Question about Sewing Machines
ON my new Singer sewing machine, the handwheel is now stuck, after I wound the bobbin thread. Why is it not moving, after I changed the handwheel to engage with the needle?
  • Sewing Machines Master
  • 1,564 Answers
Take it back. New Singers are known for having problems. Upgrade to a Babylock.
Posted on Jan 01, 2013
SOURCE: Not picking up the Bobbin thread
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
Posted on Nov 17, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
Mongo32
  • 111 Answers
SOURCE: Sewing machine will not pick up bobbin thread.
needle's in backwards
Posted on Jun 11, 2009
Mongo32
  • 111 Answers
SOURCE: singer sewing machine, needle will not pick up bobbin thread?
needle in backwards?
Posted on Aug 23, 2009
  • 96 Answers
SOURCE: needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Posted on Dec 13, 2009
Needle shaft stuck. Machine won't work.
It's possible that you have threads wound somewhere inside the machine. Likely places are the tension unit and near the hand wheel.
Sep 17, 2015 | Singer 6038 Mechanical Sewing Machine
I just brought home a Juki 8700. The needle went down and now I can't get it basck up. There is thread stuck in the bobbin. How do I get the bobbin casing off
Cut the thread above the needle eye and rock the handwheel back and forth sharply to cut the thread with the sewing hook. If that doesn't work pretty promptly, undo the needle clamp and turn the handwheel, which should raise the needle bar. Then get into the bobbin case area and try to remove the bobbin case, cutting any threads you can. Keep rocking the handwheel and trying to pull out the needle (pliers help!), and eventually everything will loosen up.
Next, clean and lubricate the area under the needle plate and the shuttle, and reassemble. Put in a brand new needle, right way around and fully up in the machine. Load the bobbin case with a well-wound bobbin, and rethread the top of the machine and you should be good to go.
Jan 28, 2014 | Juki DDL-8700
New Singer 1507- handwheel is stuck.
The bobbin might have a bunch of thread off it inside the compartment here the bobbin is. Also, make sure it's thread correctly, that can goof things up to.
Jun 15, 2017 | Singer 1507
Handwheel stuck
most likely the bobbin thread is wound around the components.
remove the bobbin and check for a mass of thread cut it all away and remove every last bit then it should work
Dec 28, 2013 | Janome Hello Kitty 11706 Mechanical Sewing...
The machine sews normally then once in awhile the material gets stuck in one position, does not move. The bobin thread seems to be a bit tangled in the bobbin case. What is going on?
Your bobbin may be wound uneven, try winding a fresh bobbin and make sure that you are using the same weight thread in the top and bottom. And try a fresh needle.
Oct 08, 2010 | Singer Inspiration 4205 Mechanical Sewing...
New singer 7469 won't sew . it will not pick up the bobbin thread I have changed thread, needle, bobbin I have re threaded it
Check the needle to be sure it was properly installed - usually with the flat side of the shaft facing the back of the machine.
Hold onto the thread tail at the needle and lower and raise the needle with the handwheel (not the power pedal) to lift the bobbin thread.
Take both thread tails under the presser foot and to the back of the sewing machine before starting to sew.
Feb 19, 2010 | Singer Sewing Machines
I have a Singer Special Zig Zag Model 418. I can
More than likely you have a broken vertical shaft gear.
When you turn the handwheel you should see the sewing hook moving under the bobbin case.
If not, take it to a sewing repair person and it should cost somewhere around $100 to repair.
Aug 20, 2009 | Sewing Machines
The machine stopped during sewing
Thread is caught in the hook...Remove the upper thread and bobbin case, turn the hand wheel backwards and forwards by hand and remove the thread remands. Good Luck
May 11, 2009 | Singer Featherweight 140Q
Sewing Machines Logo
181 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
