Question about Tacony LauraStar MAGIC i-S6 Ironing System JYLS-S6
Laurastar iron not pumping up water - Tacony LauraStar MAGIC i-S6 Ironing System JYLS-S6
Iron will not heat up
See the causes and proceed according, fix it. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord. Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
Sep 23, 2012 | Unknown LAURASTAR PREMIUM S3 Ironing...
I fill the reservoir before beginning ironing and after I finish ironing there is almost the same amoount of water left in the resevoir. The only time I can spray water is when I press one of the spray...
Hi nananmm,
Try flushing the iron and clearing the holes by filling the iron with a mixture of half white vinegar and half water. Set it for steam and let it sit on an old cloth for about 30 minutes.
This should flush out any buildup in the iron and holes.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jun 13, 2011 | Vacuums
I need instructions on how to clean Digital Advantage Iron. I have lost my manual.
any iron can be cleaned by running a little water and vinegar through it several times, it loosens the scale build up that gets in all irons over time, be sure and try to clean out the venting steam holes in the face of the iron, Once you do this, run clean clear water through it and you should be fine, if possible, always use bottled water (purified) water in irons
Jun 02, 2011 | Vacuums
Somewhat new_ leaking dark water on white shirt- washed then repeated
I stopped vacuuming my shirts ages ago, and mostly everyone else did, so I assume you're talking about an iron?
The dark water is just tap water that was sitting inside the iron and caused it to rust.
After you rinse the iron several times with distilled water, keep using distilled water from now on.
It's about $1.00 per gallon and you can buy it in any supermarket.
When you use distilled water in your iron, there is no need to empty it every time you're done with the weekly ironing.
Jun 01, 2011 | Vacuums
Often when ironing, the iron{tefal aquaspeed 160] will spit dirty water on whatever I'm ironing.are you supposed to use botled water in iron?Aren't tefal irons made for tap water?Also how do you stop iron...
Try using CLR cleaner, if not just buy a new one, and keep the receipt for a return down the road, these iron's are reasonable nowadays.
Apr 25, 2011 | Vacuums
How do I clean my iron?
I am assuming that you have scale or lime build up on your iron. Make a solution of half white vinegar and half distilled water. Pour it in the water container on your iron. Turn your iron on its highest setting and set for steam. Wait about 15 minutes and turn off the iron. When water cools pour off the remaining water/vinegar solution. Fill the iron with distilled water and turn on. Let it heat and then cool then pour off that solution. Do this till the poured off water runs clear. If you have scale on the bottom of the iron you can clean that with an old toothbrush dipped into warm white vinegar. There may be easier ways to do this but this is eco friendly and it works the best of anything I have tried.
Apr 08, 2011 | Vacuums
How do i clean my iron so brown dirt won't come out of it when i iron
Brown water and white scale are often the result of the water you use in the iron...
If you have scale, white vinegar will clean that...
For brown water, empty the iron, rinse out the insides with bottled water,
and then use the bottled water instead...
Also check out this tip...
Cleaning a Steam Iron White Scale and Brown Water
heatman101
Mar 23, 2011 | Sunbeam Vacuums
MY IRON IS NOT THAT OLD AND IS LEAKING RUST, WHAT CAN I DO?
You must always use Distilled Water in the iron. Try running a few cups of the distilled water through the iron. Iron on something you don't mind being ruined from the rust. It sometimes will flush the rusty out. If it is old and you've been using tap water the whole duration of using it you may need to purchase a new one. Good Luck!
Feb 14, 2011 | Vacuums
My Sunbeam Pro Stream II Teflon shot and spray iron consistently spits water as I try to iron. I don't overfill it and the temperature and steam dials are set correctly. help!
How old is the steam iron?
And what type of water have you been using in it during its life?
The reason I ask, is that my Wife's was doing this, and we have fairly 'hard' water,
and she was using water directly from the tap.
After a year or so of this 'hard' water, calcium and minerals build up in the heating chamber in the iron-- Also passageways get clogged, and instead of smooth flowing steam, you get build-up of pressure, and then sputtering and spurting take place, as the clogged passageways try to pass the steam to where it needs to be.
Tell us more--
Mack B
Dec 28, 2010 | Vacuums
Theres water pouring out of my t fal iron's little holes when I begin to iron my shirt...why!
The iron needs to be cleaned as I have just discovered myself. I have a hinari and the instructions are as follows. Fill the water tank and turn the iron on to medium. When heated press the steam button and hold it over the sink or a container so that the water can run out of it. It will take sediments with it. The cleaning of the iron should be carried out once a month.
I experienced the same trouble and carried out the instructions and all is well again.
Jun 28, 2010 | Vacuums
Tacony LauraStar MAGIC i-S6 Ironing System JYLS-S6 Logo
Top Tacony Vacuums Experts
Are you a Tacony Vacuum Expert? Answer questions, earn points and help others
