Question about Xerox XG-91D 19" LCD Monitor
Ridiculously easy to burn-in???
Hey there, is it just me or is it incredibly easy to burn images into this particular monitor? funny because i have had this monitor for just a little over 2 years, and things have just started happening in the past couple months. it's become ridiculously easy to burn images into this monitor now, like if something's left on screen, within 5 minutes an afterimage will be there. even the ICONS ON MY DESKTOP and my WALLPAPER burn in after awhile. that CAN'T be normal. i've basically had to give up using maximized windows for browsers and working on photoshop and such. it's gotten to be such a pain because i'm so paranoid about the mish-mash of burned-in crap that will tattoo my monitor. before i receive dozens of suggestions for jscreenfix, rest assured i've tried running the jscreenfix program several times overnight (about 8-9 hours a night) already, and it's helped some of it, but there are still there thick, tinted bars (not very noticable, but i can sometimes see them if i'm watching a DVD on my computer), as well as the "file, edit, view, etc" menu bar from when i use a maximized window. somebody PLEASE HELP!!!! :( :( :( :(
  • Dan Wong Jun 26, 2007
    well, thanks compuguy44. but the burned-in images stayed no matter how low i turned the brightness and contrast.
    now i'm reading that burn-in has to do with the liquid crystals in an exaggerated state of use, and if i leave the monitor off for a few days, it could go back to normal. which is pretty much the exact opposite of the jscreenfix idea, which is to leave that flickering screen on for hours, or even days at a time.
    i really don't know what to do, and i don't want to buy a new monitor because i just don't have the budget for it right now. ugh. keep posting suggestions, guys.
  • 432 Answers
Turn the brightness and contrast down on the monitor.
Posted on Jun 24, 2007
SOURCE:
Samsung monitor 204b screen image is split in to two parts; the upper part OK but lower part is gibberish, ghosty?
Interference. Separate the wiring so it doesn't touch. Touching wires create cross-talk of signals and keeps from running normal.
Feb 11, 2014 | Samsung Computers & Internet
My viewsonic vx2025wm 20.1 lcdmonitorgoes green,sometimesyellow,then returns towhite screen
check your cable connection if the color changes.. as normally bad or lose display connection will cause this problem..
but if it turn to total white without any image.. then most probably the LCD monitor is faulty..
but there are some cases when your display card that is giving this funny problem.. if it get too hot.. check your PC display card whether the cooling fan is turning or jam.. this is the main cause the display card get overheat and give you funny display...
May 23, 2010 | HP Computers & Internet
What is a LG W2241T monitor driver and where do I find it?
Hey. you can get the drivers at the following site:
http://www.lge.com/us/support/product/support-product-profile.jsp?customerModelCode=W2241T-PF&initialTab=warranty
however, according to the manufacturers, that particular product is now discontinued. So i'm not sure how long they would continue supporting drivers for that particular monitor for future operating systems. Hope this helps.
Oct 04, 2009 | Computers & Internet
Image stretched
No offense, but if you're an IT ignoramus, you should know how to fix this. I see you said 2 monitors, did you see that you could've added display to the second monitor making it look out of proportion? A simple fix is either adjust resolution, disconnect second monitor, or you could do the hardest one, test every single component related to display until you find the problem. Good luck with the last one,if you come down to it.
May 07, 2009 | Dell Computers & Internet
IMAGES
"Burn Image" means a disk image, not a picture. You can burn JPEG files as a data CD.
Mar 24, 2009 | Roxio Easy Media Creator 7
Bd p1400
The latest upgrade is ver 1.9. It is a downloadable ISO in zip file format. Samsung recommends Nero to burn this. Burn this to a CD-R not a DVD. I also suggest burning at a slow speed... IE 10x and trying high quality media IE .... Verbatim. 90% of the problems are related to poor quality media or too high a burn speed. This disk has to be highly accurate for it to work correctly. I've updated over 40 of these particular players.
Oct 26, 2008 | Samsung BD-P1400 Blu-Ray Player
Sino gusto funny scandal ust pm i not show start button and messages ,images,system is so slow
when i was chattig witha i got a link when entered the link then i started facing the problem like .how can i get rid of this problem
Apr 10, 2008 | Samtron MONO TTL 13 Monitor
Dell 19" Monitor - Dead
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After it went blank, you have to check that you can see the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like mine, I can see window image using flashlight and check lamps inside. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Thank you,
Tan
Mar 15, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Monitor Image Partially Freeze and PC Stop working
Hey, sounds like your videocard is about to fail. the only option now is to replace the card with another.
The card is damaged. Possibly overheating have you cleaned your pc recently? Might be full of dust and burned.
Feb 13, 2008 | ATI RADEON® 9600 Pro, (256 MB) AGP Graphic...
JVC Everio Share Station DVD... Problem
hey
since your everio doesnt look like it has any firmware updates and all, it might be a good idea to use the warranty for that.
Jan 27, 2008 | JVC Everio Share Station DVD Burner Burner
Xerox XG-91D 19" LCD Monitor Logo
104 people viewed this question
Top Xerox Computers & Internet Experts
Aditya Agarwal
saurav777
Level 1 Expert
Jim LeVerso - IT...
Jim LeVerso - IT...
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
