Question about Sharp Twin Energy EC-12TWT4 Bagged Upright Vacuum
Cannot hook vacuum floor section when carrying. Falls vertically
Small dark gray plastic piece broke off which prevents me from placing the vacuum in an L position when desired. It fall to a totally I position when trying to carrying or maneuver. What is the part number?
  • Curt Whitney
    Curt Whitney Apr 19, 2009
    Thanks. Price is shown as $12.91
Part # S-706. I found it at http://www.vacsrus.com/CartGenie/prodInfo.asp?pid=96&cid=28, but did not purchase it yet.
Posted on Jan 29, 2009
Beater bar not working on newer ball pet unit
HighnTools posted this solution some time ago. I think it can help you solve your issue.
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
Aug 29, 2010 | Dyson DC15 All Floors - The Ball Bagless...
When I press the botton next to power button in order to activate the bruch for carpet cleaning. The brush does not spin anymore.
HighnTools posted this solution a while ago. This might be related to your problem: I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
May 21, 2010 | Dyson DC15 All Floors - The Ball Bagless...
The Beater Bar keeps Shorting out, we had to replace it a while back and it was working really good, then it started shorting out, do you know what the problem is?
HighnTools posted this solution a while ago. There are so many people having similar issues. This might be related to your problem: I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
The above by highntools.
May 11, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Hi my dyson dc18 has great suction from wand but when you got to use the vac for floors little suction but wand still got suction even while vacuming floors is it suposed to stop suction from wand
My Dyson dc18 had the same symptoms. The wand worked well and the floor bar had no suction. After removing pieces & shoving my fingers into the machine (no blockage) I found the suction pipe rotates between two positions (floor and wand). It looks like a piece of plastic broke on the outside housing, so it no longer rotates positions when the wheels are raised or lowered. My son found we can move the suction by sliding a finger into the mechanism behind the wheel cover, and rotating the plastic piece clock-wise or counter clock-wise until it locks into position. It's a big pain but it works for now. I wish I could find a replacement piece online. Patty
Apr 03, 2010 | Dyson DC18 all floors Bagless Upright...
No suction power does not get up the dirty water
Your suction problem is most likely due to a clogged lint filter. It is located in the top clear plastic section. This is the one with the dial to switch from floor to tool mode. On the underside of this section is a small (1 inch square) red plastic piece with a door on it. Flip open the door and you will probably find that it is all clogged. Clean it out and you should have suction again.
Sep 21, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Engonmic hand grip broke off
Check the manuals link and maybe they will replace it under warranty...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Aug 24, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Dyson dc07 yellow/blue no suction at base
Sounds like you've **** up something which is obstructing the suction from the brush bar. There's a little section of curved grey pipe near the base which carries the dirt from the head up the vertical pipe at the back. This section can be removed, check there is nothing jammed in there, paper etc.
Jun 07, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Can't clean out a part; need help
The nozzle will seal very tight along the sides, pry up with somethin like a flat blade screwdriver to pry it loose. When you re-install it, make sure the 2 tabes at the top edge of the window snap into the slots first before putting it all of the way down. If you don't then the bucket will sit up slightly and won't suck up the water.
Feb 24, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
HOOVER STEAM CLEANER PROBLEM
The soap dispenser is supposed to be attched to the water tank. That grey piece, if it is round with 2 small ears on it is the metering plate, it controls the flow of water. It sits on the table that the tank sits on, insert it into the hole and turn to lock it in place.
Jan 14, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Sharp Twin Energy EC-12TWT4 Bagged Upright Vacuum Logo
108 people viewed this question
Top Sharp Vacuums Experts
jasbo
jasbo
Mike
Are you a Sharp Vacuum Expert? Answer questions, earn points and help others
