Question about SanDisk SDMX1 MP3 Player
I put it through the laundry... twice
The first time i put my mp3 through the laundry I got it working perfectly by letting it dry out, the second time it was at a friends house and it doesn't work any more. When you turn it on the screen is just blank and it doesn't do anything. I figured if i hooked it up to my computer it might work but nothing happened at all, the computer didn't even notice i plugged it in. I let it set for like an hour and it recognized it but the f drive didn't come up. I let it set for another hour or so and a window came up with text saying something along the lines of it was a high speed and the usb connection was not. It also said at the top self repair or something, can my mp3 repair itself or is it broken forever??
  • 85 Answers
Well you are going to need another motherboard. you may have let it dry over, but it still corrodes inside. you have no idea how much damage the water caused, even after drying out. you are going to have to send it in to see how much it is going to cost you. or sell it and buy a new one. thanks, connie
Posted on Jun 25, 2007
SOURCE:
My son's 8gb i pod was in his pants and i did the laundry with it. how can i fix it before he gets back from a trip??
  • When ever you have an electronic item that gets water logged the best thing to do is turn it off and let it sit under a fan until the water dries up. If you turn it on then you may short things out and then it will need some repairs to it. This is at a minimum.
  • If you can remove the cover and remove the battery this will very much so expedite the drying out of the insides.
  • I have provided a link to a video that will show you how to open that MP3 player and remove the battery. This is the most recommended way to dry it if you can get the back off and remove the battery. I would let it set for a good full three days and just let everything dry up. It may be tempting to try it before hand but let it set until it is completely dry. This is the best shot you have at the IPod working again.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 20, 2011 | Apple iPod touch
The clothes simply won't dry. I know it is producing heat because the clothes are warm and the heating element is hot to the touch, but the air that is coming out the back is not hot at all. I have...
The valve resistance is 1995 ohms and the ignitor is 185.
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When the dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
Hold down on the 'More Time' and 'Less Time' buttons and press the 'Power' button. if it comes up with tE1 or tE2 you have a thermistor error.
LG DRYER MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 19, 2011 | Dryers
Hello my dryer doesnt work properly it runs
Problem:
Solution:
LG dryer manual
Dec 13, 2010 | LG D2526 Gas Dryer
Dryer will not shut off in any 'auto' mode. Time display ticks down, then jumps up again and keeps running. Dryer does works properly when 'timed dry' is selected. Checked and cleaned exhaust vent. ...
How long is the vent from the dryer to the outside? Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dry-ability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Jul 14, 2010 | Samsung DV337 Electric Dryer
I have an lg dryer model DLG5966W and the check filter light is on. It takes two cycles to completly dry my clothes. I cleaned the lint filter and still doesnt dry on one cycle. I then removed the filter...
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
Jun 17, 2010 | LG DLG7188 Gas Dryer
Not enough heat
You may need to adjust the air flow on your dryer vent.
Problem:
Solution:
LG DRYER SERVICE MANUAL
LG PARTS
May 11, 2010 | LG DLG5988 Stainless Steel Gas Dryer
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
Apr 01, 2010 | LG DLG5932W Gas Dryer
I dropped my i phone in water and its not turning on?what should i do?
ouch...
leave it alone, and let it dry out, for a couple days. sometimes a hairdryer will work, but you have to be careful with it.
Aug 26, 2009 | Apple iPhone 3G Black Smartphone
Wash and dry ipod 3rd gen
Other people have dried out their mp3 players and got it to work sporadically, but the water damage is irreversible. Call Apple and tell them that it just won't work - don't give them the details of how it got there.
May 29, 2008 | Apple iPod nano 3rd Generation
Wife wash it with the week laundry
My mate washed hers thru washing machine, within 3 weeks of being left to dry out, it worked fine!
Dec 19, 2007 | Samsung SCH-u740 Cellular Phone
SanDisk SDMX1 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
