Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Coffee is not hot enough
Can i adjust the temperature on a cuisinart grind and brew thermal coffee maker?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 24 Answers
Put it in the microwave to get it to your desired temp!
Posted on Jan 02, 2013
  • 4 Answers
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart coffee maker won't brew
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
Posted on Dec 15, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart Grind and Brew 10
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Posted on Dec 17, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Cuisinart DCC 1150: coffee is not hot enough
Using the 1-4 cup setting will help, but that model does not have an actual heating element in the plate - definitely not the right model for someone who likes very hot coffee.
Posted on Jan 15, 2009
SOURCE: Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Posted on Jan 16, 2009
Overflowing coffee maker
could be using incorrect filters for a different coffee maker, sorry if this sounds obvious but this is the first thing i would think it was unless the water flow is adjustable and coming through quicker than the filter can drain it through
Apr 29, 2013 | Cuisinart Grind and Brew 12-Cup Coffee...
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
How do I clean the Cuisinart Automatic Grind and Brew Thermal coffee maker
I clean mine once a month with 6 cups vinegar and a couple cups of water. also replace the charcoal filter regularly.
Jan 14, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
I have the grind and brew thermal coffeemaker. The water does not get hot enough for steam to come off of the coffee when it is poured.
Hi, I have owned that coffee maker for years.
After it brews coffee, it does not have a warmer to keep it hot. It has a thermally insulated carafe. Such as regular lunchbox thermos jugs have. The reasoning behind this is that coffee heated after it is brewed spoils in a short time. (Of course, unheated coffee gets cold).
What that translates to for you with regard to no steam is this. As soon as the coffee maker finishes brewing your coffee, open the top of the carafe, stick in a spoon and stir it.Then pour it. (I learned the stirring part working in a restaurant).
If you have to wait before you drink it, do the same. Stir it first.
Hope this has been helpful
Love that grinder!
Best Regards,
Mark
Jan 04, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
We have a Cuisinart DGB-900 BC Grind and Brew Thermal Coffeemaker. Our Problem is that the bean grinder has stopped working. We purchased the coffee maker on 2/25/10. Prior to this happening, we were...
try cleaning the grind chute again. if problem persists:
this is a cronic problem with the DGB900BC even after cleaning. the problem is the gate or trap to the grounds needs to open/remain open during grinding or all backs up and jams. my unit opens the door (correctly) during the rotation but closes just before grinding (over-rotation?). Cuisinart is not aware of this problem (800-726-0190). please call them; i just have.
Aug 30, 2010 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
I have the Cuisinart Auto Grind & Brew and don't know how to program to brew stronger coffee...manual lost. Can you provide assistance? I've tried to download manual but can't.
The only way to adjust strength of coffee on the Grind&Brew is by changing how much water you use. The container for the beans only holds enough for 10 cups of coffee.
Aug 04, 2009 | Cuisinart Coffee Makers & Espresso...
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
I Have a Cuisinart Automatic Grind & Brew Thermal that when you start brews a small amount of coffee and then shuts off. I shut off grind and start. After I do that it brews a full pot. We have cleaned...
I have a cuisinart model dgb-600bc coffee grind & brew, didn't have a manual with it when purchased, plugged in it & hit the on button, lights up when pushing in on it, but let it go & it stops, but doesn't brew nothing. HELP -
Aug 26, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
389 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
