Question about SanDisk 4GB microSD High Capacity Memory Card
When i am insert the memory card into my mobile it is asking to format the card..how can i get my data from that card?
  • akashbarla
    akashbarla Jan 02, 2013
    memory card is not showing when i am connected to pc
  • akashbarla
    please get me a solution fastly
  • SanDisk Master
  • 27,725 Answers
A few important bits of information about using faults and fixes on usb drives w7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts Click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box (I have found better results ticking the first box then reurn and tick the second box) you should not do anything while the chkdsk utility is in progress any input may damage this drive also you might need to do this Click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7 Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
you might have restore it to its defaults Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP Right click on your drive select properties then on customize restore Default in W 7 If you need more help with this post a reply Hope this helps.
Posted on Jan 11, 2013
pctech1
  • 1940 Answers
SOURCE: sandisk micro sd card forget password in nokia
Try putting the memory card in your PC and formatting it from My Computer.
If you have a camera that takes this kind of card, you can try to format the memory card from there as well.
Posted on Jan 26, 2010
  • 44 Answers
SOURCE: i cant format 2 gb sandisk memory card in my pc,
I would suggest that you have a corrupted inaccessible memory card. Your card is damaged and won't function properly.
Posted on May 29, 2010
HeLpINHaRrY
  • 210 Answers
SOURCE: my2gb sandisk micro sd card
most likey it is a faulty card . or a cheap counterfeit . i had same problems and only a new card was the solution
Posted on Aug 02, 2010
IceCake
  • 68 Answers
SOURCE: how to format my corrupted
If you a using a card reader that plugs into your PC and it STILL doesn't read from the card, this means that the card itself is defective and needs to replaced. You CAN try using another card reader to see if that helps.
Hope this helps. :)
Posted on Oct 02, 2010
Manish32
  • 70 Answers
SOURCE: I brought a SD 2GB
This memory card is corrupted please change this memory card by dealer where u brought this card.
Posted on Nov 06, 2010
I am using N73 mobile, once it just fall down, whenever I insert card into mobile it shows msg like
Get EASEUS Partition Manager. It's totally FREE and an awesome Program for formatting and manipulating hard drives. It's very easy to use.
You can get it here: www.partition-tool.com/
Jul 10, 2012 | SanDisk 2GB microSD Memory Card
Memory card formatting
Hi
how to want to format you Memory card through Mobile and through computer. the both way i describe you let chose which one you look easy.
Through Mobile.
Switch off the mobile and Insert your memory card in mobile.
Step 1.
Press the white menu button.
Step 2.
Select "Applications".
Step 3.
Select "File mgr.".
Step 4.
Double-click on "E: Memory Card".
Step 5.
Select "Options".
Step 6.
Select "Memory Card Options" and then "Format".
Through -PC
Formatting your memory card, flash drive or device:
1. Double-click My Computer, or Computer (for Vista)
2. Right-click the drive letter associated with your memory card, flash drive or device, then select Format
(in the sample image below, we right-clicked on H:)
WARNING: Make sure you select the correct drive letter.
3. Select a File system type.
NOTE: Select FAT32 for 4GB or higher capacities. FAT for 2GB or lower capacities
4. Click Start.
Memory card info and old cameras
Many previous old cameras and portable devices do not work if the card is formatted as FAT32 or NTFS file system. One of the following errors may occur if your device does not support FAT32 or NTFS:
- Error message asking to re-format the flash card.
- Error message that the flash card is not formatted.
- Error message indicating that the card is anomalous.
To resolve the above error, backup your data and reformat your memory card in FAT file system.
If the error persists, re-format the memory card using your camera or portable device.
Aug 02, 2011 | SanDisk 1GB microSD Memory Card
PNY micro small piece inserted in mobile phone and adapter to the computer, but not copy mobile phone pictures to the computer.
for reliability buy a dedicated micro sd reader as not all the adapters work.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Mar 01, 2011 | PNY 2GB microSD Memory Card
My memory card is showing to formate when i placed in my mobile.. i need the data present in it how do i get the data..?
if you have a computer with a card reader, insert card in slot, copy info to a folder, then format card fat 16 and copy info back on card
Dec 23, 2010 | SanDisk 2GB microSD Memory Card
When i insert memory card i cant able to transfer datas to card from mobile. error RETRY or DATA will b lost
Please try reformatting the memory card before transferring data to it. Card format could be incompatible with your phone. You may find Reformat option in one of the utility menus of your phone.
Oct 23, 2009 | Nokia 7610
Nokia 5300 mobile not reading memory card, though it works fine on other mobile and PC
Try to format your memory card on a pc. after formatting, try putting some songs or any other data on the card from PC and then insert it on to ur mobile phone.
If is still does not work on mobile then you need to contact Nokia as the card is working fine.
May 25, 2009 | SanDisk 2GB Secure Digital Memory Card
My Memory card has locked after formating my Ohone momory.
A standard "unlock code" for memory cards would be something simple like 0000.
Nov 08, 2008 | Nokia N70 Cellular Phone
Memory card of nokia n72
its better to buy a new cellphone and memory card mama
Feb 13, 2008 | Nokia N72 Cellular Phone
SanDisk 4GB microSD High Capacity Memory Card Logo
43 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
