a little force to pull them out, but they came out and my oven is self-cleaning as I write this. I just thought I would share in case you or others haven't figured it out yet. Now I will just have to see how hard it is to get them back in...
Posted on Feb 21, 2009
  • 44 Answers
SOURCE: Electrolux EOB944. How do you remove the Glass
Hi
to remove glass panel you need to open door abit on top of door is 2 screws. undo these but hold handle at same time so it doesnt fall . once scrwes are out prise apart a little bit the lift glass then it should be of . hope this helps
regards dan
Posted on Mar 19, 2009
  • 44 Answers
SOURCE: How to clean the inside of the glass door of Electrolux Wall Oven
Hi
open door and along top you will see 2 screws undo but hold door at same time then just lift out and clean.
hope this helps
Posted on Mar 21, 2009
Can I get a replacement for the lower oven door of an Electrolux EDC6935 wall oven?
Hi Mike - I am happy to assist you. First, according to my research, the model number that you have provided me is appearing invalid according to the Electrolux database within the US. Are you located outside of the US? Generally speaking, for some units the complete door set would need to be replaced. However, may I please have the correct model number, to better address the issue at hand? Typically the serial tag is located in the storage drawer on the right side. Thank you and I look forward to your response.
Jun 18, 2013 | Electrolux Ovens
How do you put door back onto Electrolux wall oven......Been trying for hours, no success!
Hello paulascor549 - I completely understand that you took the oven door apart to clean it, therefore you must have took the following steps to do so. According from my research you would have to reassemble in reverse order. If you have already tried to do so and it proves to be ineffective, contact a professional to move forward accurately.
Door Removal and Cleaning of Interior Glass
Tools needed: Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide? With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Nov 24, 2012 | Electrolux 30" Built-In Single Electric...
We have a Kenmore double oven. Awhile back something spilled as it was being removed from the top oven, and spilled onto the door of the lower oven. Now the glass inside the lower oven door is streaked and...
Please follow the below steps
1)Open the door.
2)Check the hinges and let the door be opened in half way.
3)Use Philips screw head at hinges screws.
4)remove the door and take the inner part alone.
5)Just follow the picture for more help.
Clean it and place it again.
It is very simple you can easily clean it.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Feb 07, 2011 | Ovens
How do I clean my Electrolux Icon Oven?
Which Electrolux Icon Oven do you have?
For most ovens, with a use a cloth and hot soapy water (do not use an abrasive cleanser or an oven cleaner), clean the door and the frame of the oven outside of the gasket. Similarly, remove the heavy amounts of spilled food (get rid of sugary or highly acidic food spills particularly) in the oven. Take the oven racks and oven rack support, broiler pan and insert, utensils and any foil out of the oven. Then close the door. If you have a single oven, press Clean. If you have a double oven, select the oven to clean and then press Clean. Select the duration of the cleaning cycle (either by hours (2,3, or 4) or cleaning level (Lite, Medium or Heavy)). Some Electrolux ovens have buttons for the cleaning level otherwise use the up/down arrows. Then press Start. The door will lock and remain locked until the oven cools after the cleaning process. For a delayed cleaning cycle, make sure the time is correct on the clock and press End Time and enter the time you want the cycle to end and then Start.
Make sure the kitchen is well ventilated.
The manuals are available for most from the Electrolux site. Start at http://www.electroluxicon.com/ and search for your model. (Either search on the model at the top right or under Kitchen Appliances) If you find a page for that model, it will have a Specifications and Guides tab. The manual is in that tab as a pdf.
I hope this helps.
Feb 06, 2011 | Electrolux Ovens
I need to get the oven floor out to clean under it.
pull your bottom drawer out and lift up on the front of the drawer then remove the drawer. then remove screws to remove the floor pan
Apr 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
How do I use the steam clean self-cleaning oven?
The SteamClean option spot cleans the oven in 20 minutes and is recommended for cleaning light spills on the bottom of the oven cavity. When used routinely, the SteamClean option reduces the need for frequent self-clean cycle use. To use the SteamClean option, pour 12 ounces (1 1/2 cup) of water into the bottom of the oven cavity, close the oven door and push the SteamClean button. At the end of the cycle, consumers wipe out the bottom of the oven, easily removing oven soils. The steam cleaning option is eco-friendly and does not require frequent use of the self-clean cycle, which can create a strong odor. Read this in a post about the new whirlpool ranges
Apr 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Need Manual For Electrolux Oven Model EOB 985GR
Having trouble locating the correct model number. Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Let me know, Sea Breeze
Mar 27, 2009 | Electrolux Ovens
Can Get Door Back On
Just managed to put the doors on. Do the bottom door first. There are 2 little spikes on the bottom of the door. You need to slot them into the holes in the frame. Then make sure that the little metal flaps on the top of the door fit UNDERNEATH the inner door frame. Screw together.
Same with the top door, additionally add the trim on top.
Thanks to solution #1 - I've literally been fuffing about since yesterday evening, I was about to call out the engineer! :)
Jul 19, 2008 | Electrolux ICON Designer E30SO75ESS Oven
Electrolux Oven EOG9330
Hope this helps (technique used on EOG9330XN):
1) With the door open, on each hinge, there is a top cover which lies flush with the hinge. Simply swing this cover up and back towards you. This unlocks the hinge. Undo both and carefully close the door, holding it at the bottom. The door should be able to be pulled away from the frame now. Lay the door on a flat surface.
2) The oven will normally be attached to the surrounding built-in cupbpard. If so, unscrew all attachment screws (mine had at least three per side) and pull the whole oven out about seven inches, supporting if neccessary. Each side panel has a locating screw in bottom front corner, so remove the screw. Peel back the side panel (only thin alloy, but watch for sharp edges) sufficiently to see.....
3) The two side securing screws for the door hinge receiver should be visible. After pulling receiver forward, if loose, tighten securing screws (use lock washers if available, as Electrolux don't provide them).
4) Reverse the procedure to finish job, fitting the door in the near vertical position to engage hinges in the receivers. Support the door, lower to open position and flip the locking hinge covers back.
[This technique works if the hinges aren't worn and if the door doesn't close properly, it usually means that the receivers are loose and have been pushed back into the oven frame].
Apr 11, 2006 | Electrolux EOG9330 Gas Double Oven
Ovens Logo
47 people viewed this question
Top Electrolux Ovens Experts
ashburton
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
