Question about Maytag Performa PAV3200
If I put soap in fabric softner spot can I just add water and let it drain out?
If somebody accidentally puts detergent in the fabric softener spot can you then just add water to make the detergent drain out then wash normally? Where does it drain too when you overfill? If it drains in to the machine then I do not have to add more detergent.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 31 Answers
You could remove it and clean it out. Or you can add water a few times and put it in a spin. It will only release in the spin cycle.
Posted on Dec 31, 2012
4 Suggested Answers
  • 1294 Answers
SOURCE: Fabric Softener won't dispense
Suggestion: Possible your inlets to the machine is blocked. Check out the inlet tubes to clear out any blockages. This shd be done after the machine is off and the inlet valve is turned off. Some softeners are thick; you can add warm water 1:1, but this is not the thing in your case....
Posted on May 28, 2007
buffalonyman
  • 1865 Answers
SOURCE: Cant figure out where to put the laundry detergent in the maytag
This link will take you to the manual for your washer. Page 6 discusses where to add soaps and softners
http://shared.whirlpoolcorp.com/assets/pdfs/literature/6_2727060.PDF
Posted on Jun 02, 2009
SOURCE: MAH8700AWW - No Fabric Softener
Not sure if you've ever resolved this issue, but I'm dealing with it myself. I have come across this service manual that gives a very detailed illustration of the systems, how it works and how to test it.
Focus on pages 15 thru 25. Hope this helps you.
http://www.servicematters.com/maytag_library/docs/16026126.pdf
Posted on Dec 08, 2009
Fabric softner will not when it reaches its cycel
Look Inside the compartment where you put the softener in. Above are holes where the water comes down into the compartment. They sometimes get clogged. Use a pick or q-tips to clean the holes. A temporary solution if that doesn't work, you will have to add softener manually into the soap compartment at the time when the softener should be dispensed.
Feb 21, 2016 | Whirlpool Washing Machines
Htwp1200doww where does fabric softner go
You have to do it manually. Ugh. See below from manual:
Liquid Fabric Softener (Manually add during rinse cycle)
1. Turn OPTIONS knob to FABRIC SOFTENER
2. Measure liquid fabric softener carefully, following instructions on the bottle, and add during the rinse cycle.
OPTIONS (on some models)
Set this option when planning to manually add fabric softener during the rinse cycle or when you use extra detergent or bleach to clean hazily soiled items. It provides an enhanced rinse.
Oct 04, 2012 | Hotpoint Washing Machines
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
My top load Kenmore Elite Oasis which is 3 years old leaves particules that look like grease from the fabric softner on my clothes after being washed. Is there a way to clean out the residue left from the...
Kimberly,
I would use Dishwashing detergent and hot water, (not dishwashing Soap - different). The detergent is low sudsing and will help remove the softener, but it must have Hot Water to work. For the future you will need to dilute the fabric softener with water to prevent it from building up.
Good Luck
Sep 10, 2011 | Kenmore 22422 Top Load Washer
Adding liquid to rinse cycle
on your h-3 the soap disp tray will allow you the add powder ,liquid, bleach, or fabric softner at the time you put soap in disp then the water valve will dispence at proper times in the wash cyc you don't have to stop the wash cyc
Aug 26, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Stains
Apparently the residue is fatty buildup from fabric softener. Try filling it up with the warmest water possible and add some bicarb to dissolve it, then rinse a few times to get it out of the machine completely. Then use vinegar instead of softener for most washes, or dilute fabric softener with water 1:4 and occasionally rinse with bicarb. This works for me.
Oct 20, 2008 | LG WFT1071TP Top Load Washer
Fabric softner is building up in dispenser
Same deal - I have to soak up all the residual water in the softener dispenser between washes. (The detergent and bleach compartments are fine).
Jun 13, 2008 | GE WSXH208A Front Load Washer
Problems with fabric softener
check the water solenoid for open circuit, this is the water valve that supplies water to the compartment
Sep 28, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Fabric Softner section won't fully drain....
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 14, 2007 | LG WM2688HWM TROMM SteamWasher
Washing Machines Logo
121 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
