Question about Altec Lansing AVS 500 Computer Speakers
Wiring for Altec Lansing avs500
I am looking for the wiring configuration for the din plug. I have this set of speakers as well as a set of Klipch. The din plug fell apart on my Klipsch set. From what we hear this is common and difficult to find a plug that matches. We happen to have a set of Altec's and the plug fits perfect. All the colors of the wire were the same except one on each. We were hopeing it was stardardized wireing. We found a configuration diagram for the Klipsch set but can't find one for the Altec set. If you could help us anyway you could match up the correct wires to get my Klipsch working again I would appreciate it. Thanks, Angela
    Brigadier General:
  • 6,966 Answers
Hi, from a very old Altec ACS48 : Green - right speaker Red - left speaker Black - common, ground White, Yellow & another Black - power switch Orange - Led indicator Below is the pin layout
Posted on Jul 30, 2007
  • Louie  Role
    Louie Role Jul 30, 2007
    But since the Altec Lansing AVS500 is a 5speaker system, that leaves you with 2 more wires for the front left & right. Normally Black should be common ground to all speakers. You would have to guess the other 2 wires for the front left & right.
    Hope this be of some help to you, and pls post again how things turn up. Good luck and kind regards.
Are the speaker plugs brlow rca and din plug in or out, and if its the white plug where can I get the plug for that ?
The speaker out connections are for stripped wire.
The DIN and RCA connectors are for audio IN.
The white connector is probably a power connector.
May 20, 2015 | RCA Audio Players & Recorders
Logitech z3 wiring
I have a logitech z3 subwoofer with a mini-DIN-9 connector socket. It also has a volume control and 110V power cord. As best as i could trace the circuit, and using the TDA7377 stereo bridge amplifier chip datasheet, the pinout for the mini-DIN is as follows (untested):
1: L in (to vol.)
2: R in (to vol.)
3: Power (12V from transformer)
4: Standby (5V to play, 0.05mA; 0V to standby)
5: L out
6: R out
7: Ground
8: Ground
9: Ground
Connecting 3 to 4 with a large resistance (~20K ohms) should enable speaker. Pins 1 and 2 might be swapped; pins 5 and 8 might be swapped. Mini-DIN socket pin holes are numbered right to left, bottom row to top row:
9 8 7
6 5 4 3
2 1
Sep 03, 2012 | Logitech Z3 2 Speakers
Ah i have altec lansing acs 45.1.the problem is i dont know how to wiring.can u pls help me.ynx
ok first plug run a1/8 two sided head phone jack[male] from the computer to sub woofer you should have two imput jacks makes no differance ok the left sat speaker has a 6 pin din plug round looking plug insert into subwoofer and then plugac cord in the wall you should be good togo "note right sat speaker is attached to the left good luck
Nov 16, 2010 | Altec Lansing ACS 45.1 Computer Speakers
I have cyber acoustics computer speaker system ca-3770 I think is the model. My dog ate all wires and connectors. I have new connectors and wires but I need a wiring and circuit diagram. the wires that...
Hey mate, i am sorry i do not have a complete diagram with me, but i can help you with a website from where you can get the complete wire diagram for the speaker that you want.
http://www.schematics.ca/
Try this out.
Rate me please if it helps.
Mar 16, 2010 | Cyber Acoustics CA-3770 Computer Speakers
I cant remember how the wires hook up from my sound card to my Klipch system with a sub. Thank you
you would probably need an amplifier or if it does have a head phone-like connector that can fit on soundcards green slot or speakers slot
Feb 03, 2010 | Creative Labs Sound Blaster Live! 5.1...
Diagram indicating soldering of wires to the DIN plug (Logitech X220 speakers). My three of the wires broke just before the DIN plug.
hello oh well you need to open the device to know how they are connected ...you need a voltmeter to check which one of them go signal,volts,ground etc.......saludos
Nov 25, 2008 | Audio Players & Recorders
Acoustimass 9
Acoustimass 10 IV cable
Feb 29, 2008 | Bose Acoustimass 15 System
Altec Lancing Multimedia Computer Speaker System ACS295
yeah. dude go to radio shack or a similar equivelent and they'll have all the parts as well as the instructions or even the abilities to fix it right there. Try it!
Nov 13, 2007 | Audio Players & Recorders
Looking for a control pod.
I recently had a similar problem. In my case the left speaker had no sound. Finally traced the problem to a broken wire inside the control pod plug, which I destroyed by dissecting it. For those who have the experience, or know someone who does, purchase a new plug, which a Mini DIN 8 pin (RS-422 standard). It should be available at any good electronic parts store. Solder new plug on to cable, which requires a fine electronic soldering iron and a fair bit of skill (the wires are very fine).
Look at the plug (from the rear); you will see it comprises a top row of 3 pins equaly spaced; a middle row of 3 pins (there is room for 4 pins but one pin is missing just left of centre); a bottom row of 2 pins. I numbered these as follows:
8 o 7 o 6 o
5 o 4 o 3 o
2 o 1 o
The wire from the controller comprises 8 coloured cores and a bare core. The wiring of the eight cores are as follows:
DIN CORE PCB
pin 8 - brown 8
pin 7 - red 7
pin 6 - orange 6
pin 5 - yellow 5
pin 4 - green 4
pin 3 - blue 3
pin 2 - white 2
pin 1 - black 9
body clamp - bare wire - G
In case your coloured cores vary from mine I have also listed the pin each one goes to on the printed circuit board plug, which will let you identify the colours.
Oct 11, 2007 | Level 9 Sound Designs Monsoon Planar Media...
Altec Lansing AVS 500 Computer Speakers Logo
3,538 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
