Question about Garden
Fisher minute mount replaced hydraulic motor with new one, now motor very loud angles a few times then nearly kills batery have to wait several minutes for batery to rechardge, did not do it befor cha
Old pump motor burned out, replaced motor with a new one from dealer, now plow anles and lifts, but drains electrical sysem to the point lights dim badly, generator light comes on then will not respond after 3 movements of plow hyrolic unit. head a click under the hood also, then plow will not respond. battery gage shows only 8 volts. Slowly batter builds back up and another click is heard, plow will then respond again till next 2 to three movements.
  • 213 Answers
SOURCE: Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Posted on Nov 20, 2007
  • 417 Answers
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Posted on Nov 04, 2008
JR JR
  • 116 Answers
SOURCE: Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Posted on Nov 30, 2008
RescueTech
  • 145 Answers
SOURCE: Fisher & Paykel top load intermittent running
Check your water pump... When they get wet or leak, they will shut down the machine control. If you wait too long you will blow out your machine control completely. You most likely need a new water pump and it is easy to replace with no tools needed. Your part number is a 420325P and you can get one from Fisher Paykel Parts direct:
http://fisherpaykelparts.net/index.php?categoryid=111&productid=3
Posted on Dec 15, 2008
localwonder
  • 6784 Answers
SOURCE: AEG Lavamat 16820: Strange noise coming the machine
Ok, the motor windings are bad. the A.C. hum is a warning that the motor will sound when the windings are separated or shorting. its unable to hold a balanced current.the motor will actually stop soon if it isn't repaired.
Posted on Feb 16, 2009
I have a minute mount plow, when I try to use it only goes to left and right side but doesn't go up, when I try to lift the plow goes to the right. What can I do
2002 Fisher Minute Mount Inst-Act Wont Angle [Archive] - PlowSite ...
www.plowsite.com > ... > Truck & Equipment Repair
Nov 17, 2011 - 90 posts - ‎9 authors
My plow went up it was jerking and did it in steps , but , it got there . Now , it onlyjerks when i try to angle it right or left or up . I filled the fluid ... Drop it and if it doesn'traise you can just use a jack and shorten the transport chain to hold it. .... I do havecontinuity on the plow side for all 3 wires going to the plug . Hooking Up A Fisher Minute Mount 2 In Under 1 ...
Feb 1, 2011
Plow Wont Angle
Oct 19, 2010
What's wrong with my plow?
Jan 9, 2003
Looking For Minute Mount Tips
Feb 13, 2002
More results from www.plowsite.com
Ultramount Intermittent Angle Problem - Snow Plow Forum - L
Dec 27, 2015 | Cars & Trucks
Fisher minute mount 2 plow won't move.the motor runs but no plow movement? Is the pump bad?
You may have to bleed air out of the system to get it to work properly. Hope this helps.
Jan 02, 2014 | Cars & Trucks
Fault 49
machine needs a new motor controller. can't remember what the code is exactly, but I have seen it a few times, generally replacing motor cont works. I htink it can be a motor problem too, test winding with a multimeter to make sure they are equivalent.
Nov 29, 2013 | Fisher and Paykel Washing Machines
Drain pump problems
Without the model its hard to really give a detailed answer but I can tell you this. Fisher Paykel dishwashers if I recall dont actually have drain pumps. They have what they call motor rotors. I personally own a set of dish drawers from the them and to remove the motor rotors what you want to do is kill the power to the machine first, then remove the rack from the drawer. there in the center or near there you'll see the motor rotor held in with a locking ring. Just twist the ring to take it off then pull the motor rotor right out. This will take no more than five minutes max once you have the part. You'll need the model number and I believe the website is call coolblueworld.com
Apr 28, 2012 | Fisher and Paykel Dishwashers
This Fisher & Paykel GWL15 washer began making strange noises this week. When the water is pumping out, a loud, moaning or grinding sound is made. It also makes the sound after a few minutes at the...
Same thing happened to mine. There's a really simple solution: Lay the unit on it's back or lean it far enough back to have access. The pump is near the front and has a black fan blade on the bottom. Remove the electrical plug on the motor; it just pulls right off. Now look for a white plastic retaining lever near the top of the pump. Hold it out and turn the pump about 1/8 turn counter-clockwise, then it almost falls out. I found a safety pin inside that was causing my noise. Went back together just as easily. Problem solved!!!
Oct 13, 2010 | Fisher Paykel EcoSmart GWL15
On tempstar heatpump the outside fan makes a loud noise
Well, that could mean a lage list of problems from which to choose, 1st I suggest you isolate the fan to be sure it is the problem; Hopefully you have an outside disconnect box for the unit, stop the power at this discoonnect and wait 3 minutes. Place a large stick or metal bar throught the topgrill to hold back the fan blade from turning. Now connect the energy at the disco box ( you may want a second person so you can hold the stick in place). You will not harm anything by holding the fan from turning for a short time. If you hear the noise that you suspect after the unit runs for 20 seconds, then the problem is most likely the compressor. If you do not hear the noise, then remove the stick and aloow the fan to turn. You at this point should be able to see if the blade is clangging, or the blade is imbalanced and vibrating, or the noise is coming from the fan motor itself. The most likely problem is the bearings of the fan motor are worn and the motor is screaching or laboring; in which case you need a new motor unless you are savy enough to replace the bearings in the motor (however, this is not always cost effective unless you really know your stuff). Check the blade for fatigue fractures in the metal and check the mounting points that hold the motor in place-----sometimes these mounting points also fatigue after years of vibrating and need to be reinforced with oversize washers or the entire top grill piece needs to be replaced if the cracks are too severe. Goodluck, Macgivor
Jan 02, 2010 | Ruud Central System Air Conditioner
My multitester doesn't react
there are several reasons why the tester doesn't react..try to check these:
1. Check the safety fuse inside it.
2..The test lead set (the red & black wire w/ pin )
might have cut inside it,particularly in the part of
ends,near the pins/plugs.
3. The bateries might be o voltage and need to be
replaced.,or if the batery is good,just clean the
contact or teminal of the bateries.( a common
multi tester have 3 bateries, composed of 2 size
"AA" & 1- 9volts size.) these bateries are all
assigned to the "continuity"section of the tester.
(these are: X1;X10;X100 ; X 1K & X10K. )
so,if the tester is not functioning only in that
section,the first thing you have to check are the
bateries.Now.if you replaced the bateries with
new one but it is atill not working,then we go
back to my tip number 1 above.,that is to check
the test lead.
3. if you already finish checking the above method
and it still not working,then there is a problem in
the resistors of the system.
But, is your tester is digital? if it has no power: just simply check the fuse & batery..But if it has a power but not working when you use to test,you jst check the test lead or the selector switch becos the contact inside might be loosen.
Dec 03, 2009 | Skil 2100DAF Digital Angle Finder
Fisher minute mount goes up and left and locks up
check your connections, especially the main power plug in, i have used a small "c" clamp over the connection to aid in the same problem
Oct 29, 2009 | 1998 Chevrolet C1500
My Maytag dryer buzzes when I push the start button. If you hold it in, the dryer will start but makes a noise, almost like a bad belt. After a few minutes the dryer will shut itself off and will not...
Remove the belt from the motor and push 'start'. If the motor makes loud noises, squeals, or the shaft has side play in several directions, then it probably is the motor. Replace it. If the the motor runs quietly, then check the drum by hand to see if it is making excessive noise while turning. There should be a little resistance to turning, but not real difficulty. Hope this helps.
Aug 13, 2009 | Maytag PYE2300AY Electric Dryer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
