Question about Samsung BD-C5900 Blu-ray 3D Player
Netflix and DVD cuts out
We thought it was just Netflix but then we watched a DVD and it cuts out and comes back on in a few seconds. TV just blacks out and then back on. Help!
  • 124 Answers
SOURCE: Tv screen goes black for a few seconds
do you get sound while screen does black? what do you mean by "until eventually it has turned black and will not come back"? is it black from the minute you turn the tv on untill you turn it off? if sound is good but picture is black, it may be the resault of a fried monitor tube, in this case replacement will cost alot. if sound is dead also, them it is probobly power supply related issue. get out your DMM and measure the voltages in the power supply. When the screen goes black, is there still regulated B+ going to the circuitry? Do you still have HV? Is the filament of the CRT lit? Does the set still have a raster (you may have temporarily increase the screen setting to see it)? Do you measure any of the flyback derived B+ voltages that go to the video processing, tuner, Vertical Deflection, and other circuitry?
Posted on Mar 20, 2006
lukster
  • 217 Answers
SOURCE: TV Flashed HDMI
check samsung web site for firmware upgrade, or use component cabling, which is HD also
Posted on Aug 03, 2008
lukster
  • 217 Answers
SOURCE: screnn going blank
sounds like sky tv issue, try different cabling
video-tek
  • 150 Answers
SOURCE: cuts off
Hi, tough question, could be lamp, lamp circuit is overheating,t-con module or you have a bad color wheel, the latter usually causes a hi pitched squeal periodically, you have 2 choices, 1. try replacing the lamp 2. call a tech and let them diagnose it, too many possibilities without doing some diagnostics, video-tek
Posted on Feb 05, 2009
bronk50
  • 27725 Answers
SOURCE: Monitor Screening is cutting off.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Jan 27, 2011
Sony flat-screen bravia tv picture goes black but keeps playing audio when playing Netflix or DVDs.
your dvd player needs its own connection as does netflix and cable,get a new hdmi cable for each
Jul 11, 2015 | Samsung Audio Players & Recorders
Why is there no picture but sound?
Can you tell us a bit more about the problem? It would be helpful if we knew:
1) What device are you using to connect to Netflix (computer, DVD player, TV, etc.)?
2) When you use that device for something other than Netflix, do you see a picture? So if you're using a DVD player, can you play DVDs? Can you watch TV?
3) Can you log into your Netflix account on your computer and watch movies on your computer? Can you login from someone else's computer and try that?
3) When did the problem start?
Some shot-in-the-dark steps that apply to all electronics:
1) Turn everything off. Turn it all back on.
2) If that doesn't work, unplug everything. Wait 30 seconds, then plug it all back in.
3) Check all the cables (from power to your TV and Netflix device, cables coming from your peripherals to the TV, etc.). Even if they seem to be well-seated, unplug them and plug them back in.
4) Try new connections. If your TV was connected by HDMI, and you have a different way of connecting your device (DVI, component, RCA, s-video, coax, whatever) try it. If your device connects to the Internet wirelessly, see if you can get a wired connection. Swap cables wherever you can.
5) If you can, try interchanging components. So, for example, try connecting to a different HDMI port on your TV. Try other devices on your TV. Take your Netflix device (if it's not your TV) to a different TV.
Those last 2 steps may solve the problem, but are more likely to isolate the problem. (For example, if your DVD player doesn't work no matter what TV it's connected to, then the problem is the DVD player.)
Update us with as much info as you can.
Mar 29, 2015 | Netflix
Audio Cuts out on Streaming Video
I put the tv on av to watch a dvd. I now want to watch tv and it will not change from av to tv. I have a universal remote and it does not register of when I put it on tv it goes back to av
Feb 10, 2014 | Televison & Video
Black vertical lines (watching DVD); blank but lit screen (watching TV)
After 10+ years of service, it is a likely candidate for replacement.
Mar 21, 2017 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony bdp-bx57 signal cuts out
test the connection see the diagram attached. Clean the contacts and connector with contacts cleaner.180f246a-cc1f-493b-9d8e-3abff472975f.jpega07d2d96-4cdd-4858-8bc3-356bb92dae0b.gif
However you can restore in the menu to factory default.and see what happen.
Jul 13, 2013 | Sony BDP-BX57 Blu-Ray Player
TV SHUT OFF WHILE WATCHING. UNPLUG AND THEN PLUGED BACK IN. RED LIGHT CAME ON IN FRONT FOR A SECOND AND WENT BACK OFF. TV WILL NOT COME ON.
power in the tv has nothing related with the DVD. The tv has to have raster (white screen) even without signal (cable, DVD, others) if the tv alone is just having the led flashing and neither sound nor video (black screen) The tv has a short circuit in some of the boards that are part of the tv system. the blinking is part of a protection when the tv was created in the factory. Refer to the technician to repair this problem.
Apr 14, 2009 | Hitachi 61SBX59B 61" Rear Projection...
TV Flashed HDMI
Jul 29, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung BD-C5900 Blu-ray 3D Player Logo
46 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
