Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
Getting air in the solution line
Sprays good then drops off then the pessure builds and sprays and drops off
  • Official Brand Answer
  • 315 Answers
Sorry to hear about the difficulty you're experiencing with your ProHeat Turbo. Here's a quick link to troubleshooting steps.
http://www.bissell.com/FAQDetail.aspx?id=1065&cid=ccsocial
Posted on Jan 02, 2013
My neato is showing a message 'my vision was blocked. Please press ok (3000)'. How do I fix this?
Dust off your drop sensors. Using a cotton swab, clean the two drop
sensor windows on the bottom of your Neato Vacuum. Power cycle the unit, removing the batteries if necessary. You should be good to go.
Sep 20, 2013 | Neato Vacuums
Sprayer stop working
if it stopped spraying all lines may be clogged up try taking it apart and clean each line one by one i say one at a time so you dont mix up lines i had same problem when i was fixing a friends 2 main lines were clogged with old soap if unsed for some time that soap build up a grud this should help you can us a small pipe cleaner
Nov 13, 2012 | Bissell Carpet Cleaner Powerbrush Deep...
How do I get a better spray out of the steam vac when using it for carpets - not the attachment hose? can I do some simple maintainence to clean it out for a better spray?
run clear water through the system after each use, as for your problem,, lime deposits build up when left idle and not rinsed, you can run any household lime remover through the unit with Hot water and you should be fine, check for build up at the ports where the spray comes out, and brush with a hard plastic brush
May 03, 2011 | Hoover Vacuums
Wont spray water on the carpet
Same Problem here- The hand piece works fine. Bissell 9500 ProHeat2X.
Both tanks full New Belt on the brushes I can not get cleaner/water to spary when trying to clean the floors.
I've taken my air-compressor and with low psi blown back to make sure teh lines are clear from the spary heads. Still not working...
Apr 17, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell proheat 12amp is not spraying water
Pumps are a very common problem on these units. check pump belt first and make sure spray jets above the brushroll are not clogged. Most likely have to replace the pump. If you need me to walk you through this or need parts let me know.
Apr 08, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
I cant get the water to spray out the bottom
Alot of time if the unit is not properly cleaned out after the last use it get a small clogg in the line If you have or no someone who does have an air compressor. Just open the unit up find the nerest opening to the sprayer assy. with just a little blast inside that line should free up the clogg. good luck.
Nov 14, 2009 | Vacuums
Unit does not spray water for deep cleaning. One can hear the motor running of the ''spray'' action, but no water comes out. I have followed the DVD instructions exactly. Please advise Thanks Anne
sounds like you have an air lock in line before motor. turn unit upside down and disconect hoses. reconnect and try again with plain water. good luck
Oct 27, 2009 | Vacuums
Will not spray solution. Belt is not broken.
Clean out the line were your solution comes out. It sounds like you have a build up of product solution . Check your products you used . Some cleaning product are very sticky. Best of luck Ed.
Jun 18, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell Pump Weak?
Often times I see the pumps clogged with soap when acting like you described. This can cause a pump to be weak. Pressure builds up whe you stop squirting water but tapers off quickly. A few times I've been able to get water flowing good but most times have to replace the pump.
Mar 02, 2017 | Bissell 1699 ProHeat Clear View Upright...
I have a Bissell Proheat 2X Carpet/Upholstery cleaner and I can't get the soap and water to come out of the attatchment. The vacuum part is working, but the spray isn't. I can see the fluid is trying to go...
I have a Bissell "Little Green" cleaning machine that acted like yours. I found several clogs in the fluid system. The power for the fluid in my unit is provided by a small AC motor independent from the vacuum motor attached to a small plastic pump. This pump then fed into the input of the heater. Inside the heater is a sort-of mirror-image, redundant labyrinth that the fluid passes through before it exits. My heater was completely blocked on both sides, and exhibited signs of corrosion. My choice was to disable the heater and to instead hook its output line straight to the pump. I also found clogs in the fluid line, particularly where there were bends. One of the clogs was where the vacuum and fluid line made a right angle turn out of the base of the machine. The other was in the trigger handle itself in a jog of the small line that connects the valve to the spray nozzle connector.
I would suggest examining the trigger handle first. The only thing to watch for is the position of a small flat metal spring with a square hole in the center that lives between the trigger and the valve (which is also sprung).
I made good use of some slightly smaller standard aquarium air line so I could blow water and air through without having to actually taste the internal lines of the machine.
My new resolution is to run clean water through the fluid system before putting it to bed!
Jun 28, 2008 | Vacuums
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
