Question about Sceptre 32 X320BVHD 32 LCD TV
How do you clean dirt from the inside of the flat screen tv, it looks like dust on the inside of the tv screen on the side where all the turner controlls are at. i like the tv but makes it hard to wat
Where the control panel is at on the side of the tv, this is where the dust seems to be on the inside how do you clean this dust out of the inside of the screen, that is the only problem i have with this flate screen
2 Suggested Answers
SOURCE: control buttons on flat screen scepter monitor
My 22" Scepter Monitor wont light-up, pulsating blue light on. I posted this SOS a feww hours ago but I couildn't sign into FaceBook. Please anyone with a solution would be tremendously appreciated.
Best regards,
Oscar
Posted on Oct 27, 2009
How do I disassemble a Vizio E3D470VX Smart TV, to clean out the dust inside the Screen
Hi Alonzo,
To clean the dust inside the screen, you will have to disassemble the LCD panel. It is a very risky job and there is every chance of damaging the LCD screen unless you have a real good experience of doing it. If you are not good at doing such jobs, please let some professional do it for you.
Jul 05, 2016 | Vizio Televison & Video
Why does my tv make static noise when coming on?
Your flat panel TV probably has a high voltage power supply for the fluorescent tubes that illuminate the display. An accumulation of dust or dirt contamination can cause voltage to arc inside. If you can see lots of dirt or dust inside, you might want to have it cleaned.
Jun 30, 2014 | AOC Televison & Video
Dust inside screen
You would have to pull the case apart. depending on your tv you may also have to remove the lcd panel.
Nov 13, 2013 | Hitachi 42PD7200 42 in. HD-Ready Plasma...
Need to Clean The lense
If this is a projection TV (DLP or LCD), dust could be on the lens or the mirror assembly. Moving a set can dislodge dust and dirt that's accumulated inside and deposit it onto the lense or mirror. A worst-case scenario would be dust on the LCD chips. Unless you're experienced and/or comfortable opening up the set, I'd recommend contacting a local TV serviceman.
Oct 02, 2012 | JVC Televison & Video
Hi, I have an Hitachi 42PD9700 plasma TV. When the TV is off you can see a mottled/patchy area on the top right hand side of the screen (this is still visible when the TV is on if you look closely). This...
Same problem. Gray clouds INSIDE the external (plexi)glass of the screen.
I guess either:
1 - Screen collection dust or some electrostatic phenomenon.
or
2 - Some coating peeling off.
1 may be solved by dismounting and cleaning.
Any solution you know about ?
Sep 22, 2011 | Hitachi Televison & Video
How do I properly clean my Samsung 46" LCD T.V. screen?....when sun hits it from an angle it looks as if it is coated with dirt/dust...tried wiping with a new CLEAN dry cloth but does not seem to...
go to walmart or best buy and buy you some lcd cleaner....its specially made for lcd/flat screens and will not harm it ...just follow the directions provided with cleaner and your done :)
May 07, 2011 | Samsung Televison & Video
Have a JVC HD-Z886 61inch, there appears to be some black spots behind the screen. Looks like dust, most at top of screen, not a big problem. Is there any way to clean behind the screen? When new the TV...
  • The most severe problem dust can cause in an LCD TV is a short circuit. This occurs when dust enters the television's casing and settles on one or more of the internal circuit boards. Enough dust can cause a short circuit, which will prevent the TV from working at all. In other cases, it will damage picture quality or prevent certain features from working properly.
    Because a short circuit can only occur when enough dust is present inside the TV, this problem happens after the TV has been in use for a number of years, meaning that it will not be covered under the manufacturer's warranty. In many cases of short circuits, repair is expensive, and you are better off buying a new set.
  • Image Quality
  • Dust can also have an effect on an LCD TV's picture quality without entering the LCD's casing. Dust that settles on the surface can distort the picture and decrease its brightness. While it's easy to wipe the dust away, use only a soft cloth and mild cleaning solution to avoid scratching the screen or causing permanent damage with caustic cleansers.
    Dust under the screen can be more difficult to clean. Using compressed air to blow the dust out is the best option, short of disassembling the set to clean the screen from the inside. Keeping the surface of the screen free of dust is usually sufficient to prevent dust from getting under the screen.
  • Control Problems
  • Another effect dust can have on a an LCD TV occurs when it enters the space around buttons, making it difficult to control the television. On certain sets, dust will cause buttons to stick or prevent them from engaging when pressed. Using compressed air to blow the dust out, or resorting to using only the remote control, will solve this problem.
  • Jan 24, 2011 | Televison & Video
    Need to remove screen cover
    you have to remove the back of the tv to clean the inside screen.
    Apr 29, 2009 | Toshiba 57H82 57" Rear Projection...
    Gray spots on screen on a JVC HDILA model HD 56G 787
    The gray spots are caused by dust on your lens, very easy to clean.
    Power down the TV.
    If you open the right side access panel (right side as you are looking at the front of the TV) you can see it in the middle, it's not very big. Using a scratch/lint free cloth, gently wipe off the lens or use a vacuum to **** up the dust being careful not to actually touch the lens.
    Replace the access panel and enjoy your spot free screen.
    Sep 29, 2008 | JVC HD-52G786 52" Rear Projection HDTV
    Sceptre 32 X320BVHD 32 LCD TV Logo
    105 people viewed this question
    Top Sceptre Televison & Video Experts
    Jaime Hernandez
    Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
