Question about Kitchen Ranges
I have a kenwood dual fuel range cooker and the main oven has stopped working. There is no light, fan or heat. can anybody help please.
  • salena conaghan Jan 29, 2013
    Called an engineer and he diagnosed the problem straight away over the phone. It was the selector switch which the engineer said was a common problem with the kenwood range cooker.
  • 2976 Answers
SOURCE: convert my belling DB90
You will have to change the orifice to accomodate lp gas.
Posted on May 08, 2009
SOURCE: The oven of my kenmore dual fuel range will not heat.
Mine did the same thing, replaced bottom element still not working. the top element & convection element works now what?
Posted on Oct 09, 2012
SOURCE: Lofra MXD96AMFE/C Dual Fuel Range Cooker
Hi
The timer on our Lofra MXUD76MFE broke about 2 months after the 12 month warranty ran out.
Being a bit of a fiddler i took the top off the cooker to access the timer (not that difficult) when i ispected the timer i was astonished that it had lasted the 14 months it had such was the quality of it.
The timer was easy to set to ensure the cooker worked but unserviceable to restore the timer mechanism.
I thought given that it was such a cheap looking part (even allowing for the exorbitant price of parts) it would be worth replacing.
Came across the new appointed distributor - Premier Appliance Brands - based in Warrington (01925 248980)
They gave me a part No of 03010631 but didn't have stock and initially could not give me a price. i left it a couple of weeks and rang back this week.
They quoted £77 - needless to say i didn't order it
Posted on Nov 30, 2007
  • 1314 Answers
SOURCE: stoves 900DFa dual fuel cooker
check to see if one of the oven elements are burned into if you have an oven cord on it turn the breaker off and check the cord where it connects to the oven
Posted on Mar 15, 2008
SOURCE: DeLonghi DFS 090 SO DUAL
I had the same problem,it was something to do with the oven knob switch ,i got an engineer out to fix mine or else just buy a new knob hope this helps
Posted on Mar 25, 2009
Oven not heating up but fan working
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Aug 11, 2010 | Zanussi ZCM900X Dual Fuel (Electric and...
Stoves 900DFa dual fuel cooker
Mar 15, 2008 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
Feb 14, 2008 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Delonghi professional dfs903 cooker
have a Delonghi dual fuel DTC90DF range.
The oven has been temperamental for a whil, working then clicking off so that you had to turn it on again and it would work for a while again. Eventually there was a bit of smoke coming through the hob and it smelt of electrical burning and stopped working all together. It is the main fan oven that is now not working.
Please help
Bev
Jan 03, 2008 | Ovens
TECNIK 1285 RANGE COOKER
I have a Tecnik Range cooke that was in the house when i bought it. The secong oven has no cover for the heating element at the top so everything I put in browns at the top. Should this oven have a metal plate underneath so that I can use it as a conventional oven or should it be like that
Dec 19, 2007 | Tecnik TKC1285 Dual Fuel (Electric and...
Small Electric cooker on Range does not reach temperature
The orange light is designed to go off when temperature required is achieved in the oven. If the light remains on it suggests that the oven is not heating, It could be a thermostat problem but it's more likely to be the element.
Nov 19, 2007 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
The cooker stays warm when mains cooker switch is on.
Either teh grill element or the oven heating element is fault or the thermostat or grill regulator, locate which element is warm, if the grill then it is most likely the regulator, if it is the oven it is the thermostat. Engineer
Jul 20, 2007 | Stoves 800DFDOm Dual Fuel (Electric and...
Fan assisted oven not working
If the fan is still working then it is the element that has gone. This is easily replaced as you only need to remove the back panel and swap the the element.
Nov 02, 2006 | Rangemaster Classic 110 (Dual Fuel) Dual...
Kitchen Ranges Logo
161 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
