Question about Exercise & Fitness
Proform 500 zlt belt slips - Exercise & Fitness
  • 10865 Answers
SOURCE: belt is slipping
your macnine needs some maintenance. slippage on the proform is usually due to a worn out front roller and a worn motor driving the belt. both can be replaced. or you may want to find a good used one as many get no use before the optomististic owner decides to sell.
Posted on Aug 17, 2009
Testimonial: "Thanks for the fast response"
  • 13 Answers
SOURCE: Proform Crosswalk Advanced 525X
One possibility is the pulley in the front roller.The shaft that goes into the roller slips making the belt seem as if its slipping. To check it it requires tmarking both surfaces with paint and then see if the mark seperates.
Posted on Dec 01, 2009
jyackle5
  • 8197 Answers
SOURCE: belt is slipping on a proform 740cs treadmill.
You can get the manual on linke below. When there type in the number code then hit submit. on the next screen click on manual link to down load. then on page 21 tells you how to adjust belt.
http://www.hammerwall.com/Download_Manual/18209/
Posted on Jan 07, 2010
  • 31 Answers
SOURCE: My treadmill Proform Crosswalk 400e feels like it
If it feels like you are walking/sliding on ice, the walkbelt or the motor drive belt is loose.
Posted on Jan 16, 2010
bwinton
  • 83 Answers
SOURCE: Belt is slipping and catching
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Posted on Apr 30, 2010
The belt slips when I run
see this video and fix it. God bless you
Sep 28, 2012 | Proform Crosswalk 500 Treadmill
Belt seems to slip while on the treadmill
hi your belt need to be tightened, check your manuel on how to do this. but do not walk on the belt when its doing this you can damage the belt and the motor very expensive to fix.
Nov 11, 2010 | Proform Crosswalk 500 Treadmill
THE BELT MOVES FINE BUT WHEN I STEP ON THE MACHINE THE BELT STOPS
the drive belt is slipping under the motor hood and most likely needs replaced
Aug 02, 2010 | Proform Crosswalk 500 Treadmill
Treadmill is slippng badly
There should be an allen head bolt on each side at the rear of the treadmill going throughthe rear cover into the tail [rear] roller. Turn each one 1/4 turn at a time equally untill slipping is stopped. If belt tracks more to one side tighten slightly more on that side.
Feb 06, 2010 | Proform Exercise & Fitness
Proform Crosswalk Advanced 525X the belt slips and it squeaks when slipping.....I have tried adjusting the end of the belt but that doesnt seem to help
Nov 30, 2009 | Proform Crosswalk 500 Treadmill
My 525x slips. Which part typicaly causes this?
This usually caused by a slipping drive motor belt. remove the hood cover, one screw in rear and 2 on the bottom. There will be an adjustable bracket on the drive motor. Good luck, Tim
Nov 05, 2009 | Proform Crosswalk 500 Treadmill
Proform Crosswalk Dual Motion Cross Trainer Treadmill. motor works great. Rubber on right side under the moving belt has come off so belt slips when in use
I think you are talking about the front roller. It has a rubber sleeve that helps to grip the walking belt. Sometimes you can tighten this enough to keep it from slipping but you run the risk of overtightening and damaging both rollers. We recomend replacing that roller.
Oct 24, 2009 | Proform Crosswalk 500 Treadmill
Walking belt stop when you walk
this usually is caused by your tensioners on each side of the upper belt roller have become misalligned and for whatever reason now needs to be adjusted
one side is basically lower on the horizontal
so it slips down as it spins
Oct 14, 2009 | Proform Crosswalk 500 Treadmill
I have a proform treadmill that slips as soon as i step on track i looked at the belt it looks good how do i tighten up the track
There should be adjustment screws on the back left and right sides. The screws will be horizontal with the tread, and probably need an allen wrench to tighten. If the tread runs straight, tighten each side 1/4 turn at a time to keep them even. Check the tread after each adjustment, and stop as soon as the tread quits slipping.
Sep 08, 2009 | Proform Crosswalk 500 Treadmill
The belt is slipping and making a squealing sound
May 14, 2009 | Proform Crosswalk 500 Treadmill
Exercise & Fitness Logo
32 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
