I have a cisco router and a HP printer and want to print from my iPad though my router to my printer what do I need to do to do this?
I want to used my iPad through my router to my HP printer. What do I need to do?
    Genius:
  • 1,669 Answers
See if the Apple store has an app to kink to a router.
Posted on Dec 31, 2012
How do I print from my iPad to my wireless printer?
If your wireless printer is an HP, HP has an app called "HP ePrint" on the iTunes App store. I have used it with good success.
Jan 02, 2015 | Apple iPad Tablets & eReaders
Can't print with my Ipad 2 over the wireless network
That's probably an incompatibility issue between the iPad and printer. Router is most likely not to blame.
Mar 03, 2013 | Cisco Linksys Wireless N Home Router...
I want to use my iPad through my router to my HP printer what do I need to do to get it to print
It's not quite that easy, it's a compatibility issue. If your HP printer has Air Print compatibility, you can use Air Print, if not, Download, in the iPad app store ,a free app for HP printing. Follow instructions
Dec 31, 2012 | Linksys Wireless-G Broadband Router
Hp photosmart won't print in color
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Sep 10, 2012 | Cisco Photosmart C4780 Wireless AllInOne...
What do I need to make my printer wireless?
You need 1) a wireless router with a USB port that supports the HP OfficeJet printer. 2) The software for your router to run a printer on the USB port. Obviously, you will need a USB A/B male end cable.Note: the scan features of the all-in-one may not work unless the printer is directly connected to the computer. Bi-directional communication is required for scanning and the router software may not support this completely.
Check the list of supported printers closely for older routers. I have a Cisco Linksys E4200 v.2. This router supports all the HP printers that I use.
If this is a new installation of the printer, first install the printer on the computer. If you have Windows 7, just connect the printer to the USB port on the laptop. This will install the OS drivers for the printer. (For Windows XP, go to the HP site and get the full software.)
Next install the wireless router between your modem and computer and set that up. (If you have DHCP (dynamic address allocation), it should be automatic. Otherwise follow the directions.) Next install the router software (for my router, it was Cisco Connect).
My next step was to launch the Cisco Connect program and connect the printer directly to the USB port on the router. In Cisco Connect, choose add a printer and find the printer connected to the router. Print a test page. (At times, I've had to reset the port that the printer is on in the Windows Control Panel Printer Properties. (For the Cisco Connect, the printer is on the DOT4 port.)
Other routers will be set up somewhat differently.
Another option is to have the printer connected to a desktop and then make it a shared printer with the wireless router communicating between the laptop and the desktop. This makes the desktop the print server, so it needs to be on when you want to print. If you have several computers with Windows, this can fairly easy to set up. Make sure that the computers are in the same Workgroup (XP) or Homegroup (Win7). Enable sharing and you are done.
I hope this helps.
(who has a OJ 7000 (with ethernet port) and a LJ1320 (USB) connected to the router. Three computers talk to these printers with the laptop on the wireless network. On an older router that didn't support the printers, the laptop was the server for a previous OfficeJet and one of the desktops was the server for the LaserJet.)
Aug 27, 2012 | HP OfficeJet 6110 All-In-One InkJet...
I have a problem with my HP LaserJet P2015dn. When a print job is sent to the printer, it will not print unless I turn the printer off and then back on. This printer is used on a small business network.
This is a common issue with these printers and it is usually one of two issues:
1. The formatter is failing. HP used to replace them free of charge because of on going defects, but that program has expired due to age of machines.
2. Some business class routers such as CISCO, will lose track of the printer becuase HP products do not constantly broadcast their IP address. If you are using a CISCO product you can try entering a static enterly into the ARP table of the router to see if that fixes the problem.
If you are not using CISCO network gear then it is more likey option 1
Jun 10, 2011 | Office Equipment & Supplies
HPC 4780..Printing fine from computer. but will not scan or copy when i press the button on printer. Get a message that scanning/copying failed.
Uninstall the driver for your HP C4780 and reinstall it using this page.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3794615&lc=en&cc=ph&dlc=en&lang=en&cc=ph
If you are not familiar in doing so, you can call HP on this number: 800-474-6836 (United States)
Mar 25, 2011 | Cisco Photosmart C4780 Wireless AllInOne...
I have an ipad and bought a hp c310 wireless printer to allow me to print. It was working well until i upgraded my router to dir 825. now my ipad does not recognize my printer. Once i reset the new router...
As of right now printing from the iPad is only "officially supported" by like 4 types of HP printers. I am not sure if yours is one of them (it is the newer ones for now). There are some tricks you can use (extra programs to install) that should allow all printers. Do you have a mac or a PC? If you have a mac follow this guide and it should work for you....
http://www.wired.com/gadgetlab/2010/12/ipad-iphone/
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
Mar 03, 2011 | D-Link DIR-825 Wireless QuadBand Router
My HP printer will not print pages from the desktop. I ran a test report from the printer itself and it said that the Access point could not be found and that it was in fact turned off. How do I fix this?
If this problem arises check for updated printer drivers, compatibility between your wireless printer and Windows Vista and firewall settings. All or any of this could prevent your HP wireless printer from printing documents. Setting up wireless printers is very easy; however, sometimes certain settings can create hassles for you. get more help for HP Wireless Printer Problems.
Aug 10, 2010 | Cisco Photosmart C4780 Wireless AllInOne...
Computers & Internet Logo
David Payne
David Payne
