Model # RKMA
SOURCE: Is the Model #25HBA360A300 a 5 ton unit?
36k-car-ms Key Features AC Type: Split System Additional Features: Ductless Cooling Capacity: 36000 BTU/hr Electrical Requirements Voltage: 220It is a 3 ton aprox 550 sq feet per ton is required
SOURCE: Have Rheem 5 ton heat pump with stacked coils poor cool.
If your sure on the psi your low on freon or your evaporator is restricted discharge psi would realy help.you will get best performance with a clean unit or pay expensive utility bill . Tom
SOURCE: Rheem Heat pump 5 ton heat strip 10KW what
I would say this is around 75 amps of draw at max for both the compressor and heat units. . Therefore--at least 90 amp breaker, and probably 100 amps for good measure, and at least #4 or #2 wire to the unit.
SOURCE: I have a 5 ton air conditioner made by
on the unit it should have low voltage termanals labled R Y G H H2 the R termanal goes to the t-stat on the r termanal and the y to y on the t stat ang g to the g on the t stat and H termanal goes to h on the t stat etc if thers no termanal block find the low voltage wires and get back with me on the collors
SOURCE: i have a rheem 12
Take a garden hose with nozzle and a solid stream of water, and hose it out, be watch that you do not damage the fins, with to much force, take your time and get the dirt ect. out of the out door coil start at the top and go across and work you way done the coil, the water will be dirty for sure and should get you working again.
