Question about Brother GX-6750 Typewriter
Brother gx-6750 typewriter
When you push the return button, it returns on the same line and doesn't advance paper. how do i fix this
  • 186 Answers
Make sure the knob for the platen (roller) is tight. Hold the roller and turn the knob to tighten.
Posted on Jun 26, 2007
SOURCE:
Why does paper not advance to next line when carriage returns?
There might be a setting for how many lines it moves when the carriage gets to the end. It is mechanical so you'll see it!
Sep 01, 2014 | Office Equipment & Supplies
How to change the font on the GX-6750 brother typewriter
You have to buy a new printwheel or daisy wheel with smaller fonts.
Jul 07, 2014 | Brother GX-6750 Typewriter
Returning to a previous typed line
That is a problem with this machine. The platen doesn't have a detent so there are no positive stops. The trick is to note where the typed line lines up with the line on the card holder. With a little practice you will be able to go back to a previous line fairly accurately. Use the idex or code+rev button to make the paper go up and down. Also it's a good idea to check for corrections before hitting the return button.
Apr 11, 2014 | Brother GX-6750 Typewriter
I have a Brother GX-6750 correctrone that won't
If you can roll it in by hand but ie won't advance you most likely have a cracked gear on the index motor. If the pa[er won't go in at all you may have a lable stuck. Try feeding and pushing thin piece of card board thru/
DickyO
Aug 23, 2013 | Office Equipment & Supplies
Dpu 414 stacks lines
Set SWDIP switch 1, switch number 4 to ON. That switch controls whether when you get a CR (Carriage Return), you get just that carriage return or a CR-LF (carriage return + line feed). You need the latter. Setting the switch to ON will accomplish that. Have a good day.
Jul 02, 2012 | Seiko DPU 414 Matrix Printer
How to make the paper move to the left to begin tying on a 1932 remington typewriter
The platen is the (usually black) cylinder around which the paper is rolled. There is a carriage return lever mounted at the left end of the platen, which needs to be pushed inwards when the line is finished to move the paper into position for the next line.
Jun 04, 2011 | Computers & Internet
WHEN I TYPE SOME THING AND HIT THE SPACE BAR THE RETURN BAR IT TYPE ON THE SAME LINE AND EVERY THING IS IN ONE .
If the paper will move up with the platen knob the paper feed motor probably has a broken plastic gear. The gear and motor are sold as one 35.00.
DickyO
Mar 15, 2011 | Brother GX-6750 Typewriter
The paper doesn't advance when I hit the return button on my Royal Alpha 2001 typewritter. How do I get it to advance the paper? I have not used it in years.
Hi!
I'm going out on a limb here.
I assume the carriage returns but the line does not advance. Close?
- There is a setting for the linespacing which is either 0 (zero), or 1, or 1 1/2 or 2
Likely, this has been inadvertently moved.
- Also, there is a way of disengaging the linespace mechanism to allow typing to be made on unevenly space forms. This might have been moved.
Please feel free to contact me anytime.
Feb 13, 2011 | Royal Office Equipment & Supplies
My Royal Alpha 2001 typewriter has been unused for years. I turned it on recently and it worked fine except it would not paper advance with the return button. How do I get the paper to line advance?...
Hi!
Brother GX-6750 Typewriter Logo
147 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
