SOURCE: Fuel filter location Sierra
I have been told by a mechanic that the fuel filter is inside the fuel tank. Have to either drop the tank or remove the pickup bed. Access is on the top of the tank. This is poor engineering.
SOURCE: 2003 GMC Sierra Knock sensor and oil pressure??
the knock sensors are located below the intake plenum,or,upper intake manifold as some call it, they screw into the lower intake, the front one is sensor 1, the rear is sensor 2. it is wise to change both if you have some miles.since you are going to be buying a gasket set to do this job.the sensors are cheaper than the gaskets.
SOURCE: 2000 gmc sierra 1500 5.3 v8. a/c heater control problem
your heat/cool and vent selection options are controlled by engine vacuum through small clear tubes attached to the rear of your climate control interface. Other vehicles have small steel pull wires that operate the desired changes. You might try removing the trim and any fasteners affiliated with the interface/console. GENTLY pull outward and look to see if any of these tubes are pulled off or cut/damaged. Did anyone recently install a new stereo in the vehicle? If so, the vacuum tubing and or pull wires that change your outlets could have been damaged when the stereo unit was pushed into place. Hope this helps
Testimonial: "Very good information. THANKS!"
SOURCE: freezer ok refrigerator not cold we changed the
feel door seal after door has been kept closed for a quite a time.If it feels warm at any one spot door seal needs replaced.adrian;;;;
