Question about Panasonic TX-32LXD1 32 in. LCD Television
Panasonic TX-32LXD1 connect to blu-ray with HDMI cable
I have a panasonic TX-32LXD1 which doesn't have an HDMI slot and I have a blu-ray player that needs connecting. Is this possible please? Thanks.
  • 53 Answers
SOURCE: How to connect Panasonic BD60 Blu-ray disc player to 2 components
If there are red and white RCA jacks on the back of the BR player and on the receiver you should be able to get sound. The same as your VHS.
Posted on Dec 29, 2009
  • 380 Answers
SOURCE: My HDMI connection does not work with Blu Ray DVD
After reading your post a couple of times, it just seems your are in a little of a pickle here. The only thing I can suggest, since your tv will work with fios and not the your BD player(I assuming your using the same port on the tv with the same hdmi cable), is all about firmware. Maybe your tv is not compatible with the the BD player. Try updating the firmware on the tv.
Posted on Dec 30, 2009
SOURCE: Diagram to hook up HDTV, Tivo with cable card, and
I did it myself. With 2 HDMI cables, it was easy.
Posted on Jan 20, 2010
moorah1
  • 181 Answers
SOURCE: I need a remote control code to match my BT Vision
Hi, Andrew! Does your remote control have a "code search" mode? Panasonic products are mandatory for all of universal remotes. but, new flat panels are, usually in a special section of your code manual, if you still have it. If not, try to start aut code search procedure and be patient: it might take 10-15 minutes till your set will start to respone. make sure, enter the code to memory, as soon as you see the set took the code. Otherwise? You must start all over.
Posted on Jan 23, 2010
  • 11800 Answers
SOURCE: My Panasonic Viera 50" 1080i
The Panasonic doesn't detect the presence of the signal on the antenna input so it just skips it. shut down the player and turn the cable box on before attempting to switch sources.
But why aren't you using the Composite RCA connection on the cable box ? Not only you would get a much better image but the tv would detect that change in the AV source and should switch by itself. If it doesn't then the control processor is faulty and the entire mainboard will will have to be replaced
Posted on Nov 05, 2010
I have a Panasonic tx-40cx680b tv and a Panasonic DMP-BD75EB-K blu ray DVD player. When I play a DVD the screen is green, it's connected via an hdmi lead. Any ideas?
There are multiple HDMI inputs.
2 HDMI (side and bottom)
3 4K HDMI with HDCP 2.2 on the rear
Try connecting your Bluray player to the side or bottom input.
Here is a link to the specs
https://www.panasonic.com/uk/consumer/televisions/4KTV/tx-40cx680b.specs.html
Dec 14, 2017 | Panasonic Televison & Video
Panasonic tx-48cx400b TV turns off when I connect my Ps4 through hdmi cable. Can anyone help?
Panasonic TX-48CX400B 4K UHD 48 Inch TV (2015 Model ...
www.amazon.co.uk > ... > TVs
Amazon.com, Inc.Buy Panasonic TX-48CX400B 4K UHD 48 Inch TV (2015 Model) at Amazon UK. ...PRO GOLD RED HDMI v2.0/1.4a HDMI Cable 3D 2160p PS4 SKY HD 4K Ultra HD ...This tv offers excellent picture quality through HD sources and Netflix HD and ... TVand PC are both connected to my network switch with Ethernet cables).
for LED TV VIERA TX-48CX400B - Panasonic
www.panasonic.com/uk/.../viera-televisions/.../tx-48cx400b.ht...
PanasonicExplore the Panasonic TX-48CX400B - LED - Uncompromising 4K picture quality is yours with this 4K Ultra HD LED TV featuring an HDMI 2.0 terminal. ... Many describe the 4K effect as feeling more like looking through a window than watching ... Simplyhook up your various devices - such as a Blu-ray recorder or the latest ...Missing: turns ‎ps4
Panasonic VIERA TX48CX400B ' 48 inch 4K Ultra HD 3D ...
Dec 26, 2015 | Panasonic Televison & Video
Denon avr-2113ci hdmi can't change source
Can you update the firmware on the amp as this could also affect the connection between the players.
Jan 15, 2013 | Denon AVR-2113CI
After plugging the hdmi cable, we have the sound but no video
Some ideas:
  • Make sure the correct input is selected for your display device.
  • You may need to change the video out setting on your video source device (Blu Ray player, cable box, etc) to turn on the HDMI output port. See the video source's manual.
  • Devices connected to HDMI are sometimes picky about the order they turn on. Try turning off the video source and video device, then turn on the video source, wait a few seconds, then turn on the display. If that doesn't work, try reversing the order that they are turned on. If this is the problem, you can buy a universal remote, like the Harmony, that will start devices in a specified order.
Feb 12, 2012 | Panasonic DMPBD655 Player
How do I connect a sony BDP-s350 blue ray player to a onkyo tx-sr803 7.1 receiver with the hdmi cable?
Connect HDMI cable from the rear panel of the blu ray player to the DVD/IN digital section, labeled as "HDMI/IN" on the rear panel of the receiver.
Jan 01, 2010 | Onkyo TX-SR803 Receiver
1080P video via HDMI generates awful interference
Your Plasma's native resolution is 720P. Go into the Blu Ray's output setup. you can choose 480p 480i 720p 1080i and 1080p. Set it for 720p that should clear up the issue.You may have to run Component directly to the TV since you only have 1 HDMI input and you can run Digital coax or optical to your AV receiver for audio. On a 50" TV the difference between 720p and 1080p using "GOOD" cables cannot be seen by the human eye. Above 50, yes it is noticeable.
Hope this helps.
May 22, 2009 | Onkyo TX-SR705 Receiver
HDMI connection with Panasonic DMP-BD35K Blu-Ray Disc Player
Try hooking the Panasonic up straight to the tv without going through the receiver. If it displays a picture its obviously not the blu-ray player. May also be a problem with the HDMI cable itself. Hope this helps.
Jan 04, 2009 | Onkyo TX-SR506 Receiver
Connecting blu ray to surround sound receiver to tv
Hi, I have just completed this installation myself.
You are correct, HDMI to Amp Input from Bluray and then HDMI from Amp output to TV. Coloured cables are not required to operate the bluray now.
Good luck
Jan 02, 2009 | Onkyo TX-SR606 Receiver
What Blu Ray to buy for ONKYO TX-NR801 for Dolby TrueHD, etc???
Hi, as the Onkyo receiver you have does not have HDMI switching, the only thing it will do for you with a Blu-Ray player is process the audio signals.  The video from the BR player will have to go directly to an HDMI input of your hi def TV.  In this case, either Sony or Panasonic BR player will be equal.  Assuming you keep the Onkyo unit you have, you would want to use the optical digital output from the BR player as the audio source into one of the optical, digital audio inputs on the Onkyo.  In an ideal world, your receiver would some that does do HDMI switching.  This way, all the audio and video signals from any audio or video source would be automatically switched and channeled through 1 simple HDMI cable into your hi def TV.  This will make you life simpler as ther would be no need to select an appropriate input on the TV, as well as one on the receiver.  That said, buying a new receiver in addition to a BR player is more costly.  Good luck.  Let us know how it goes.
Jan 02, 2009 | Onkyo TX-NR801 Receiver
Panasonic TX-32LXD1 32 in. LCD Television Logo
50 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
