Question about Plumbing
Moen aberdeen kitchen faucet won't shut off - Plumbing
jj505
  • 195 Answers
SOURCE: Loose handle on my Moen single handle kitchen faucet
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Posted on Apr 06, 2009
  • 44 Answers
SOURCE: I cant stop my Moen single lever kitchen faucet
1. If it's "leaking" from the body then, the O-Rings between the body of the faucet got gunked up with minerals from your water. This interferes with the seal.
The answer is to take some grit cloth/very fine sandpaper and clean the inside of the spout body. Wipe clean. I would also suggest replacing the O-Rings on the faucet body, but at the very least wipe the O-rings and faucet body clean.
THEN: lubricate the inside of the spout body AND the O-Rings with silicone grease. It's translucent and readily available and the only thing I would ever use for a faucet repair. NOT plumber's grease, NOT WD-40.
Reassemble and enjoy.
2. If it's dripping, the you need a new cartridge. You can get them for FREE from the hardware store if you have the old cartridge to trade them. The problem is that Moen cartridges are water-sealed into place and you need a special tool to break that water seal. The special tool (just a tiny piece of specifically shaped plastic, really) comes, you guessed it - with the new cartridge.
Two possible solutions: a) bite the bullet and just buy the cartridge (~$25) or buy a Moen cartridge puller, usually available from the hardware store as well for about the same price. Ask, they might even lend you one.
The point of whichever tool you end up with is to rotate the cartridge itself inside the faucet body to break the water seal so that you can pull it out with a set of pliers. There will be a retaining clip to pull out as well.
www.plumbingpartsdepot.com/moen7300.gif
http://img2.timeinc.net/toh/i/a/plumbing/faucets-toilets-07.jpg
Good Luck.
Posted on Sep 09, 2009
Testimonial: "this will give me something to work on. thanks"
  • 127 Answers
SOURCE: Moen kitchen faucet model 7430 leak
cartridge does not stop that type of leak. If it is leaking from around the base of the spout it is o-rings that are the problem that are onthe valve after you pull the spout all the way off.
Posted on Oct 18, 2009
FixinFax
  • 3085 Answers
SOURCE: need to replace cartridge in single lever moen
Turn off water
Remove the handle with an allen wrench, usually 1/8".
Unscrew the dome with a pair of channel lock pliers with a rag to prevent scratching.
Wiggle out the old cartridge with the channel lock pliers.
Clean all innards with WD-40.
Reverse procedure
Posted on Dec 12, 2009
Testimonial: "Thank you for the speedy reply it was needed at the time because the part was jammed or at least it seemed so."
  • 122 Answers
SOURCE: How do I remove the aerator on a moen pull out
It should just unscrew. You might need some needle nose pliers as the aerator may be slightly recessed.
Posted on Jan 28, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    How to remove lever
    There have been at least 2 different versions of the 7590C... on one version there's a plug on the 'back' (180 degrees from the handle) that covers a horizontal set screw, and on another version there's a cap on top that pries off and covers a vertical mounting screw.
    User manual - http://moen.com/shared/docs/instruction-sheets/ins801l.pdf
    Parts diagram - http://moen.com/shared/docs/exploded-parts-views/7590cpt.pdf
    In this case, the parts diagram should clue you into which version you have better than the user manual does.
    Mar 08, 2015 | Moen 7590C Aberdeen One Handle Kitchen...
    How do I disassemble a Moen 7590orb handle
    If you call Moen they will provide you with detailed repair instructions. In Canada 800 465 6130 and if not in Canada that number might redirect you OR any Moen retailer can get you the appropriate toll free niumber for your area.
    Dec 11, 2014 | Moen 7590ORB Aberdeen One-Handle Kitchen...
    How to fix
    If the faucet leaks tighten all connections if that does not work call Moen as their faucetts usually have a lifetime warranty.
    May 07, 2014 | Moen Aberdeen One-Handle Kitchen Faucet...
    I can't get to the cartridge inside my Moen Aberdeen handle
    The detailed exploded view of the parts is in this sheet.
    Hope this is the right model that you have.
    http://www.moen.com/shared/docs/exploded-parts-views/7590cpt.pdf
    you will need to undo the nut holding the cartrigde in place. Sometimes you will have to get a special tool to undo these parts.
    Apr 19, 2014 | Plumbing
    Moen aberdeen #93980 manual
    This is what Moen has to offer for the faucet itself:
    http://www.moen.com/shared/docs/product-specifications/7592csp.pdf
    The design guide is here:
    http://www.moen.com/assets/moencom/images/design-planning/support/articles/kbplanningguide-revised8-26-09v2.pdf
    The exploded view- for the 2 handle
    http://www.moen.com/shared/docs/exploded-parts-views/7592cpt.pdf
    The exploded view single handle. This is all that shows up for the Stainless model as well.
    http://www.moen.com/shared/docs/exploded-parts-views/7590pt.pdf
    The three other options/finishes have their own manuals
    Chrome 2 handle
    http://www.moen.com/shared/docs/instruction-sheets/ins802e.pdf
    Chrome 1 handle
    Bronze
    http://www.moen.com/shared/docs/instruction-sheets/ins801k.pdf
    Jan 07, 2012 | Plumbing
    How do I get cover off moen 7840 kitchen faucet
    Use a small flat-head screwdriver. Insert behind the small cover and 'pop' it off.
    Dec 27, 2011 | Moen 7840 Camerist Single-Handle Kitchen...
    I am having a leak with the hydrolock going to the sprayer hose on a new Moen faucet. I have taken it apart a few times to make sure it's together right, but I can't get it to stop leaking.
    Three years ago, I installed a Moen kitchen faucet with sprayer
    in one of my rental units. Moen twice sent replacement
    Hydrolock kits, as I couldn't get them to seal. While waiting for the Moen parts to arrive, I used a short length of heater hose purchased at AutoZone, held on by two small hose clamps. After all three Hydrolocks had failed to seal, I just left the heater hose in place. Three years and no problems. ..and no more Moens, either.
    Sep 16, 2011 | Moen 87530 Touch Control Single Handle...
    How do I get to the valve cartridge to replace it?
    how to replace moen cartridge for two handle kitchen faucet ... cartridge for two handle kitchen faucet exporters,how to replace moen cartridge for two handle kitchen faucet suppliers,how to replace moen cartridge ...cn-faucet.com/ kp-how-to-replace-moen-cartridge-for-two-handle...
    Mar 17, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    Need to fix a broken moen kitchen faucet
    I had the same problem with my Aberdeen single lever with a pull-out sprayer a few months back. If you are the original owner of the faucet, it's under warranty; you shouldn't have to pay for any parts. Call: 1-800-BUY-MOEN (1-800-289-6636) and tell Customer Service what the problem is. They will send you the Handle Mechanism Kit at no charge. (Mine was part #93980 for my Aberdeen faucet, but yours may be a different part number.) It's tricky to take apart and get back together but my husband and I have zero plumbing experience and got it all fixed in about 20 minutes. The Moen.com website also has exploded parts diagrams of all their faucets so you can identify exactly what part you need, and they have some little videos and slideshows to show how to replace parts. If you can't reach Customer Service on the phone, you can go to "Contact Us" on their website and email them a description of your problem.
    Jun 17, 2009 | Moen Plumbing
    Plumbing Logo
    91 people viewed this question
    Top Plumbing Experts
    Donni Steen
    Tom Chichester
    Are you a Plumbing Expert? Answer questions, earn points and help others
