I change the motherboard i don't how to fix the power led h.d.d led reset speaker etc.? pls send me a motherboard layout including to sort it
  • Dick
    Dick May 11, 2010
    There are thousands of motherboards and they all have different layouts. Which one are you looking for?
  • 70 Answers
What is the model # of your new mobo?
Posted on Jan 18, 2009
I need help with hooking up the front panel wires from a acer veriton 460 on to a asus p5g41t-m lx plus mother board
I don't think it's gonna' fit.
Acer Veriton L460 computer Case Dimension specifications,
http://support.acer.com/acerpanam/desktop/0000/Acer/VeritonL460/VeritonL460sp2.shtml
Chassis: 2.5 inches Wide (63.55mm) x 10 inches Long (254mm) x 8 inches High (203.2mm).
Asus P5G41T-M LX motherboard is 9.6 inches LONG, (244mm), and 7.9 inches High (201mm).
http://www.asus.com/Motherboards/Intel_Socket_775/P5G41TM_LX/#specifications
However,...........
If you do not know what the Power On switch, Power On LED light, and Harddrive activity LED light wires are, then remove the Front Panel, and trace them back.
(Side Panel then Front)
Click on the Download tab.
(Overview / Specifications / Download / etc)
http://www.asus.com/Motherboards/Intel_Socket_775/P5G41TM_LX/#download
Click on any O/S. They will all get you to the Manual download.
Click on the + sign to the left of Manual (12)
Scroll the inside blue bar down until you come to -
Version E7096 -
P5G41T-M LX User's Manual (English)
Click on the blue - Global
A small window will come up on the right -
Opening E7096_P5G41T-M_LX.zip
[This is a Zip file. A Zip file is used to send large amounts of information, more easily. A Zip file is a Compressed file. It needs to be uncompressed after downloading, or can be stated as 'unzipped'.
If WinZip is no good on your computer, then just download the free 7-Zip ]
Make sure there is a Green dot in the small circle, to the left of Save File.
If there is no Green dot; left-click in the small empty circle to the left, of Save File.
Now go below in the small window, and click on OK.
A small window will come up on the left.
Allow the file to fully download in this window.
Then DOUBLE-click right on the file name.
On the left side in the next window, click on - Extract all files.
At the bottom of the next three small windows, click on -
Next, Next, and Finish.
In the last small window DOUBLE-click on the file name -
E7096_P5G41T-M LX, next to the red Adobe PDF icon.
Page 1-6 (16 of 62) shows the Motherboard Layout.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front panel connect to, is the Front Panel header.
Motherboard installed in computer case; Processor to Top, Ram Memory slots to the Right, white PCI slots to the Bottom;
the Front Panel header is below the bottom white PCI slot, and next to the bottom edge of the motherboard.
F_PANEL
4 pins across the Top row, (Then no pin)
5 pins across the Bottom row.
1.10.2 Internal Connector section - Page 1-26 (36 of 62)
8. System panel connector (10-1 pin PANEL)
Pins aren't numbered, I'm going to number them;
Pins across the Top row are numbered EVEN.
Pins across the Bottom row are numbered ODD.
Starting on the LEFT side going towards the Right; Top row,
Pins 2, 4, 6, and 8. There is NO Pin 10.
Starting on the Left side going towards the Right; Bottom row,
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. 5 Volt power reserved for the factory.
D) Pins 2 and 4 are for the Power On LED. (Light)
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) There is NO Pin 10. Just a flat spot.
The small 4-pin header immediately to the LEFT, is for an internal speaker. Used to hear BIOS Beep Codes. The computer's way of telling you something is wrong, and an area to look into for it.
The Front Panel USB header is listed, and Firewire ports. (1394a)
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 14, 2012 | Acer Power S290 PC Desktop
How to connect front panel to acer power s290 motherboard
http://www.ascendtech.us/acer-aspire-sa90-mbs7109002-motherboard_i_mbacembs7109002.aspx
The area of pins on the motherboard, that the main wires from the Front panel go to, is the Front Panel header.
Looking at the Front Panel header it is parallel to the outside edge on the bottom/right of the motherboard.
13 pin header.
6 across the Top row with 1 pin missing, 7 across the Bottom row.
Top row is numbered EVEN
Starting on LEFT side coming across to the Right, Top row;
Pins 2, 4, 6, 8, No Pin, 12, and 14.
Pins 2 and 4 have a Green area
Pins 6 and 8 have a Red area
No Pin 10.
Pins 12, and 14 have a Yellow area
Bottom row is numbered ODD.
Starting on LEFT side coming across to the Right, Bottom row;
Pins 1, 3, 5, 7, 9, 11, and 13.
No Pin 10.
Pins 12 and 14 have a Green area.
A) Pins 2 and 4 in the Green area (Top left) are for the Power On LED
If the Power On LED is dim when the computer is on, switch the wires around.
B) Pins 6 and 8 in the Red area are for the Power On switch.
C) Pins 12 and 14 are N/C. Not Connected
D) Pins 1 and 3 in the Yellow area, are for the HarDDrive activity LED light.
Pin 1 is for the Positive wire.
E) Pins 5 and 7 in the Purple area, are for a Reset switch, IF a Reset switch is used.
F) Pins 9, 11, and 13 are N/C.
(Pin 9 is 5 Volts DC. Used by the factory for testing)
Regards,
joecoolvette
(I thought the internal speaker was that round little 'buzzer', below the bottom white PCI slot, (PCI 2), and close to the edge of the motherboard )
Nov 01, 2012 | Acer Power S290 PC Desktop
I have installed a new motherboard in an acer case. The power cable from the switch on the front of the case will not connect to the board. Can anyone help? Thank you
You should read the motherboard manual, for cabling:
1. Power SW
2. Reset SW
3. HDD led
4. Power led - and power led +
5. Speaker
Cabling scheme, also written on the motherboard.
If the Power SW not installed the switch on does not work.
If the Reset SW not installed the switch reset does not work
If the HDD led
not installed the hard drive light (red) is not lit
If the Power led (+/-) not installed the power light (yellow) is not lit
If the Speakers are not installed, when the computer is on the beep sound is not heard.
I hope this information helps.
Oct 15, 2011 | Computers & Internet
I had to change the motherboard as it failed
Look at the front panel of the computer you will see the connections you have. Should be power, reset, power led, usb etc. These are connected to your current motherboard and most times all the connections will be labeled in the case, on the wire connector ends. IE the end that connects to the motherboard. The only exception to this is the usb ports, and they can be hooked up to new usb connectors on the motherboard. Also note, read i said READ the proper way to connect the usb to the motherboard, this is usually a one shot deal, get it wrong and you kill that usb connector.
Apr 24, 2010 | HP Media Center M370N (DM163A#ABA) PC...
Can't figure out where to put
Geta flash light and look at the lower right hand corner there you will see where they go. Since you did not include your motherboard type I can not send you a diagram but the pins in that corner will be marked so that you can tell where they plug in. You may need a magnifying glass to read the letters saying hddled,power led,pwsw,reset they also have little lines so that you know which way to turn your plug to plug it in. If this helps you leave rating and feedback thanks.
Feb 21, 2010 | Computers & Internet
How to connect pwrswitch, pwrLED, IDE-LED, reset,
http://www.motherboards.org/files/manuals/1/p4bmx-101.pdf
Here is the manual for this motherboard, and it shows you the pinout for the power switch, reset switch, power LED, HDD LED, and speaker.
Jan 13, 2010 | Computers & Internet
Dell GX270 SATA front panel 34 pin layout
if you are talking about connecting the front chassis connectors to your motherboard then you need to find out the exact model of the MB... im assuming its Intel since its a Dell.
the link below should get you started
http://www.intel.com/support/product.htm
Jun 01, 2009 | Dell OptiPlex GX270 PC Desktop
I tried several different cards but no luck. Cards work ok on other computers.
5V Stand-By Indicator LED
The power supply will always supply a 5V standby voltage to your
motherboard so that it can power on via for example Wake On Lan
technology. This LED shows that your power supply is supplying
this standby voltage to your motherboard.n :D
You may need to replace your power supply, if the LED is flashing, it's not supplying the power the motherboard needs.
[JP-25]
1 2 3 4 5 6 7 8 9
10 11 12 13 14 15 16 17 18
1] Power Led (+)
2] --
3] Power Led (-)
4] --
5] --
6] Speaker (+)
7] --
8] --
9] Speaker (-)
10] Reset switch
11] Reset switch
12] N/A
13] Power Switch
14] Power Switch
15] ACPI Led (+)
16] ACPI Led (-)
17] HDD Led (+)
18] HDD Led (-)
For future reference you can download your motherboard manual here:
(PDF) Soyo K7VKP2
May 09, 2009 | Computers & Internet
Emachines t6522
I assume you are trying to connect the wires from the faceplate to the motherboard. Get a magnifying glass and see if the board is marked as to Power, Speaker, HDD LED, Reset, etc. Trace the wires to the faceplate and note what the function of each pair of wires is and attach to motherboard as necessary.
Jan 17, 2009 | E-Machines eMachines Desktop PC
Reset/power/led etc..lead connections
on most motherboard it is possible to read there to set the wires.
hope this helped a little.
May 15, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
119 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
