Question about LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T...
LMX25981ST/01 HOw to remove the LED light cover and replace lights
  • 1 more comment
  • Michael Messina Dec 31, 2012
    Are you talking about the lamp in the fresh food side or the dispenser light?
  • sherryhon
    sherryhon Dec 31, 2012
    Yes I am
  • sherryhon
    I am talking about the fresh food side the light that sits at the ceiling of the refrigerator inside the two french doors next to the water filter-. LED lights.
I have a LG LMX25981ST refrigerator. I need to know how to remove the front control panel on the door to replace the solenoid for the ice flap. How do you remove the front cover?
Wow...
SEARS has a pretty reasonably parts library...
Their motive is to get you to hire them to do your repair...
but they also SEEM aware that modest income can be had by HELPING CUSTOMERS purchase GUARANTEED FIT repair parts from them...
They are certainly NOT the cheapest...
In my opinion...
PUSHY, PRETENTIOUS & overly expensive ($$$$) for
parts & especially service (but they do offer guarantees
(because they need them)..
Second attempt...
(this FIXYA site is running WORSE THAN some of the fractured appliances we are trying to help)
Found no decent repair videos... ERGO unable to say
CONCLUSIVELY that the door service TRIM merely SNAPS
into place
Protect your finishes with masking tape... around your "DOOR SERVICE" trim ring.
Get a clean new putty knife (edge covered with MORE masking tape and slip it under the edge of the trim & gently lift.
If it doesn't easily lift... quit & start making calls
here.(Sears)
http://www.searspartsdirect.com/model-number/LMX25981ST/3204/0161000.html?searchType=modelSearch&q=LMX25981ST&searchTerm=LMX25981ST
partsselect.com
LMX25981ST Parts List
appliancepartspros
http://www.appliancepartspros.com/lg-motor-ac-dispenser-eau60943436-ap5644965.html
Me...
Carnac the Magnificent
Jan 19, 2017 | LG Refrigerators
How do I replace front HID light bulb? and where can I purchase parts for replacing?
  1. INSTALLATION GUIDE:
  2. BMW E38 99-01 HID TYPE 7 Series 1PC Halo Amber Projector Headlights
  3. Parts Identification:
  4. Projector Headlight
  5. Halo & L.E.D.
  6. Bottom of the Headlight:
  7. Ballast Bracket, Halo Wires(red/black)
  8. Turn Signal Adaptor
  9. TOOLS REQUIRE
  10. 10mm - 8mm socket
  11. Philip Screwdriver
  12. Crimper/Pliers
  13. For more information about how to install your vehicle, come visit our youtube page on
  14. http://www.youtube.com/spyderauto
  15. Remove the facotry headlight from the BMW. First remove the front panel cover below the headlight to access the bottom screw of the headlight housing. There is also two screws on the top of the housing.
  16. Once you have remove the headlight, turn the headlight around and remove the bracket that holds the Ballast. Then remove the ballast using a philip screwdriver.
  17. Unplug the wire from the ballast, and then remove the Xenon Plug from the housing. Put the Ballast aside.
  18. Carefully remove the D2S Xenon Bulb from the factory housing. Once you have remove the bulb, transfer the bulb to the Spyder headlights.
  19. Remove the bracket from the Spyder Headlight, and then install the ballast on the housing like the original. Once you have put the ballast on, put the bracket back on.
  20. Remove the Panel Cover bracket from the original headlight to the new Spyder Headlights as shown here.
  21. STEP:
  22. Install the Spyder turn signal socket if the orignal does not fit, unplug the factory plug from the harness and plug the new one on.
  23. Install the Spyder Headlight back on to the vehicle. Plug the Harness back on, the halo/L.E.D. Wires is connect to the Parking lights. These wires are optional to your vehicle, you do not have to wire them together.
  24. Factory Xenon Headlight
  25. Spyder Projector Headlight using Factory Xenon Lights
May 21, 2014 | BMW 335i Cars & Trucks
Led number are not fully displayed
That means that the LEDs have burnt. If the Led are not very useful then donot bother otherwise call the technician from the maker.
Feb 27, 2014 | LG LMX25981ST Stainless Steel Bottom...
Replace headlight bulb
  5. Halo & L.E.D.
  9. TOOLS REQUIRE
  12. Crimper/Pliers
  21. STEP:
  26. STEP:
  27. PLS VOTE ME
BMW e46 HID Headlight Replace
Nov 23, 2012 | 2000 GMC Denali
How do you remove the light bulb cover in a fivestar 48
You remove your incandescent light bulb and insert your automotive LED light bulb.The LED lights cover the landscape area for people to be able to see.
home light bulbs
May 28, 2012 | Five Star FiveStar 48'' Range Hood -...
Replacing stock tail light w/led tail light, on my 01 harley softail std, need the color codes to be able to accomplish
I would not splice any wire due to the fact that Kuryakyn, Drag specialties, Custom Chrome and many other manufacturers has direct plug in L.E.D. tail light assemblies for your particular motorcycle.
Apr 03, 2010 | 2001 Harley Davidson FXST Softail Standard
Backlight on slide temperature control , passenger side out. 2005 tahoe how to replace
go to radio shack, buy 12v led light, sub min size.
remove back cover, remove knobs from front.
you will need a solding iron, unsolder light, check for + side of
led and + side on broad and solder led in place, install front and knobs
and install back and screws, install in truck
Feb 07, 2010 | 2005 Chevrolet Tahoe
Service Error 5C00 - iP90v Pixma Canon Printer
Clean it out underneath the printhead & cleaning mechanism first (paper towel), then do the fix routine.
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
also there are TWO distinct steps to resetting the TWO ink counters in aan iP90. Enjoy.
3-3. Adjustment / Settings
(1) Service mode
The basic operations are the same as those of the i70 / PIXUS 50i.
In this section, destination settings, how to reset the waste ink counter, and EEPROM information
printing, which differ from those of the i70 / PIXUS 50i, are detailed.
1) Turn off a printer. While pressing the Resume/Cancel button, press the Power button.
The LED lights green to indicate that functions are selectable.
button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the
alternately lights in either orange or green, starting with orange.)
4) When the LED lights green, press the Resume/Cancel button as many times as you need, to
select the preferred function. (See the table below.) Each time the Resume/Cancel button is
pressed, the LED alternately lights in either orange or green, starting with orange.
(The color red indicates the changes from the i70 / PIXUS 50i.)
Time(s) LED Function Remarks
0 times Green Power off When the print head is not installed, the carriage
returns and locks in the home position.
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting Proceed to step 5) below. Once executing step 5), then, move on to step 6) to select the waste ink counter to be reset. (Different from the i70 /
PIXUS 50i.)
5 times Orange Destination settings Proceed to step 5) below. Once executing step 5), then, move on to step 7) to select a
destination. (Different from the i70 / PIXUS 50i.)
10 times Green Return to the menu selection
5) After the function (menu) is selected, press the Power button. The LED lights green, and the
selected function will be performed. (When the operation completes, the printer returns to the
6) Press the Resume/Cancel button the specified number of time(s), then press the Power button.
Time(s) LED Waste ink counter to be reset
0 time Green Main waste ink counter
1 times Orange Platen waste ink counter
2 times Green Main waste ink counter and platen waste ink counter (at the
same time)
Note: When the waste ink counter is reset, print the EEPROM information as shown below,
and confirm that the value of the counter is 0 %.
8
7) Press the Resume/Cancel button the specified number of time(s) according to the destination
listed in the table below, then press the Power button.
Time(s) LED Destination
1 time Orange Japan: PIXUS iP90
2 times Green Other than Japan (A4): PIXMA iP90
3 times Orange Other than Japan (LTR): PIXMA iP90 (LTR)
Note: After the specific destination is set, print the EEPROM information as shown below, and
confirm the model name.
Print sample:
1:iPXXXX 2:V1.02 3:IF(USB=1) 4:D=004.9 PD=000.0 5:ST=2005/09/27-18:30
6:ER(ER0=1000 ER1=5100) 7:LPT=2005/09/028-09:09 8:PC(M=002 R=000 T=001 D=009 C=009)
9:CLT(BK=2005/09/27-18:30 Cl=2005/09/27-18:30) 10:CH=00002 11:CT(BK=040 CL=013)
12:IS(BK=1 C=0 M=1 Y=1) 13:IC(BK=00000 C=00000 M=00000 Y=00000)
14:Power(SON=00009 SOFF=00009)
15:REG=0 16:UR(A(BKoe)=+01 B(Coe)=-01 C(Moe)=+01 D(SCoe)=-01 E(SMoe)=+01 F(BKbi)=+01
G(CLbi)=+01 H(BK-CL)=+01 I(SCLbi)=+01 J(C-SC)=+01 K(M-SM)=+01)
17:WP=0024 18:CDIN(LG=001 PB=000) 19:MSD(015)
20: PAGE(All=00083 PP=00035 HR+MP=00003 PR+SP+SG=00003 GP=00000 PC=00000 ENV=00000)
21:CDPAGE=00003 IRPAGE=00003 BTPAGE=00003 PBPAGE=00000 22:BAT PAGE=00000
23:EDGE=00083 24:L=00000 25:HEAD Temp=30.0 26:Env Temp=30.0 27:FF(3F 3F 3F)
HDEEPROM
1:V0001 2:SN=0000-3D6B 3:LN(00000 00000 000001 000003 00001 00000 00000) 4:ID=00
5:IL=(BK=000 C=+01 M=000 Y=+01 C2=+01 M2=000 Y2=+01)
Printed items:
1. Model name 2. ROM version 3. Connected I/F (USB1) 4. Main waste ink amount, Platen waste ink amount
5. Installation date 6. Operator call/service call error record 7. Last printing time 8. Purging count
(manual/deep/timer/dot count/print head installation and removal/ink tank installation and removal)
9. Cleaning time 10. Print head installation and removal (change print head) count 11. Ink tank installation and
removal (change ink tanks) count (Bk/CL) 12. Ink status (Bk/C/M/Y) 13. Total ink consumption 14. Power-on
count (soft power on/soft power off/hard power on) 15. Print head alignment implementation 16. User print head
alignment values (Bkoe/Coe/Moe/SCoe/SMoe/BKbi/CLbi/BK-CL/SCLbi/C-SC/M-SM) 17. Number of times of wiping
18. Number of times of camera port connection and removal (Legacy, PB) 19. Number of the maximum printing
intermission in days 20. Number of print pages (total/plain paper/high resolution paper + Matte Photo Paper/Photo
Paper Pro + Photo Paper Plus Glossy + Photo Paper Plus Semi-gloss/Glossy Photo Paper/Card/Envelope) 21.
Number of Camera Direct Print pages (total), number of IRDA print pages (total), number of Bluetooth print pages
(total), and number of Print Beam print pages (total) 22. Number of print pages using battery (total) 23. Number of
borderless print pages 24. Number of print page (L/4” x 6”) 25. Print head temperature 26. Inside temperature
27. Line inspection information
HDEEPROM
1. Version
2. Serial number
3. Lot number
4. Print head ID
5. Ink ejection level (Bk/C/M/Y)
Jul 23, 2009 | Office Equipment & Supplies
Elddis caravan porch light bulb blown cant remove cover
Take a pair of safety glasses, work-gloves, and a hammer, and swing the hammer to break the cover. Remove the whole unit, and replace it with an energy-efficient LED light & socket.
Apr 23, 2009 | Computers & Internet
Right brake light out 2004 Prius
Th other post is incorrect, the 2004 has LED brake lights that are part of the tail light assembly. you have to replace the whole assy. There are two screws that hold the assy in, they are both covered by white cable clips. The clips just pull off and then you can use a 10mm wrench to remove the nuts on the screws. My brake light stopped working and during the removal, the LEDs started working again, hopefully you will find the same situation as the LEDs are supposed to last for years.
Nov 29, 2008 | 2004 Toyota Prius
LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T... Logo
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
