Question about Samsung ML 2010 Laser Printer
Red online/error lamp printer ml-2010r
With power off and on again: the red lamp keeps lighting.
Prob after I pushed the cancel button.
This button do not works good, when i press on it I need to let it
return with a paperclip .But even button is in normal position
and power off and on again the red lamps light continiously.
No printing possible.
thx for your answer
  • MadBel Jan 31, 2009
    The printer is 'ready' but doesn't print. There is the 'online/error' light on.
lolita
  • 385 Answers
SOURCE: error msg
Hi Usually with this printer, you just simply turn it off and then on again and the lights will stop flashing. This is an LSU (Laser Scanner Unit) error. If you still have the problem, it might be either the LSU needs replacing or it could be the main board. These parts might be scarce though and very expensive. It might almost be cheaper to buy new printer but that is up to you to check and decide for yourself.
Posted on May 25, 2007
SOURCE: online/error light
Pull out the toner cartridge. Carefully put your fingers into the opening just beyond the chrome roller. A little to the left of center you will fell/see a small black plastic finger which sticks up. It should be loose - push it forward and it springs forward, release it and it returns to the original position. If your paper jam catches this finger it can become jammed and will feel rigid. Put light pressure on it either pushing to the back or pulling forward until it becomes free again. Replace the toner cartridge, close the cover and your red light should go out.
It worked for me - hope it helps someone else.
Mary Lou
Posted on Oct 22, 2008
SOURCE: ML1610 SAMSUNG PRINTER PROBLEM
The online/error light is always red, and I can't print. I turn the printer off, change the toner and the light is still red, what can I do
Posted on Feb 05, 2009
SOURCE: In my printer power is on and red light will appears
I have to install this printer in xp professional o.s.
than what can i do now
Posted on Mar 22, 2009
SOURCE: Samsung printer ML 2510 series
Maybe the toner is low... According to the manual, a blinking red light:
• A minor error is occurring and
the printer is waiting for the error
to be cleared. When the problem
is cleared, the printer resumes
printing.
• The toner cartridge is low. Order
a new toner cartridge. You can
temporarily improve print quality
by redistributing the toner. See
page 8.3.
• The toner is totally exhausted.
Remove the old toner cartridge
and install a new one. See page
8.4.
• The toner cartridge reached the
end of its life.
Posted on Apr 18, 2009
ERROR CODE 5800
Follow these procedure
1. Turn off the canon printer.
2. Hold button Resume/Cancel (red triangle in the circle), click on POWER - an indicator light green.
3. Release the button Resume / Cancel keeping POWER.
4. Click Resume/Cancel 2 times, keeping POWER, and then release all the buttons.
5. When the indicator recorded GREEN - click Resume / Cancel 4 times!
6. Turn off the printer POWER button.
7. FINISH
I think You will be relif from your printer problem.
Thank you very much.
Jun 05, 2011 | Canon Pixma MP500 All-In-One InkJet...
When I want double sided printing with samsung ml2010 printer, the online error stay red after one side is printed. Then i can do nothing but turn off the power button. it goes well when one sided...
I solved it!! Just hold down the Cancel button and I think it acts as the OK button. The red light will go away and turn green and it will print the odd pages. There you go!
Dec 18, 2010 | Samsung ML 2010 Laser Printer
Samsung ml1640 laser red light blinking
samsung ml1640 laser red and green light blinking continuously and printing not happening
Jul 02, 2010 | Samsung ML-1640 Monochrome Laser Printer
My ML1610 Samsung printer is not working. The red and green light are blinking simultaneusly and cancel button is struck. How can I set it right?
Dec 15, 2009 | Samsung ML 1610 Laser Printer
Last week i tried to print but it didn't work and appeared 5100 error. i have the pixma mp 170 printer... i don't know how i can fix it
Hello
The manual states that the error code 5100 is a result of:
Service error 5100 is displayed
Cause: Movement of the FINE Cartridge Holder is blocked.
Action: Clear the paper jam or foreign object that is preventing the FINE Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
You might see something blocking the printer head, check inside to see if there is a paper jam, staple, or some other object blocking the print head.
If this does not work, try resetting the device:
  1. Turn the printer off.
  2. Hold the button Resume / Cancel (red triangle in the circle), click POWER - indicator lights green.
  3. Release the button Resume / Cancel, keeping POWER.
  4. Click Resume / Cancel 2 times, keeping POWER, and then release all the buttons.
  5. When the indicator light Green - click Resume / Cancel 4 times!
  6. Turn the printer off button POWER.
Hope this can help you.
Best regards
Andrea
Oct 20, 2009 | Office Equipment & Supplies
Red light blinking, first orange then red, toner blinks green
dear sir
  1. it is problem paper miss feed
  2. over temparature
clean thermostator.thermostator over dry toner
or cartridge assembling problem
Aug 04, 2009 | Samsung ML 2010 Laser Printer
Online/Error
this could probably caused by interrupted spooled jobs that was sent earlier, as i assumed, try pressing the cancel button on the printer itself, or from your pc cancel all documents.
if you cant recover still reset the printer once again and put some paper to finish the pending job that was qued earlier
Jul 25, 2008 | Samsung ML 1610 Laser Printer
Samsung 2010R
Hey there TUPOKIKE,
Printers can be very frustrating at time. But luckily, you can get updates drivers from the manufactures website. ML2010R is located here,
http://www.samsung.com/us/support/download/supportDown.do?group=printersmultifunction&type=printersmultifunction&subtype=monochromelaserprinters&model_nm=ML-2010R/XAA&language=&dType=D&mType=DR&vType=R&prd_ia_cd=06010400&disp_nm=ML-2010R/XAA
Select which ever one matches your operating system. That will begin downloading the driver.
Hope this helps.
Nov 27, 2007 | Samsung ML 2010 Laser Printer
Online/error light
Mary Lou
Aug 31, 2007 | Samsung ML 1610 Laser Printer
Samsung ML 2010 Laser Printer Logo
929 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
