Question about Eastern Tools & Equipment ETQ TG72K12 Gas Powered Portable Generator with Electric Start
How do I get the generator to stay started? Generator cranks but won't start. Plug is firing and wet with fuel. Oil level is correct.
Fuel is ethanol-free and fresh. It ran fine a month ago.
My 20kW Kohler home generator (nat gas) cranks but won't start. Definitely getting fuel. Everything checked in October with new spark plug. Maybe a setting?
Did you check the oil level? Some generators have a oil sensor that will now allow it to start if the oil level is too low.
Mar 14, 2017 | Kohler Electrical Supplies
I have fire and gas but will not start oil alert light on when crank
By fire I assume you mean spark at the plug. When turning the engine over with the key and the oil alert light comes on the spark is interrupted by grounding the system thus the engine cannot start.
First, look at the obvious things, check oil level if it is at the recommended level smell the dipstick if it has a strong smell of gas
change the oil and try to start it again. Be sure the plug is not soaked with raw fuel before you try the restart. I the problem persists you can disconnect the wire from the top of the low oil sensor.Try to start the gen. if it starts change the low oil sensor.
I hope this all makes sense to you , good luck with it.
BR
Jul 24, 2014 | Honda 3000 Watt Portable Generator
I have a UST GG7500 Generator and it will not stay running.
Make sure there is enough oil, some generators wont start when oil level is low to protect from damage. Also have you cleaned the fuel injector, they get dirty and clogged just like a car.
Dec 28, 2012 | Computers & Internet
Husky generator won't start
did you try cleaning the conductor that goes to the spark plug if not try to clean it with a real fine sand paper it should do the job.
Oct 27, 2012 | Husky Portable generator
Honda eu 3000 won't run, cleane bowl,cleaned filter. fresh oil new plug got spark, will run for 10 seconds, the will not crank again. wait 20 min. it like crank an run 10 seconds?
i usually do a quick test of a small few onzes of fuel down the plug hole and reinstal plag and see if i9 fire up and run for a lil bit. maybe 5 -10 seconds. now i know i have spark . most usually our wonderful fuel is the problem. its just nasty now. it can stick a needle to the seat. it can hold her open . one way ya flood out. the other ya starv out. give it a try.
Oct 15, 2012 | Honda 3000 Watt Portable Generator
Onan 5500 marque gold turns over but, won't start. fault code is 32 but, batteries ok, air cleaner ok, fuel pumping, oil changed, won't start
Code 32 is a low cranking speed sense. You didn't mention a Spec # which would help. You say batteries are ok, but the generator is not getting enough cranking amps or voltage to maintain the control properly. Check, battery voltage, wiring, any in line isolation solenoids, check generator solenoid, also make sure there is no mechanical binding on the generator, a good way to do that is remove the spark plugs DISCONNECT THE BATTERY to prevent starting, underneath where the air intake is under the alternator is a plastic plug, remove that and you can put a socket I believe 3/4" up onto the alternator shaft and rotate the engine, if it tuns freely there is no binding, if you feel it is hard to move, check the drive train, belts, pulleys underneath (A lot of work, best to take to a dealer if it is mechanically bound)
Sep 13, 2012 | Onan Marquis Gold Quiet Gas Generator 5500...
Honda em5000sx generator won't start
I have a EM5000SX. My problem is my generator will not start unless I turn the fuel selector to off. Then crank it until it does start, turn the fuel back on. Run's normal . I run this generator for my cabin every weekend.
Aug 25, 2012 | Honda Electrical Supplies
Powermate 5000er 10 hp won't start no fire to the plug
Make sure that the generator is full of oil. It has a low oil level sensor that will ground the spark if the oil is low. If you have filled it to FULL with oil and still have the problem disconnect the low oil level sensor (one wire) and check for spark again. IF you now have spark the oil level sensor has either failed or is dirty. (yes you can clean them with carb cleaner.)
If after doing the above you still have no spark... I need 2 things.
1. the actual model number off of the generator Will start with PM or PMO
2. the engine model number / type / series number off of the engine
Thanks for choosing FixYa,
Kelly
Aug 27, 2011 | Coleman Electrical Supplies
I have a 3250 watt Kingcraft generator that won't
Always troubleshoot with new sparkplug. Remove the oil sending unit connection from the coil. The coil should work without any wires connected. Usually the only connections are oil sending unit that will short to ground when low oil condition and other wire must be kill wire to on/off switch. Use carb cleaner spray directly into the carb with air filter removed and choke off as fuel supply. Just a short spray and another short spray after a couple of pulls. If engine wants to start you will need to keep spraying cleaner for engine to continue to run. If engine wants to run, replace fuel with couple gallons of premium fuel to get it going. Hotter fuel will help if the compression is low. Good luck
Aug 24, 2011 | Generac Power Systems Generac 0057890 3250...
Brand new Honda Generator 2000i will not start. uhhg
Hi and welcome to FixYa I am Kelly.
Things that must be verified.
1. Fuel selector: ON
2. Start run sw: ON
3. Oil Level : Full
4. Choke selector FULL ON for no more than 2 pulls initially The half choke then off
5. Spark at the Spark Plug YES? NO?
a. No spark suspect low oil level sensor is grounding the ignition either due to low oil level or it just is not working properly.
After doing all of the above...
Spark Plug WET or DRY? Dry and still won't start check fuel supply. If you use the choke with the start run switch in the off position the spark plug should get WET. Spark plug does not get wet... with choke on and ignition off. Fuel supply problem.
At this point I suspect either the Oil Level is incorrect or... that the FUEL SELECTOR is OFF.
If you need more help just respond here and we can press on.
Kelly
Sep 02, 2010 | Honda Electrical Supplies
Eastern Tools & Equipment ETQ TG72K12 Gas Powered Portable Generator with Electric Start Logo
27 people viewed this question
Top Eastern Tools & Equipment Electrical Supplies Experts
Bernie Knutson
Bernie Knutson
Level 1 Expert
jhnolson
wadingriver
wadingriver
Are you an Eastern Tools & Equipment Electrical Supply Expert? Answer questions, earn points and help others
