Question about HEWLETT-PACKARD Computers & Internet
HP Mini110 doesn't power up
This netbook won't power up even if power supply is fine and if there is battery the orange LED battey loading works. When I put external power also the LED near the DC jack goes on but nothing more. Alreadty tested the power on switch that is fine. Things I've done: -removed every external components. (keyboard, RAM, display cable, USB board, speakers, mic and BIOS battery) -tried an hard reset and a BIOS reset shorting CMOS battery pins. -re programmed from outside SPI BIOS chip. -tried a "soft" reflow of the Intel chipset I was also looking for some damaged component, but alls looks like fine. I noticed that without battery the board absorbs around 0,05A that maybe is a bit too much.
  • HEWLETT-PACKARD Master
  • 2,248 Answers
Why make it worse , messing with BIOS like that.
if the battery BIOS is over , 2.9v its good if not replace it
and never short batteries out ever, that is web BS you read.
test one is does it run with main battery removed, y/n
yes good
no, does BIOS come up, with line power only
yes, good,
no bad, if bad then check for 19vdc at the line pack.
18.5v is lowest i think, 50ma is not good off.
if power is correct, 19v, then and BIOS is dead.
then remove ram and all things, like you did and is correct actions.
still BIOS is dead (means screens BIOS DEAD)
yes, dead then the MOBO is bad.
whats bad on it who knows/?
3million transistors there to fail.
why mess with it? circa 2009?
i bet that reflow made it worse. (its not trivail that)
did you pull all non ecential parts off mobo?
wifi,,usb-audo card.
is the fan dead, if yes, the MOBO is toast.
the fan must come on, power on. on most HPs.
dead cold booted/
the cpu has compound but the other chips have thermal tape.
that must be correctly applied. as the manual directs you.
ebay has used MOBO for near nothing
most owners hat this Mini, its slow. ( i have one parked in attic)
so parts are cheap on it. dirt cheap why work so hard fixing a slow ATOM processor notebook, slam in a MOBO if you must.
Buy one that is for sure guaranteed No DOA. or pass....
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR2.TRC1.A0.H0.TRS0&_nkw=hp+mini+110+motherboard&_sacat=0
the book.
http://www.hp.com/ctg/Manual/c01757458.pdf
Posted on Apr 23, 2017
  • 7 Answers
SOURCE: acer not work
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a diskette won't work with a usb stick
I had mine 2 months it's a common problem with the notebook.
The onely thing that you have to do is download these programs with someone with a internet connection.
Good luck
Posted on May 25, 2009
  • 143 Answers
SOURCE: HP Pavilion dv2500 - FTB
The troubleshooting you have done seems to be fine. It does not seem to be a problem with the power supply,cord or battery.Did you try a hard reset. If there is a reset button on the bottom of your laptop, you might want to try pressing that with laptop plugged in, not plugged in, with battery, without battery and different combinations thereof.
If this does not work or you don't have a reset button read on.
Before assuming it's the motherboard, there is one other possibility. There is a part called a PCA switch. It is possible this switch has gone bad or a plug might have come loose.
If you are comfortable with doing your own work, you can obtain a repair manual for your laptop online. Within this manual, it should explain what is involved in replacing this part. It is really not too complicated.
It does not sound like a hard drive problem simply because it doesn't seem to be getting power to any other part of the laptop.
You can try these steps.
Regards
Posted on Aug 03, 2009
  • 159 Answers
SOURCE: HP Pavillion dv6700 - black screen
Do the following without the battery inserted.
Let the computer sit with no battery for 24 hours. Do not put the battery in at all. Try using your original memory stick ONLY, with no hard drive and see if it will POST. If it does, insert the hard drive and try again. Could be the new memory...
Another thing you can try is reseating the processor. Turn the ZIF screw, take the processor out (WATCH THE PINS!!) and put back in GENTLY. Leave the memory in the computer, hard drive removed, try to power on.
These models have been known for bad motherboards. Contact HP and arrange to send it in. If you do enough digging on HPs website, you'll find the service advisory.
-Dell & HP Certified Technician
Posted on Oct 29, 2009
  • 10406 Answers
SOURCE: No connection with the DC Jack on Gateway 3550GZ
It's time to take the computer to a qualified technician, for proper trouble-shooting & repair, because there are very-few "user-repairable" parts inside a laptop/notebook computer.
Posted on Jan 21, 2010
  • 8909 Answers
SOURCE: hello. i have a problem whit my dell 1525 pp29l
If it cannot finish POST then you have a mother board problem.
You state you reset the BIOS. Can you get to the BIOS menu? If you can then the problem is not motherboard errors but hard drive boot sector problems, depending on OS used.
If the BIOS has been updated, then it is possibly an incorrect version or corrupt.
If you can reflow the soldering, remove the BIOS chip and fit a known good one. That should fix your problem.
Hope this helps.
Posted on Nov 23, 2010
Powersupply won't run on Orange terror Bass 500
I found both FDA2828N50F MOSFET transistors in the power supply were shorted. I replaced them and the amp worked fine. I couldn't find a reason for them to fail.
Jan 10, 2013 | Orange Amps Orange Terror Bass 500 Amp...
Bike won't run without battery
Just curious why you would be removing the battey? Does it run fine with the battery?
Oct 24, 2012 | Honda Motorcycles
What are the solutions for hp netbook 1000 that stopped charging?
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Sep 15, 2012 | HP Mini 1000 Netbook
My LG 42LV4400 led tv won't turn on. Even the
Someone must open it and check voltages on the power supply board as the first step.
Depending on what is found boards may have to be ordered and installed to KNOW which will fix or not fix the set.
Mar 14, 2012 | LG Televison & Video
Battery is fully charged, but netbook won't turn on unless plugged in.
I would say that you definitely need to purchase a new netbook battery. If it's only turning on when plugged in, then the battery itself doesn't have any more charge cycles.
Oct 10, 2011 | HP Mini 1033CL Netbook
I have a hp mini110-3617tu. currently, i couldn't type t,y,g,h and "backspace". if i press g ot t, it will come out as gt. please help!!!!
Most of the time, this sort of problem means that the keyboard is toast. You can try to unplug and replug the connector first, but if it doesn't work you need to replace the keyboard.
Refer to this service manual for instructions on removing the keyboard:
http://h10032.www1.hp.com/ctg/Manual/c01683469.pdf
There should be an HP sticker on the bottom of the keyboard with a model number in the format ######-### (for example, 448592-001). You can search for this on ebay to find an inexpensive replacement keyboard.
Sep 21, 2011 | HP Mini 1000 Netbook
Hello.My ACER Aspire One netbook will not properly load, or load at all actually. It worked fine yesterday, I shut it down.. and when I turn it back on it won't work correctly. It comes to a black load...
Hello my friend. The problem is that the "hard drive" has a lot of bad sectors and the netbook cannot recognise it. The Hard disk might need replace with a new hard disk. Please refer to a computer technician. Please rate my help! Thanks!
May 11, 2011 | Acer Aspire One PC Notebook
I cannot wake up my HP Pavilion dv3. blue power led flashes on and off and orange connection led too.
The display driver could have crashed, try holding the power button until the lights go off, and the hard drive powers down (you can hear the spinning stop) then try to power it back on. If that doesn't work, do a hard reset, which would be unplugging it from any AC power, and removing the battery and then reconnecting the battery before powering it on. Should this not work, i would say it's safe to assume the backlight is non functioning and a replacement would have to be ordered.
May 05, 2011 | HP Pavilion Dv3-1075us Notebook
Computers & Internet Logo
Top HEWLETT-PACKARD Computers & Internet Experts
john smith
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
