Question about HP Pavilion a6000n (882780985018) PC Desktop
My hp desktop 6100 wont start and make 4 beeps
I try replace the ram,and after 3 min it shut down.when i try to start the computer it makes 4 beeps
  • HP Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Make sure that your RAM modules and Cmos battery are securely seated on some motherboards Cmos batteries are soldered in. Open computer and reseat memory Sometimes when the computer is moved or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Disconnect all expansion cards If the above recommendations still have not resolved the irregular POST, disconnect the riser board(if applicable) and each of theexpansion cards. If this resolves the issue or allows the computer to POST connect one card at a time until you determine what card is causing the issue. Disconnect all drives If you were unable to determine by the beep code what is failing or do not have a beep code disconnect theIDE, SATA, SCSI, or other data cables from theCD-ROM, Hard Drive, and floppy drive from theMotherboard. If this resolves your irregular POST or generates error messages re-connect each device until you determine what device or cable is causing the issue. In some situations it can also be a loose cable connection that causes the issue. Remove the RAM If you continue to to receive the same problem with all the above hardware removed, disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. ' Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue. Re-insert the memory into the same slot. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick. Try one stick of memory in each slot. If you're able to get the computer to boot with one or more of the sticks of memory it's likely you're dealing with some bad memory. Try to identify what stick of memory is bad and replace it. If you're able to get memory to work in one slot but not another slot. You're motherboard is defective you can either workaround the issue by running the memory in a different slot or replace the motherboard. Power cycle the computer In some situations a computer may have power related issues often caused by either the power supply or the motherboard. To help determine if this is the cause of your issue try turning the computer on, off, and back on as fast as possible, making sure the computer power light goes on and off each time. In some situations you may be able to temporarily get the computer to boot. This should only be used as a temporary workaround if you're able to get this to work. Often this is good for users who may have not done a backup and need to get the computer up one more time to copy files before starting to replace hardware. Disconnect and reconnect the CPU (central processing unit) For users who are more comfortable working with the inside of their computer or who have built their computer one last recommendation before assuming hardware is bad is to reseat the CPU by removing it and putting it back into the computer. Bad motherboard, CPU, RAM, or power supply If after doing all of the above recommendations you continue to have the same issue unfortunately it is likely that you have badMotherboard , PSU ( power supply unit ), CPU, or RAM. The next step would be either to replace these components or have the computer serviced. If you plan on doing the repairs yourself or you are a repair shop it is suggested that you replace the Motherboard first, RAM, CPU, and then power supply in that order or try swappable parts from other computers. Hope this helps.
Posted on Dec 31, 2012
Computer shut off by itself and now wont come back on?
Does it beep? If you know how to install memory try removing all memory then power on do you hear beeping?. Install one of the memory try power on. Make sure CPU fan is working.
Oct 19, 2014 | HP Compaq Presario SR5350F Desktop PC...
HP Pavilion a422n (DW270A) PC Desktop Ok I am having an issue as the pc will turn on then it beeps once then stops. Then it goes into a solid beep. With the screen still on the hp start! What happened...
proberly memoryproblem try change place of memorysticks. RAM
1-4 and 3-2.can also bethe motherboard.try change places whith the RAM-sticks first.
Apr 12, 2013 | Computers & Internet
Computer shut down and red light flashing five times then three second pause and repeats
According to the troubleshooting guide for this model, the red light flashing five times indicates a problem in the RAM (memory), before the video subsystem is ready. You may just need to open the case and make sure the memory sticks are fully locked in their slots. If you just added new memory, it might not match the required specs.
Blank screen and the power LED flashes Red five times, once every second, followed by a two second pause, and the computer beeps five times. (Beeps stop after fifth iteration but LEDs continue flashing.)
Cause Pre-video memory error.
Solution
1.
Reseat DIMMs. Power on the system.
2. Replace DIMMs one at a time to isolate the faulty module.
3. Replace third-party memory with HP memory.
4. Replace the system board.
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c01363877/c01363877.pdf
Jul 16, 2011 | HP Compaq DC5800 Small Form Factor PC...
When I startup my HP 5750 PC, if just makes 5 3short beeps, what is the problem and how do I fix it?
Is it 3 Short beeps? Check your RAM.
I mean, take out the RAM, clean its contacts with an eraser and put it back.
If the problem persists,
If you have many RAM chips, try starting computer with only one chip at a time and thus you can find which one is faulty.
Take the faulty chip and try on some other computer, if same proeblem, that chip is damaged.
Aug 13, 2010 | HP Compaq dc5750 PC Desktop
Fail to start, 4 beep or 5
This site should hone down what you need, tells what the post codes mean.
http://www.computerhope.com/beep.htm
Hope this helps
Mar 20, 2010 | Intel Computers & Internet
I replaced on My Sony VGC-LS25E the HDD from 250Gb to 500Gb reinstalled original Factory System with recovery works ok all day i shut it down like for 30 Mins and turn back on no video only 2 beeps put...
beep codes depend on the brand of the computer you have or on the bios they are using. for sony desktop computers, if you here 2 beeps, it means that there is a parity error. try to reseat the RAM/memory of the computer.
Jan 25, 2010 | Sony VAIO® VGC-LS25E All-in-one Desktop PC...
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
HP COMPAQ D530 RED BLINKING LIGHT WITH BEEPING SOUNDS.
4 beeps & 4 flashes mean problem with the power supply. For my experience, most of the time the PSU is good, it is just overloaded.
For more LED and Beep messages, check this link:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00067072/c00067072.pdf
Dec 26, 2008 | HP Compaq d530 PC Desktop
if it is a long beep then check ur ram, try cleaning ram. if not solved then there may be problem with ur ram try changing ur ram.
if it is short beep and if you have a display card installed check the display card
Installed memory cpu is making a loun beep and wont boot up
Ram is not supported or installed incorrectly, try readjusting it, then reset the CMOS and try again. If ti doesn't work after the readjust make sure that the ram speed etc is supported by your motherboard.
Dec 22, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
HP Pavilion a6000n (882780985018) PC Desktop Logo
74 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
