Question about Lionel 6-30068 North Pole Central Christmas Train
6-30068 The train is only used arount the Christmas tree. This year it seems to have poor power and appears to be loosing contact with the track. Some times it will not go at all. I have tried cleaning the track and wheels this helps some but the problem comes right back the next time we use the train.
  • 161 Answers
Check out these Lionel Customer Service Videos.
http://www.lionel.com/CustomerService/service-documents/video.cfm?documentID=6334
http://www.lionel.com/CustomerService/service-documents/video.cfm?documentID=6337
Posted on Feb 13, 2013
SOURCE: Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Posted on Jan 07, 2009
SOURCE: We have a Lionel 80-watt
This transformer is difficult to open unless you have the triangular security screw driver. Security bits can be purchased at any Harbor Freight tool store but you will need to adapt them to fit into the channels where the screws are recessed. Click on the link below to view the correct tool needed to correctly open this unit up:
http://www.amazon.com/Silverhill-Triangle-Screwdriver-Roomba-Happy/dp/B001F3FUBK/ref=sr_1_1?ie=UTF8&s=hi&qid=1277110784&sr=8-1-spell
Posted on Dec 24, 2010
SOURCE: New Lionel Polar Express train set-up issue. The
My son just got this train and we are having the same problem. Taking the last car off solved the problem for us. I think it has something to do with accessories and the transformer voltage output (See page 14 and 15 of the instructions).
I have still not determined why it won't run with the final car but am assuming it has something to do with the lights on the cars pulling too many amps and not enough left to run the train. I will let you know if I find a solution. If anyone else knows how to solve the issue, any assistance would be greatly appreciated.
Thanks
Posted on Dec 25, 2010
  • 13 Answers
SOURCE: I bought the 6-30089 Pennsylvania Flyer Train Set
Hope you got the set working. If not, look underneath the locomotive near the rear (under the "cabin"). There are two switches, one on either side. One says "Smoke", the other says "Reverse". If the "Reverse" switch was set to "Off" when the locomotive was in Neutral, it will stay in neutral even when the power is cycled or the "Direction" button is pressed on the power supply. Even in Neutral, all the lights will work and I believe the smoke element will heat up but won't puff. Whatever setting the "Reverse" switch is on, try changing it to se if that works. Hope this helps...
Posted on Jan 18, 2011
selena_dambr
SOURCE: the train is running slow.I checked the connections everything is where it should be. I am using it around the christmas tree for the first time. Does the trach size matter. Is it maybe going over the
Is it old if so there is ur eason also it could be shortige of track or did you put stuff on it
Posted on Dec 11, 2011
Hawthorne Village Home for the Holidays Thomas Kinkade Village Christmas Train Does not go around the Tracks
If it has never ran, return it to where you purchased it.
If it has ran, you probably need to clean the track and the pick up wheels.
If there is no electricity being delivered to the track, take a multi-meter and check the power supply to see if it is working.
If the power supply works, check to make sure your wiring between the power supply & track is connected.
Dec 11, 2012 | Electric The Thomas Kinkade Christmas...
I have a Lionel ZW transformer older version 1955-1956, And lately my train loses power at one area of the track and then regains power again. This happens on both the outside and inside tracks.
This does not appear to be a problem with the ZW. The XFMR does not know anything about train location on the track. It appears to be a track connection problem on the center or outside tracks or both. One way to identify a bad connection is to take a parallel wire from the common and hot terminal of the ZW and connect directly to the area of track where the train stops and slows down. If this cures the problem then I recommend checking the tightness of the three track connections. For both FasTrack and Tubular, crimp slightly the pin receiving holes in the end of the track.
Note: For both tubular and Fasrtrack it is recommended that common track power for any one section be input to the track at more than one point. In this way one bad outter or center conductor won't cause the train to slow up or stop.
If FasTrack, you can solder directly to the tabs on the track underside for a permanent connection.
Aug 22, 2011 | Lionel Postwar Parts Zw-99 Transformer...
I have power to the train and it runs but it moves extremely slowly and sommetimes comes to a stop.
I'm assuming the train is track powered with a power pack, and not battery powered, so there's actually a few possible solutions. I'll work from the easiest/cheapest, to the more advanced/expensive.
First, especially if the track is old or been in storage a while, the track may have a thin film of dirt, oil, or rust that is insulating the wheels from picking up the power they need from the track. Try cleaning the track with a mild soap but BE SURE TO DRY IT COMPLETELY before reattaching the power. Also, clean the wheels but use a cotton swab and very little water. One drop inside the motor might destroy it from the inside. You can also try a special track cleaning solution sold at your local hobby shop that has HO model train sets. That will work better, especially on lightly rusted parts. Also, make sure all the track connections are tight and free from contaminants.
Then, if you're feeling brave, you can check the motor of the train itself. Disassemble the locomotive and find the motor inside the housing. Check the wires leading from the wheel area to the motor for any corrosion, or loose/broken wires. If it's not the wires which are easy to solder back in place, I wouldn't recommend going any deeper into the motor as it's better and less frustrating to just buy a whole new set.
Finally, the problem may lay in the power pack (inverter) itself. I personally don't bother trying to fix a power pack, but if you know your electronics you could run some tests of the output voltage to the track, and the voltage on the track at various points. Again, it's not worth the time or effort to mess with the power pack unless you know what you're doing. You could get seriously injured or killed by the voltage/amperage running through those things. They even have enough stored electricity after they're unplugged to cause some nasty electrical burns from the capacitors.
Hope this helps and you're able to fix the problem so you can get back to enjoying the train set. I've always enjoyed watching them for hours, especially when I set up my track around the Christmas tree every year! Good luck!
Dec 19, 2010 | New Bright 384 Holiday Express Animated...
Locomotive won't come on
This train set is very particular and getting it to work each Christmas is a family tradition in frustration. First you must make sure that all the pieces of track are connected properly and that the track is perfectly symmetrical and flat. We double-check the battery positions every year and find one in wrong. There are + and - signs, but they're hard to see; use a flashlight. There is a black toggle switch below and behind the red stack that toggles forward (to make the train go forward) and backwards (reverse); straight out perpendicular to the train is the "stop" position. Also, you have to start at a stop/switch station. One other note: behind the red stack, there is a smaller black stack. If you turn this, you can make smoke come out of the stack. I think I remember someone suggesting a drop of cooking oil. Hope this helps!!! Hope you get it set up for Christmas!!!
Dec 12, 2009 | New Bright 181 Toy Christmas Train
Need help setting up Lionel North Pole Central Christmas Train 6-30068--how do I attach the transformer to the track? It is on O gauge track and is transformer that came with set. Our manual is lost and...
I had the same dilema and trains are not new to me. Look under the piece of straight track that has a notch in it for the wiring. There will be a clip to hold the wire and a piece of plactic that looks like a block. One either side of that is a metal tab that one end of the wiring slides over. Actually each piece of the Fastrack has one of these. Only one has a notch but you can notch any one.
MHC
Nov 26, 2009 | Northpole Lionel 6-30068 North Pole...
An electricalroblem with Holiday Express train
Mar 31, 2009 | New Bright 181 Toy Christmas Train
Need replacement track for train set
is there a way to make wooden tracks for this inflatable to sit . all you would have to do is measure the distance between the wheels and the cut the lumber and screw together. i would use 2 x 4 x 8 feet long . and cut the braces just the right lenght so the train would sit on the track. you could even paint the rails gray or silver and the braces black to off set the colors of the train it self .
Dec 01, 2008 | Animated Inflatable Christmas Train
Lionel 6-30068 North Pole Central Christmas Train Logo
202 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
