Error code F00 bosch maxx 7 - Washing Machines
  • 34 Answers
SOURCE: user giude
https://www.2instructions.com/search.php?cmarque=BOSCH&modele=MAXX%207
Posted on Aug 20, 2009
SOURCE: I have E3 error code on a Bosch washing machine
"E3" on a Bosch Maxx means the door is not closed properly. Either there something preventing it from closing properly (blockage) or there is a fault with the locking mechanism.
Posted on Nov 22, 2009
SOURCE: What does error code E2 mean? I have a Bosch Maxx
The e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
to fix you must do a master reset of the washing machine.
1. Close the door and make sure the dial is pointing to the "OFF" function
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen)
4. Release the button and turn the dial back to the "Off" function.
5. Select any program and the message should not be appearing.
Posted on Nov 25, 2009
tbirdfan1
  • 3051 Answers
SOURCE: I have an error code
Hello there
Normally this is a drainage problem code
Unplug the machine and wait for 30 min
During this time Remove the cover on the front bottom right corner or the front cover at the bottom , use the small hose that is attached to the pump to drain the water, from the pump then unscrew the large drain cover and remove the blockage from the drain pump. and any additional hoses then reattach the hoses and then plug in after the 30 minutes is up then press the cancel button and test ...Test by pouring 1L water into section II in the top and setting the machine to 'drain'. it should beging to drain
Posted on Mar 07, 2011
Chesc
  • 59 Answers
SOURCE: Error code F18 for Bosch Maxx 7 Silence washing
F-18 means the pump is blocked.
First checkthe filter for coins or other junks. Make sure the drain hose isn't blocked, restricted or kinked. Make sure there's no obstruction in the drain standpipe or U-bend.
If this doesn't work, might as well change the drain pump assembly. http://www.espares.co.uk/parts?k=pump
Hope it helps. ;)
Thanks for using Fixya. A 4-thumbs up for answering your question is greatly appreciated.
Posted on Jun 04, 2011
How do your error E17 on a Bosch Maxx 7 varioperfect.
Hi Kerry, The same question was asked on this site back in March 2009 !! and the link below has an answer..... CHEERS..
E17 error code Fixya
Apr 04, 2016 | Bosch Washing Machines
What is error E:00 in Bosch maxx 6 washing machine?
error E:00 in Bosch Caroline, Could not find anything pertaining to this Bosch code. You may be can contact Bosch at last link posted or download manual.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Identify Bosch Washing Machine Error Codes
How to Identify an Error Code on Bosch Washing Machine
Washing Machine Error Codes Front Load and Top Load Washers
Download instruction manuals
Apr 02, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
Hi Washing machine BOSCH Maxx 7. Displays error F 21. What's wrong - and what can we do ? sincerely,Jette
The F21 error code indicates that you have a problem with the washing machine's motor.
Have it checked out by competent electrician.
Feb 22, 2015 | Bosch Washing Machines
Errore f00 lavatrice bosch
Errore F:00 lavatrice bosch ecomaxx7 vario perfect
Jan 23, 2014 | Washing Machines
Hi, How Can I Reset error in my wash machine Bosch
You can reset the error code by the follow steps.
Turn the knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position.
Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off
When your turn it back on it should have cleared the error code.
Sep 26, 2013 | Bosch Washing Machines
Our Bosch Maxx 7 skips spin cycle of the washing program. The remaining time jump from about 7 minutes to 2 minutes
Possible that the program controller unit has some errors and so it does work erratically. Check on all connections to the program controller unit, check for moisture on the unit. Also remove power for few hours and see if there is any change.click on : washing machine tips
Mar 14, 2012 | Bosch Washing Machines
Error code F18 for Bosch Maxx 7 Silence washing machine
Hope it helps. ;)
Jun 04, 2011 | Bosch Washing Machines
F14 fault on Bosch Maxx 7 I have low water power, could this be the problem? Machine bleeped at me then stopped. I have turned my machine off, but the washing cycle had not finished.
Hello
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
You may need to restart wash cycle.
Apr 06, 2011 | Bosch Washing Machines
How to reset the error codes (F21) on Bosch Maxx 7?
See this url
http://experts-univers.com/mon-lave-linge-bosch-maxx-7-ne-fonctionne-plus.html
Oct 10, 2009 | Bosch Washing Machines
Washing Machines Logo
638 people viewed this question
Top Washing Machines Experts
