Question about Kenmore Washing Machines
Kenmore Series 80 Washer Drips and Spin Cycle Sometimes Has Low Torque
Series 80 washer 11027802690. I've replaced the pump (3363394), coupler (285753A), clutch (285785, including the mating white plastic piece that clips to the bottom of the drive basket), top seal in gear case (3349985), oil in gear case. There are two problems which existed before I changed those parts out: (1) Spin cycle doesn't always engage with torque and/or stop quickly when I open the lid (it just spins freely and gradually slows down). (2) Water drips from center of washer seemingly when the loads are full, towards the end of the wash cycle and into the spin cycle. The water appears to have some small black particles in it. The black can not be runoff from the top of the gear case since I cleaned the exterior. The housing interior previously had a ring of gunk about 6" from the bottom, that's why I changed out the top seal in the gear case and put in new oil, replaced the clutch including that white plastic piece. I inspected the gear case, I didn't see any chipped or broken parts inside. When I had the agitator out, I didn't see any items underneath potentially blocking drainage. The lid switch works and the timer starts every cycle appropriately as the knob turns.
Does it leak every time it's run, or only occasionally? It could be that the belt on the drain pump is going bad or is loose, so it works some times but not always. Could be that the belt broke or the drain failed, so it will always leak from now on. It's hard to say without actually taking it apart and having a look
Posted on May 29, 2013
  • Michael Grosser Jun 05, 2013
    In the end I pretty much replaced every seal and bearing I could, and most of the major parts, short of the transmission. By then I was starting to spend considerable money and time on my 16 year old washer, so I decided to put the old girl out to pasture and bought a new one.
2 Suggested Answers
  • 66 Answers
SOURCE: kenmore 80 series washer not spinning
you need the gear box not the timer.
Posted on Dec 21, 2007
Kenmore 80 didn't drain during the spin cycle and leak underneath machine. Makes buzzing noise in the wash cycles.
The pump is likely damaged if it was leaking. Look for a ring of melted plastic on the face side of the pump. Check to make sure the hole is not rounded where the motor shaft enters the pump.
I'd replace the pump just to make sure the washer doesn't flood some time in the future even if the pump turn out to be ok now.
Vlad,
First Choice Appliance Service. Sacramento, CA
Jul 05, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore Washer Series 80. The cycle stops before
check to see if you have it set on drip dry
Feb 06, 2010 | Kenmore Washing Machines
Kenmore washer 80 series misses spin during wash.
You may need to replace the motor coupling between the pump and motor...
Apr 07, 2009 | Kenmore Washing Machines
Kenmore 80 series. RUNS LOUD, THEN TURNS OFF AND RESETS...
you have something gotten into your pump ,,, it trys to drain and spin but overloads the motor and shuts down till the motor switch resets .... remove the pump and take out whatever gotten in it and if that not possable replace the pump.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Washer Leaking from left front...
That would be your drain pump and/or drain hoses. You will need to access the inside of the washer by removing the outside casing to get a good view. The following link explains:
http://www.fixya.com/support/r397092-replacing_water_pump
The link explains how to replace the pump. Although you may not have a bad pump, it gives all the steps necessary to disassemble the washer to get to it. I would recommend you fill the tub about a third of the way then shut the washer off. This will fill the tub enough to determine where the leak may be coming from. Check both drain hoses for cracks or splits and make sure the clamps are tight. If the pump is leaking, it is NOT repairable. These are sealed units and will require replacing if damaged. You can purchase a new pump (if needed) at repairclinic.com. Just type in your complete model number and the pump should be listed as item number 3296 (part number 3363394).
This a simple job that requires not special tools to accomplish. I hope you find this information helpful.
Nov 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series
sounds like your control switch needs replacing.
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
149 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
