Question about Maytag Neptune MAH6500A Front Load Washer
Maytag Neptune MAH6500AWW Has No Power
Rear Mounted Display Does not come on.
  • 1073 Answers
SOURCE: maytag neptune modle MAH6500AWW
it is saying locked rotor situation, could be a loose connection at the main board, at the door switch or the motor is bad, bet motor kit # for motor and board 12002039 good luck with the repair
Posted on Apr 12, 2008
sdmc73
  • 121 Answers
SOURCE: maytag neptune washer display showing FL
fl is a over fill. clean the pump out and the sump near the pump is in the back the dran hose goes to it
Posted on Nov 30, 2008
localwonder
  • 6784 Answers
SOURCE: my maytag neptune washer will stop working and
HI, this error code is signaling an issue with the fill actions. Your washer seems to be having problems when it try's to fill the tub with water.
First, make sure there's water getting to the washing machine. Make sure the water faucets are open all the way.Check for kinked hoses as well.
If the hoses are fine and, the faucets are fully open, this will confirm a inlet water valve malfunction. you will need to replace this failed component in this case. it has failed.
Posted on Jun 17, 2009
SOURCE: My maytag neptune front load washer (MAH6500AWW)
control board bad
Posted on May 06, 2010
  • 414 Answers
SOURCE: Smelly clothes after washing.
I have this problem with my Siemens machine, it is due to mainly running low temp washes and bateria building up in the hoses etc. (more prevalent if the machine is connected directly to the sink and not on a stand pipe). I run a 90 degree cycle every 4 weeks with the machine empty except for two capfuls of baby sterilisng fluid (approx half a mug) I buy stores own as it is cheaper than miltons. The first time I did mine I ran the cycle twice to be sure it was cleared out. My machine is six years old and the first smelly signs were when it was about a year old, I run the maintenance wash religiously ever 4 weeks and run a machine descaler such as oust thru every 4-6 months. Hope this helps. Roni. (ps don't be tempted to use bleach as it foams up and can cause more problems!!)
Posted on Jul 06, 2010
What size washing machine is this
Your Maytag Neptune MAH6500A Front Load Washer has dimensions:
Width : 27"
Depth : 29"
Height : 42 1/2"
Capacity : 3.34 cu. ft.
http://www.ajmadison.com/cgi-bin/ajmadison/MAH6500AWW.html
May 22, 2014 | Maytag Neptune MAH6500A Front Load Washer
How do I check the drain pump on Maytag neptune washer
I have a matag front load washer MAH6500AWW the door won't lock it just clicks
Apr 07, 2012 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag Neptune MAH6500AWW mOdel. Less
YES YOU CAN , CONTACT PLUMBERS SUPPLIRES WITH MODEL NUMBER OF MACHINE AND MAKE FOR BERINGS WHEN YOU HAVE THEM YOU CAN START, FIRST MAKE SURE POWER IS OF THEN LOCATE SKREWS IN THE MACHINE PANEL, REMOVE AND OPEN PANEL LOCATE BEARINGS AND REMOVE BRACKET HOLDING THEM IN AND REPLACE NEW ONES , IF YOU OPEN MACHINE AND HAVE A GOOD LOOK YOU WILL FEEL MORE CONFIDENT, GOOD LUCK.
Oct 22, 2009 | Washing Machines
MAYTAG MAH6500AWW-WASHER WILL NOT AGITATE/SPIN
This is a frontload Neptune. I think you will find that the motor control located in the bottom right front of the cabinet is bad.
Feb 07, 2009 | Compaq Presario 5000 PC Desktop
Maytag neptune modle MAH6500AWW
Apr 12, 2008 | Maytag Neptune MAH6500A Front Load Washer
Maytag Neptune MAH6500A Front Load Washer Logo
29 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
