Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Replace handle release lever part 38458042 - Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
4 Suggested Answers
SOURCE: Hoover Self Propelled wind tunnel vacuum U6433-900
I need to replace the actuator pivot arm on my Hoover Wind Tunnel to fix the self propel feature. I can see where it needs to go but I can not seem to get the cover off the vacuum so I can get to it. How do I do this?
Posted on Sep 16, 2008
  • 377 Answers
SOURCE: Need to replace the handle-release
The exploded views at this URL will help you identify the part and you will be able to order it as well.
http://www.ereplacementparts.com/hoover-u8125960-savy-bagged-and-bagless-vacuum-parts-c-37315_37337_37538.html
Posted on Oct 13, 2010
SOURCE: The handle release lever (Part N. 38434-021) on my
You can buy Hoover Handle Release Lever 38434-021 at
http://partsreadyonline.com/item.php?ItemID=798
Posted on Jan 10, 2011
Handle release lever placement.
Best you go on line to Hoover and input the Model into their system. The support area has downloads whereby you can get the Manual free and fix the problem yourself in minutes.
Dec 18, 2013 | Hoover Vacuums
Handle Release Lever/Pedal 203-2347
Hi Chris! I'm sorry; You'll need to contact one of our Authorized Service Centers for assistance.
Here's a quick link to help you locate one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
May 18, 2013 | Bissell Model 3910 Upright Vacuum Cleaner...
The handle release pedal wasn't allowing the handle to lower. I took off the pedal and saw the spring load part was broken. What is this part and how to replace it? Bissell 3760-3 handle release
Order Slider Release (7.93, vacpartswarehouse) Pull off 'tank.' Remove 3 Screws for Foot Detent Lever. Pull off. Remove old slider release and spring (verify it's broke.) Replace with new. I just did this today after a year of dealing with it.
Mar 04, 2012 | Vacuums
Kirby Generation 3: Having trouble putting plate back on where electrical cord attaches. Ever since the shop put a new cord on for me, I have trouble using release lever for dropping the handle when I...
There are 2 tabs on the bottom front edge of the switch plate which slide under the metal top cover. Make sure these tabs have not gotten bent upward so they will not slide under the top cover. If they are bent, simply pry them open. Also, note that the handle pivot has a sliding latch on it to allow the handle to be fully lowered. To lower the handle flat, push the little knob inward.
May 03, 2011 | Vacuums
How do you replace the handle release lever on the hoover windtunnel 6425-900
The release lever is held in place by tabs molded into the base. You just need use a screwdriver or two to press the plastic tabs back and then push the release lever out. The new release lever can be just pushed into place and the plastic tabs will snap and hold it in place.
Nov 15, 2010 | Vacuums
Stand up lever is plastic, broke when stepped on to release handle, can it be repaired, replaced with a better one, plastic breaks too easily?
The pedal release can be replaced but the base will need to be checked for cracks as well. if the base is broken most common is the socket the pedal release snaps into. some of the plastic parts have been made with better materials
Oct 20, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
Bissel 3593Handle Release Lever/Pedall replacement
You need to replace slider release not just the handle. Take off the screws holding the black plate under the removavle canister the you will be able to see the slide release.
Nov 05, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Dirt Devil upright vac
It could be a broken handle release, but it also could be the the clamps where the handle asm, and the base hold together came use, this will cause this problem on some Dirt Devils. The top has to come off to check this out.
Jul 13, 2008 | Kenmore Progressive Bagless Upright with...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
35 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
