Dell E197FP LCD Monitor Logo
Posted on Dec 31, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I boot up my desk top with monitor E197 FP LCD stays black takes a few times to go
I have windows 7 using high speed internet monityor is about 6 years old CPU is about a year &half old
Buddy Mcsparrin
Level 3:
  • Dell Master 1,684 Answers
  • Posted on Feb 10, 2013
Buddy Mcsparrin
Dell Master
Level 3:
Answers
1684
Questions
Helped
1011057
Points
4641
This is a common problem with the E197 units. The problem is caused by a failure of the filter capacitors on the power supply board, they are not holding a charge like they should and it takes several power cycles to get them charged up so the monitor turns on. The E197 uses the same power supply that the E177 uses. Here is a link to a repair guide for the E177 with video disassembly and repair instructions that will help you get your monitor going again.
http://www.ccl-la.com/blog/index.php/repairing-a-dell-e177fpf-lcd-monitor-with-power-issues/
5 Related Answers
Anonymous
  • 859 Answers
  • Posted on Jun 21, 2008
SOURCE: Dell LCD monitor suddenly loses power
Five years is a long time for an LCD panel. You definetly got your money's worth.
But, if your trouble shooing has led you to this conclusion I can also only conclude that the power driver inside your panel just gave up the ghost.
However, try giving Dell a call, for what's thats worth and see what they have to say.
You might also want to ask this expert "Robotek" what he may think as he is a board troubleshooter and could give you an answer if one is there.
Type this or copy and paste into your browser's address bar:
http://www.fixya.com/users/robotek
And then click on the Ask Me button under his picture.
Best regards,
Worldvet
Anonymous
  • 53 Answers
  • Posted on Jun 03, 2009
SOURCE: 7 year old Dell Inspiron 4150 has black screen.
This is a common problem, I don't think the LCD per say is bad. The backlight tube may be bad or the power inverter that powers it may be bad. GO to support.dell.com and search for these parts, get them both and replace them both. It is tricky as you must dissasemble your laptop lid panel.
Buddy Mcsparrin
  • 1684 Answers
  • Posted on Jun 26, 2009
SOURCE: I have a Dell 1704 FPTt monitor and it is about 4
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the badparts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the newone the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Anonymous
  • 121 Answers
  • Posted on Oct 10, 2009
SOURCE: Dell flat screen monitor does not come on after
Sounds like a capacitor on the power strip inside the monitor is failing.
The cost to repair can run $400.00. A tv repair shop may be able to fix it, but most technicians recommend buying a new monitor.
However, if you are experienced in electronics, you can disassemble the monitor and replace the capacitor. Radio Shack sells them for between $15 to $20.
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Feb 01, 2010
SOURCE: I have a dell 19-7 fp monitor that only stay on
The problem can be caused by bad caps in the power supply, bad inverter circuits, or bad lamps. You need to open it up and look inside and post back so we can guide you further, see example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
AOC 917sw starts normally then goes black after a few seconds?
More than likely, you have set the resolution too high for the monitors capabilities. Set the computer to a lower resolution, and try again. If using windows, try to boot in safe mode to accomplish this. Other OS's can take variables at boot also to do the same. You'll have to search for yours.
Good luck.
Bruce
Hello My acer 1916W LCD Monitor Screen will not light up after turning my desk top Computer on.. Although the start light lights up okay My Screen stays Black. It only lasted over 6 months I am now using a...
you need to reset the bios in the computer take the littel battry out inside with the power of then wait a min or two re insert boot and c if that works
1helpful
Hi.i have a dell e521 with a e197 fp monitor. when i turn the system on the monitor stays in stand-by mode. so i have a black screen,is it broken?
not really.. theres a possibility that the monitor is just on standby mode. try to disconnect the power cable of the monitor, then hold the power button of the monitor to drain its flea power. put the power cable back then try it again.
if its going to do the same thing, check the connection of the monitor at the back of the computer. see if its seated properly.
try restarting the computer..
try draining the flea power on the computer as well, possible that the computer is in standby or hibernate mode..
How do I change the resolution on my fuji plus FP-988D 19 inch monitor
Monitor resolution is done at the PC, not at the monitor, right click on the desk top, slect properties, display property will come up, select setting. You should set it to match your monitor native resolution for best picture.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Can VP171s work with Windows 95?
Your video settings are incorrect for the monitor. Right click on desk top and go into the settings/advance area where you can make monitor adjustments.re resolution and refresh rates.
When I switch my windows XP Home Edition on instead of the usual gradual build up to Desk Top & icon programmes etc. I get the usual large black screen but instead of the windows motif appearing I get...
The results you are seeing are actually from the monitor itself. It's telling you the vertical and horizontal sync frequencies to help you troubleshoot your lack of display.
You'd usually see this happen when someone has set the resolution too high, and the monitor just can't handle it.
Power up, and keep tapping F8 until you get a Windows boot menu. Choose "safe mode", let it boot to windows. Go to display properties, and then settings. The slider for the resolution will now be right down. (left-most). Click it once, so that the apply button becomes valid. Hit apply and let it restart.
You should now boot to Windows normally, but with a very low resolution. Go back to display settings and bump it up one step at a time, using the apply button. (which will revert back one step if you don't hit "yes" within 20 seconds).
That way, you can find a resolution that looks right, but isn't too high for your screen.
Acer Monitor boots up w/computer then "no signal"
you must have disconnected it while the pc was running.damage can occur while doing this as can a keyboard (they are not like USB devices that can be plugged and unplugged while "hot".)
Lcd monitor failure
your monitor need to be service so take it to service center if you are in mumbai you can call for service
Ashok
9322133048
Flatron L1719S
I think your monitor is unstable. Is it showing power saving when you boot your PC? Does it show something when the Windows XP splash appears?
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
