Question about Zynga Texas HoldEm Poker
My chips are gone when i get back on
I had 8mill 2mon ago but i got off and got back on they were gone so i got it back up to 2mill got off and got back on today they were gone again
I HAVE LOST 200 MILLION 2 WEEKS AGO WHY,,,, HOW IM ASKING.
If you bought chips and didn't get them --click on the help word found at the Bottom of the DDC lobby page --you will be able to get help there--If you lost it by gambling--then it's gone --Know your limits---
May 16, 2014 | Evermoremedia DoubleDown Casino
Lost chips from lucky shamrock last nite, over 19,000,000.00
I played ddc for about a hour, then when I came back all my chips were gone. it showed 0. I am a disable person and playing on DDc helps pass my time. Please give me back my chips. PLEASE.
Dec 12, 2013 | Evermoremedia DoubleDown Casino
How do you change a water pump on a 1992 Chevy Lumina
No need to drain rad You dont even need to remove the lower rad hose just remove the four bolt on the water pump pully 10mill wrench then the pully should come off after that there are 5 8mill bolt that attach the pump to the housing easy as that by the way you need to left up the idler pully to get the belt off it swings up.
Jul 17, 2009 | 1992 Chevrolet Lumina
Lcd on pixma mp 520 stopped working - was working before.
hi....
take it to a tech to check about the system control chip... the control chip would have gone bad... and they will replace u with a new chip..or else Try manually moving the head carriage back and forth a few times!
Also check, if there isn't some piece of paper lodged inside, if yes try to remove it carefully!.
rate me fixya!!!!
Jun 01, 2009 | Canon PIXMA MP520 InkJet Printer
Blue, green, red parallel curved lines at top of screen
hello sorry but it sounds like the chip have gone again when you replace these chips you might have to change the resistors and the 2 capacitors as well
shaun
May 08, 2009 | Mitsubishi WS-55905 55" Rear Projection...
Usb malfunction
The USB ports have gone bad. Just because they show up in device manager as being recognized does not mean they are working correctly. They are controlled by chips onthe motherboard and if one of those chips has gone bad, then they just won't work. The cheapest solution would be to purchase a USB card and install it, bypassing the onboard ports. Thanks and please take a moment to give this solution a rating of fixya. Thanks! :c)
Dec 29, 2008 | Intel Motherboard
Samsung CLP-500 problem
Resistors? You mean the smart chips?
Here's something I found over the last few years of dealing with these newer laser printers.
Say for example you had a 13,000 page factory toner, you replace it with a 20,000 page aftermarket refill, but you trade off the chip. There are small case triggers that read the toner size (I still haven't figured if it's internal or external) The chip is programmed for a specific cartridge size. The carts don't match, the chips won't work.
Also, certain printers will recall chips that have been used, and won't let you reapeat chips until you have gone a certain number (like it has to have 4 or 5 different chips before you can reuse the first chip).
So options to get around it.
I found in the Dell printers, if you go through the menus, there is a setting that allows you to bypass using factory cartridges, I don't know if Samsung has the same menu settings, but it's worth digging through the layers.
2) Put the chip that came with it back in, and see it it will work.
3) Break down and buy a factory cartridge. I know this is the least attractive option, but it will determine if it is a read sensor, a firmware/software error, or something else.
The whole smart chip imbedding happened about 7 years ago as a settlement on a lawsuit.
Oct 28, 2008 | Samsung CLP-510 Laser Printer
Zynga Texas HoldEm Poker Logo
18 people viewed this question
Top Zynga Facebook Apps Experts
 Grubhead
Grubhead
Are you a Zynga Facebook App Expert? Answer questions, earn points and help others
