Question about Kenmore Microwave Ovens
We removed our wall mounted Kenmore microwave (speed cook oven) and trying to use on the countertop we get an F7 error. Could the F7 error be because the unit is not mounted on the wall - I'd hat
It's a great oven and was working fine before us removing it. We did not drop it or jar it much moving it but we did have some difficulty getting the vent off. Set on the countertop the lights come on and the menu seems to work. I set the cook time then push start, it sounds like it's working but one or two seconds later the F7 error shows up in the display. Looked for a switch or sensor on the wall mount but couldn't find one. Does the f7 error mean the oven is broken?
3 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: remove wall mount microwave
The installation instructions will tell you how it's attached.
Contact Danby Customer Service US / Canada
Posted on Nov 08, 2008
MNfisherman
  • 11896 Answers
SOURCE: Microwave doesn't work
Sounds like you have a faulty control panel. I would use a meter and test the power from the control board to the magnetron and circuit board. Chances are the control panel is faulty
Posted on Jul 25, 2010
I have a Kenmore Elite Speedcook Microwave oven, model #665.63783600. What does error code F7 mean on this model?
F7 Error Code On Microwave Ovens With Inverter Board
An F7 error code could be an inverter board failure. Anything else that prevents microwave energy may also cause an F7 error, and must be checked. The technician should perform the following procedure to test for an F7 error code:
1. Check the magnetron.
2. Check the magnetron TCO (it should be closed).
3. Check the 3 interlock switches.
4. Check the harness wiring.
5. Check the electronic controls.
6. Check the inverter board.
For more free help, feel free to contact me via my site with your detailed symptoms and full model number and FCC ID number as shown on the tag in or on the oven.
Nov 18, 2016 | Kenmore Microwave Ovens
How do I set the timer and use the cook function at the same time on my Kenmore microwave model 405
Either your microwave is defective or you don't understand how to use it. Try Googling (Kenmore)(74229)(manual) without parens to get instructions or go to www.searspartsdirect.com for the same.
Sep 16, 2016 | Kenmore 74229 Elite Black Countertop...
How do I change the power level
I have a Kenmore, but you can try this: when you're about to cook, put the time in, then press the power button. Put the power level in, then press start.
Oct 26, 2014 | Hamilton Beach P100N30ALS3B Black...
I have a old jenn air wall oven and a old jenn air microwave mounted on top. it was a countertop model. when i removed it it was plugged into the top of the oven. would that be a 110 appliance outlet?
The Jenn Air microwave that is mounted above the oven in your unit is 110v 60Hz. The socket in the upper rear right corner of the oven is a 110v 6Hz socket and is where the microwave would be plugged in. If you are going to replace the microwave, you can plug it into that socket. If you would rather not use that socket, you will have to drill a hole in the side of the cabinet holding the over/microwave to get the power cord out.
Sep 29, 2014 | Jenn-Air Microwave Ovens
Cooking with convection oven
You do not have to remove the turn table, but I use the metal rack when cooking with convention.
Apr 15, 2014 | GE Profile PEB1590 1.5 Cu. Ft., 1000W,...
Kenmore Elite countertop microwave model 721.79153010 has no power, completely stopped working.
has an internal fuse. but you need to find out why it has blown, has it been making any funny sounds while cooking. ??
Mar 09, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
My kenmore elite microwave when turned on shows a f7 error code.
f7 keeps showing up and the microwave keeps cutting off,f7 code shows up. what do i do
Oct 26, 2010 | Kenmore 68361 Microwave Oven
I don't see how you remove it from the wall mount
do you have cabinets abofe the microwave. open and see if the brackets that hold it on are in there.
May 25, 2009 | Kenmore 63792 Microwave Oven
Microwave Ovens Logo
24 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
